indianajones11
PostPosted: Jan 25, 2012 - 08:03 AM
Here's another tutorial for driver code of the HD44780 controller. R/W pin is grounded. Code offers :
4 / 8 bit I/F for Mega, Xmega and some Tiny series MCUs . I've interfaced a 5V LCD with 3.0V Xmegas directly .
Option to use the virtual ports feature for Xmega parts .
Compiler : WinAvr20100110
IDE : Studio 4.18 SP3
Code:
slow_clk()
fast_clk()
are functions to change CPU frequency when it's too fast for the LCD, but are specific to Xmegas . Change according to your system clock, and oscillator, if you use these . Add the asm file below as just another source file, as you would for a C-file within the Studio project tree .
Jerome
lcd.c :
Code:
#include <util/delay.h>
#include   <avr/io.h>
#include <avr/pgmspace.h>
#include   "lcd.h"
extern  void ccp_write( void *ccp_reg, uint8_t value );
// Clearing a row has similar code to lcd_xy, so I factored out the common parts and so this is a combo function . See CLR_LINE () macro in lcd.h .
void   set_lcd_xy( uint8_t row, uint8_t col )
static  uint8_t   xx[4] = { 0, 0x40, 0x14, 0x54 };  // Should be changed to switch construct  else it eats 4 RAM bytes.
uint8_t   x = 0;
   x = xx[row];
   if ( col < CLR_COLS )   {
      x += col;
   x |= 0x80;
   lcd_cmd( x );
// This section provides a clr_row op. if needed .
   if ( col >=  CLR_COLS ) // Put col > CLR_COLS for 2nd parameter to clr a row.
         for ( uint8_t i = Max_col; i; i-- )
            lcd_putc( ' ' );
         //set_lcd_xy( row, 0 ); // Now set cursor to 1st column on same row.
}// End set_lcd_xy
void   lcd_putc( char a )
uint8_t   temp;
   if ( a > 9)
      temp = a;
   else  temp = a + 0x30; // Convert  to hex.
   set_rs;
#if defined   MODE_4
uint8_t   hi, lo;
   #if   defined   ( PORTA_OUT )
      slow_clk();
   #endif
   hi = (temp & UPPER_MASK );
   lo = (temp & LOWER_MASK );
   set_e;
   lcd_data = hi;
   clr_e;
   set_e;
   lcd_data = ( lo << 4 );
   clr_e;
#elif  defined   MODE_8
   //slow_clk();
   set_e;
   lcd_data = temp;
   clr_e;
#endif
   _delay_us(40);
   clr_rs;
      fast_clk();
   #endif
}// End lcd_putc
void   lcd_puts( char *s )
   while( *s != '\0' )
       lcd_putc( *s++ );
}// End lcd_puts
void   lcd_cmd( uint8_t c )
   clr_rs;
#if defined   MODE_4
uint8_t   hi, lo;
      slow_clk();
   #endif
   hi = ( c & UPPER_MASK );
   lo = ( c & LOWER_MASK );
   set_e;
   lcd_data = hi;
   clr_e;
   set_e;
   clr_e;
   set_e;
   lcd_data = c;
   clr_e;
#endif
   if ( c < 4 ){
      _delay_ms(2);
   else{
      _delay_us(40);
      fast_clk();
   #endif
}// End lcd_cmd
void   lcd_putstr_P( PGM_P s )
char   temp;
   while(  ( temp = pgm_read_byte( s++ ) ) != '\0' )
   {   lcd_putc( temp );
}// End lcd_putstr_P
#if   defined  ( PORTA_OUT ) // Xmegas only .
void   slow_clk( void ){
   OSC_CTRL &= ~( 1<< 4 );    // disable PLL
   ccp_write( (void * )&CLK_CTRL, 0x00 );  // Int. 2MHz as temp. system clk.
void   fast_clk( void ){
   //OSC_PLLCTRL = ( 8<< 0 );  Set this in main() so it doesn’t get done multiple times. Fout = (2 MHz * PLL_of_8X ) = 16 MHz .
   OSC_CTRL |= ( 1<< 4 ); // Enable PLL .
   while( !( OSC_STATUS & 0x10 ) ); // Wait unitl PLL as sys_clk is rdy to go.
   ccp_write( (void * )&CLK_CTRL, 0x04 );
#endif
lcd.h :
Code:
#ifndef    LCD_H
// Driver for HD44780 controller. R/W pin is gnd'ed.
   #define    LCD_H
   #include   <avr/io.h>
   #define   MODE_4    1  // Set to 4 bit mode
   //#define   MODE_8    1  // Set to 8 bit mode
   #define   VP_ON   1  // Use Virtual Port
   //#define   VP_OFF  1  // Don't use Virtual Port
   #define   Max_rows   4
   #define   Max_col    20
   #define   EN     2
   #define   RS     3
   #if defined DDRA  // To identify Mega or Tiny series being used.
