| Author |
Message |
Posted: Jun 29, 2011 - 02:00 AM |
I think my bootcmd or bootargs might be incorrect???????
This is the process i followed after building successfully building the kernal.
Set up the SD Card on the computer
Code:
sudo umount /dev/sdc
sudo /sbin/e2fsck /dev/sdc
sudo /sbin/mkfs ext2 /dev/sdc -I128
Copy files from computer -> SD Card
Code:
sudo dd if=/home/alastair/Desktop/buildroot-avr32-v3.0.0/output/images/rootfs.ext2 of=/dev/sdc
sudo dd if=/home/alastair/Desktop/buildroot-avr32-v3.0.0/output/images/u-boot.bin of=/dev/sdc
sudo dd if=/home/alastair/Desktop/buildroot-avr32-v3.0.0/output/images/uImage of=/dev/sdc
Uboot Parameters
Code:
baudrate=115200
ethaddr=00:04:25:1C:6A:D2
bootdelay=1
ethact=macb0
serverip=172.24.41.2
tftpip=172.24.41.2
eth1addr=00:04:25:1C:6A:D3
filesize=ded1f
env=askenv
bootargs=console=ttyS0 root=/dev/mtdblock1 rootfstype=ext2 rootwait rootdelay=1
bootcmd=mmcinit; ext2load mmcblk0p1 0x10400000 /uImage; bootm;
stdin=serial
stdout=serial
stderr=serial
Boot
Code:
U-Boot code: 00000000 -> 000144f7 data: 24000000 -> 24002d80
SDRAM: 32 MB at address 0x10000000
Testing SDRAM...OK
malloc: Using memory from 0x11fc0000 to 0x12000000
Flash: 8 MB at address 0x00000000
DRAM Configuration:
Bank #0: 10000000 32 MB
In: serial
Out: serial
Err: serial
Net: macb0, macb1
Press SPACE to abort autoboot in 1 seconds
Manufacturer ID: 1B
OEM/Application ID: 534D
Product name: 00000
Product Revision: 1.0
Product Serial Number: 2983805300
Manufacturing Date: 08/09
SD Card detected (RCA 2)
CSD data: 007fff32 5f5983ce 76dbdfff 924000b9
CSD structure version: 1.0
MMC System Spec version: 0
Card command classes: 5f5
Read block length: 512
Supports partial reads
Write block length: 512
Does not support partial writes
Supports group WP: 32
Card capacity: 1021837312 bytes
File format: 0/0
Write protection:
** No boot file defined **
## Booting image at 10200000 ...
Bad Magic Number
Posted: Jun 29, 2011 - 07:09 AM |
Seems like your bootcmd is doing something else. You only need rootwait or rootdelay, not both. Rootfstype should autodetect with ext2, and you can NOT have an ext2 file system in raw flash devices. Use ubifs, or jffs2.
I would also recommend that you partition your SD-card, even if it just is to have one big partition.
Delete your filesize argument i U-Boot.
Arguments I use when booting a file system from SD-card:
Code:
set bootargs root=/dev/mmcblk0p1 rootwait
set bootcmd 'mmc init; ext2load mmc 0:1 0x10400000 /boot/uImage; bootm'
Posted: Jul 06, 2011 - 01:12 PM |
Still having some problems with this.
I think there might have been a problem with my buildroot so i have downloaded the binaries directly. I am now using an EVKLCD101 so i have downloaded the binarys for that from here - http://www.atmel.no/buildroot/binaries/ ... evklcd100/
I have copied the jffs2-root and jffs2-usr files to the SD card using sudo dd if=**file path** of=/dev/sdc
Previously i was using files labelled as rootfs.ext2 so not sure if i can still use
now that the files are labeled as jffs2. Does the bootcmd or bootargs change due to this? |
Posted: Jul 09, 2011 - 04:09 AM |
Posted: Jul 22, 2011 - 06:08 AM |
are your bootargs and bootcmd correct? as far as I remember root path should be root=/dev/mmcblk0p1
my ngw100 uses:
Code:
bootargs=console=ttyS0 root=/dev/mmcblk0p1 rootwait
bootcmd=mmcinit; ext2load mmc 0:1 0x10400000 /boot/uImage; bootm 0x10400000
[/code] |
Posted: Aug 01, 2011 - 05:27 AM |
Thanks for your post
With those bootargs/cmd i get an error saying
** Unable to read "/boot/uImage" from mmc 0:1" **
## Booting image at 10400000
Bad Majic Number
I have checked the SD card and the file system looks like it copied perfectly.
Whats the story with Uboot, do newer versions of the buildroot need newer versions of Uboot? If so what the clearest most up to date guide as to how to update Uboot? |
Posted: Aug 12, 2011 - 03:12 AM |
Resolution:
Contacted Atmel. Upgraded Uboot using the Uboot file found in http://www.atmel.no/buildroot/binaries/ ... gw100mkii/
I used the AVRATJTAGICE_MKII to do this by first installing AVR32Studio on my PC then
open command prompt and cd into the following directory
program files\Atmel\Plugins\com.atmel.avr.utilities.win32.x86_3.0.0.201012011602\os\win32\x86\bin
make sure the u-boot.bin file is in this directory. Plug the AVRATJTAGICE_MKII into your computer and automatically install (driver is part of AVR32Studio)
Plug into your device, make sure you get the JGTAG pins round the right way
Erase flash
avr32program erase -fcfi@0 ;
Program new uboot
avr32program program -F bin -vfcfi@0 u-boot.bin;
Use the EVKLCD101 Linux binary from http://www.atmel.no/buildroot/binaries/ ... evklcd101/
Put on your SD card (will post a good article on howw to do this here)
set bootcmd to mmc init; ext2load mmc 0:1 0x10400000 /boot/uImage; bootm 0x10400000
set bootargs to console=ttyS0 root=/dev/mmcblk0p1 fbmem=600k rootwait
WORKS |
Posted: Aug 26, 2012 - 02:36 AM |
| Hi,is just that i dont know why my boot folder is not visible in the SD card, i can see it if i plug it into the PC (the SD card) but when i plug it into the atngw100 board there is no boot folder and no uImage, i don't understand why, and because of that problem, my board isn't booting, i already changed my SD card, i was first using a terasic SD card (256 MB) and now i'm using a kingston micro SD card (1 GB). please help. thanks in advanced. |
