Posted: Sep 30, 2011 - 07:24 AM |
I am trying to make of program of 0 to 99 counter of about 1s delay using the timer1's ctc mode. I have declared a global variable called num . I wrote the program so that at every 1 second a compare match interrupt will be executed and in the ISR the value of the global variable will be increased by 1 . Then the value will be used in main function to use it for output .
Here is the code
#define F_CPU 1000000UL
#include<util/delay.h>
#include <avr\io.h>
#include <avr\interrupt.h>
unsigned int num=0;
/* signal handler for timer overflow interrupt TOV0 */
ISR(TIMER1_COMPA_vect) {
if(num<99) ++num;
else num=0;
void square_wave_init(void){
/*Timer/Counter1, Output Compare A Match Interrupt Enable*/
TIMSK |= (1<<OCIE1A);
/*set timer counter initial value*/
TCNT1=0;
// Initialize Output Compare Register - 1A
OCR1A = 487;
// Waveform generation mode:4 : CTC : Clear Timer on Compare match
TCCR1B |= (1<<WGM12);
/*start timer with presscaler of clk/1024*/
TCCR1B |= (1<<CS10) | (1<<CS12);
square_wave_init();
/* enable interrupts */
sei();
unsigned int a=0,b=0;
DDRD=0xFF;
a=num%10;
b=num/10;
PORTD=a;
PORTD|=(1<<4);
_delay_ms(10);
PORTD&=(~(1<<4));
PORTD=b;
PORTD|=(1<<5);
_delay_ms(10);
PORTD&=(~(1<<5));
But its not working . plz guys help me debug it ....[/quote] |
Posted: Sep 30, 2011 - 07:26 AM |
How is it not working? (1) not counting? (2) wrong count speed (fast? or slow?)
What is your actual clock speed? And, how do you know?
Jim |
_________________ Jim Wagner
Posted: Sep 30, 2011 - 08:12 AM |
Posted: Sep 30, 2011 - 09:14 AM |
Posted: Sep 30, 2011 - 07:23 PM |
| the value of the variable 'num' isnt being assigned to the variables a or b . the value of the variable 'num' isnt being assigned to the variables a or b . |
Posted: Sep 30, 2011 - 07:29 PM |
If you actually READ that link I just gave then you would know EXACTLY why this is. The optimiser will hunt out anything pointless in your program and ditch it. |
Posted: Sep 30, 2011 - 08:30 PM |
i have just read it and understood what was happening in the code . Thnx a lot  |