        #define   lcd_ddr     DDRA
        #define   lcd_data    PORTA
        #define   lcd_ctrl_ddr   DDRD
        #define   lcd_ctrl     PORTD
        #define   set_e     lcd_ctrl |= (1 << EN)  //;  sets a bit
        #define   clr_e     lcd_ctrl &= ~( 1 << EN )   //;  clr a bit
        #define   set_rs    lcd_ctrl |= (1 << RS)
       #define   clr_rs    lcd_ctrl &= ~( 1<< RS)
   #elif  defined ( PORTA_OUT )  // To identify Xmega series MCU being used.
      #ifdef   VP_ON
            #define   lcd_ddr   VPORT0.DIR
         #define   lcd_data  VPORT0.OUT
         #define   lcd_ctrl_ddr    VPORT1.DIR
         #define   lcd_ctrl   VPORT1.OUT
         #define   set_e     VPORT1.OUT  |= ( 1<< EN )
         #define   clr_e     VPORT1.OUT  &= ~( 1<< EN )
         #define   set_rs     VPORT1.OUT  |= ( 1<< RS )
         #define   clr_rs     VPORT1.OUT  &= ~( 1<< RS )
      #elif   VP_OFF
         #define   CTRL_PORT  PORTE
            #define   lcd_ddr   PORTD.DIRSET
         #define   lcd_data  PORTD.OUTSET
         #define   lcd_ctrl_ddr    CTRL_PORT.DIRSET
         #define   lcd_ctrl   CTRL_PORT.OUTSET
         #define   set_e     CTRL_PORT.OUTSET = ( 1<< EN )
         #define   clr_e     CTRL_PORT.OUTCLR = ( 1<< EN )
         #define   set_rs     CTRL_PORT.OUTSET = ( 1<< RS )
         #define   clr_rs     CTRL_PORT.OUTCLR = ( 1<< RS )
      #endif  // End #ifdef   VP_ON
   #endif // End #if defined DDRD
   // LCD cmds
   #define   disp_on  2
   #define   cursor_on  1
   #define   blink_on  0
   #define   CLR_COLs   50  // Used as 2nd param. in set_lcd_xy to clr screen.
   #define   I_D   1
   #define   S     0
   #define   S_C   3
   #define   R_L   2
   #define   DL    4
   #define   N     3
   #define   F     2
   // 4 or 8 bit I/F
   #define   _8_bit    0x30
   #define   _4_bit   0x28
   #define   UPPER_MASK      0xF0
   #define   LOWER_MASK    0x0F
   #define   CLR_LCD       0x01
   #define   GO_HOME     0x02
   #define   ONE_LINER  0x30
   #define   TWO_LINER 0x38
   #define   disp_off  0x08
   #define   FAST_DELAY   50
   #define   CURSOR_ON   ( 1<< cursor_on )
   #define   BLINK_ON    ( 1<< blink_on )
   #define   CURSOR_OFF   0
   #define   CLR_LINE( row )    set_lcd_xy( row, CLR_COLS )
/******** Prototypes ***********************/
   void   set_lcd_xy( uint8_t , uint8_t );
   void   lcd_putc( char );
   void   lcd_puts( char * );
   void   lcd_cmd( uint8_t );
        void   lcd_putstr_P( PGM_P s );
   static  inline void   init_lcd( uint8_t );
   void   slow_clk ( void );   // Needed if CPU freq...
   void   fast_clk ( void );  //... too fast for LCD.
static  inline  void init_lcd( uint8_t cursor )
#if defined   MODE_4  // Init. Code for 4 bit I/F.
uint8_t   lo_nibble, hi_nibble;
   #if defined  PORTA_OUT  // Setup for Xmegas .
      #if defined   VP_ON
         PORTCFG.VPCTRLA = PORTCFG_VP1MAP_PORTE_gc | PORTCFG_VP0MAP_PORTD_gc; // VP0 for PORTD, VP1 for PORTE
          VPORT0.DIR = 0xF0; // Set Upper nibble as output .
          VPORT1.DIR = ( 1<< EN | 1<< RS );  //Set lcd control pins as output .
      #elif   defined  VP_OFF
         lcd_ddr |= 0xF0;
         lcd_ctrl_ddr |= (1<<EN) | (1<<RS);
      #endif
   #elif   defined  DDRA  // Setup for all other MCU types .
      lcd_ddr |= 0xF0; // Set Upper nibble as output .
      lcd_ctrl_ddr |= (1<<EN) | (1<<RS); // Set lcd control pins as output .
   #endif // End #if defined  PORTA_OUT
   // Must send MSN ONLY and 3X 1st. and Enable line must toggle for each nibble.
   lcd_data = 0;  // Data and ...
   lcd_ctrl &= ~( (1<<EN) | (1<<RS) );  //... control lines init. to zero .
   _delay_ms(60);  // PORst. delay, needed.
   hi_nibble =  _8_bit;
   set_e;
   lcd_data = hi_nibble;   // Send 1st function set, must be ( 0x3x ) to lcd... first time.
   clr_e;
   _delay_ms(6);      // Must be > 4.1 ms
   set_e;             //  2nd send of function set
   clr_e;
   _delay_us(105);   // Must be > 100 uS
   set_e;           // 3rd @@!@!!!! send of function set.
   clr_e;
   _delay_us(105);
//************ Code above this line cannot be changed, except TWO_LINER.
   hi_nibble = _4_bit;
   set_e;                  // This section sets desired data bit size I/F to 4 bits.
   lcd_data = hi_nibble;  //TWO_LINER;
   clr_e;
   _delay_us(FAST_DELAY);
   hi_nibble = ( ( _4_bit | 0x08 ) & ( UPPER_MASK ) );
   lo_nibble = ( ( _4_bit | 0x08 ) & ( LOWER_MASK ) );
   set_e;                  // This part preserves data bit size I/F, and sets font and # of lines.
   clr_e;
//_delay_us(FAST_DELAY); NO !! Delay after a byte, NOT nibble !
   set_e;
   lcd_data = ( lo_nibble << 4 );
   clr_e;
      // 1 byte sent.
   hi_nibble = ( disp_off & UPPER_MASK );
   lo_nibble = ( disp_off & LOWER_MASK );
   set_e;
   clr_e;
   set_e;
   clr_e;
   hi_nibble = ( CLR_LCD & UPPER_MASK );
   lo_nibble = ( CLR_LCD & LOWER_MASK );
   set_e;
   clr_e;
   set_e;
   clr_e;
   hi_nibble = ( ( 0x04 | 1 << I_D ) & UPPER_MASK );
   lo_nibble = ( ( 0x04 | 1 << I_D ) & LOWER_MASK );
   set_e;           // Set entry mode -- 0x06 is cursor shift right
   clr_e;
   set_e;
   clr_e;
/********** end of 4 bit init. **********************/
   hi_nibble = ( 0x14 & UPPER_MASK );
   lo_nibble = ( 0x14 & LOWER_MASK );
   set_e;                  // 0x14 is enable cursor right shift
   clr_e;
   set_e;
   clr_e;
   set_e;
   clr_e;
   set_e;
   clr_e;
   _delay_ms(2);
   hi_nibble = ( GO_HOME & UPPER_MASK );
   lo_nibble = ( GO_HOME & LOWER_MASK );
   set_e;
   clr_e;
   set_e;
   clr_e;
   _delay_ms(2);
   hi_nibble = ( ( 0x08 |  1<< disp_on  |  cursor  ) & UPPER_MASK );
   lo_nibble = ( ( 0x08 |  1<< disp_on  |  cursor  ) & LOWER_MASK );
   set_e;
   lcd_data = hi_nibble;  //( 1<< cursor_on)  | ( 1<< blink_on );
   clr_e;
   set_e;
   clr_e;
   // 1 byte sent.
#elif  defined   MODE_8  // Init. Code for 8 bit I/F.
      lcd_ddr = 0xFF;
   #endif
      lcd_data = 0;  // Clr data and...
      lcd_ctrl &= ~( (1<<EN) | (1<<RS) );  //... control lines .
      _delay_ms(60);  // PORst. delay needed.
      set_e; // Send 1st function set, 0x3x to lcd... first time.
      lcd_data = TWO_LINER;    // 0x38
      clr_e;
      _delay_ms(6);  // Must be > 4.1 Ms
      clr_e;
      set_e; // 3rd send of function set.
      clr_e;
      _delay_us(105);
/********** Code above this line cannot be changed *********************/
      set_e;  // This line actually sets desired data bit size I/F, font and # of lines.
      clr_e;
      set_e;
      lcd_data = disp_off;
      clr_e;
      set_e; // 0x01
      lcd_data = CLR_LCD;
      clr_e;
      lcd_data = ( 0x04 | 1 << I_D ); // 0x01
      clr_e;
/***************** end of 8 bit init. *****************************/
      lcd_data = 0x14;
      clr_e;
      set_e; // 0x01
      lcd_data = CLR_LCD;
      clr_e;
      _delay_ms(2);
      set_e; // 0x02
      lcd_data = GO_HOME;
      clr_e;
      _delay_ms(2);
      set_e;
      lcd_data = ( 0x08) | ( 1<< disp_on) | ( cursor );  //( 1<< cursor_on)  | ( 1<< blink_on );
      clr_e;
#endif // #if defined   MODE_4
   }// End init_LCD
#endif  // End  #ifndef    LCD_H
ccp.S :
Code:
#define   _SFR_ASM_COMPAT   1
#define   _SFR_OFFSET  0
#include  <avr/io.h>
#define   CCP_SIGN   0xD8
.global  ccp_write
.func  ccp_write
   ccp_write:
    movw   r26, r24  // Copy register address into X ptr.
   ldi  r24, CCP_SIGN
   out  CCP, r24
    st   X, r22  // Write value to protected register X_ptr.
ret
.endfunc
// Must use registers shown, BUT you can use Y ( must preserve these registers ) or Z ptr. instead of X .
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
