maximax
PostPosted: Jun 08, 2012 - 05:17 PM
First of all my apologies if I am posting this in the wrong forum. I am using avr-gcc, however the solution to my problem may or may not be avr-gcc specific.
I have been toying recently with a AD9851 dds module which I currently have hooked up to a mega48 also running v-usb (software usb) in cdc mode. In other words it connects to a pc via usb and presents itself as a serial com device.
Naturally space is getting a bit tight but it all works and fits quite comfortably until I try to perform the following calculation in firmware.
#include <math.h>
#define DDS_XTAL 180000000
unsigned long tuning_word = (frequency * pow(2, 32)) / DDS_XTAL
So at last to my question. Is there any way I can optimize this somehow to squeeze it into my mega48? So far all my attempts to replace the pow function with constants or macros seem to have resulted in even more code and/or compiler warnings.
I guess the obvious solution in upgrade to a mega88 but since there is not that much in it (less than 1K) I thought it might be worth asking.
The other solution (I am currently using) is to have the pc perform the heavy maths and simply send the pre-calculated tuning word to the mcu. This of course requires me to have a custom application to communicate with the module whereas my original intention was to be able control the device via any serial terminal software.
Some readers may be wondering how I am compiling the code and with what optimizations. The answer is that I am using the Makefile (attached) which came with the cdc-io software I adapted to suit my needs.
PostPosted: Jun 08, 2012 - 05:21 PM
pow(2,32) is surely just 4294967296ULL ?
BTW so others don't have to download the text file the key lines are:
## Options common to compile, link and assembly rules
COMMON = -mmcu=$(MCU)
## Compile options common for all C compilation units.
CFLAGS = $(COMMON)
CFLAGS += -Wall -gdwarf-2 -DF_CPU=12000000UL -Os -fsigned-char
CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d
Unless I missed my guess that's a Makefile created straight out of AS4.
PostPosted: Jun 08, 2012 - 05:57 PM
I'm way confused. Put any value into "frequency", shift it left 32 bits, store the low 32 bits--won't it always be 0?
PostPosted: Jun 08, 2012 - 06:00 PM
I wondered about that - thread title says "long long" but code says just "long". I presume OP is aware that unlike a PC sizeof(int) = 2, sizeof(long) = 4, sizeof(long long) = 8?
I guess the code snippet may have been a typo?
maximax
Yes, and unfortunately it produces about (if not exactly) the same amount of code as the pow function Sad
I also tried (1 << 32) which gave a warning that the bit shift was to wide for the long type.
btw, thanks for pointing out the relevant section of the makefile.
maximax
PostPosted: Jun 08, 2012 - 06:10 PM
Sorry if the thread tittle is adding confusion, I am aware of the size of the long and long long types.
The problem seems to be that the intermediate type needs to be ULL to multiply the UL prior to the division.
However there was a slight typo in the code snippet I posted. DDS_XTAL is defined as 180000000UL not 180000000.
PostPosted: Jun 08, 2012 - 06:24 PM
The problem seems to be that the intermediate type needs to be ULL to multiply the two UL's prior to the division.
??? Even thought AFAIK pow() only returns a float result, the low 32 bits of your result will always be zero.
In the meantime you've pulled in a bunch of float code.
We can't see what "frequency" type is. But if starting with an integral frequency, doing integral operations, and getting/using an integral result then avoid the FP operations. The operation shown doesn't make much sense, so it is TBD if even long-long is needed.
Have you tried:
unsigned long tuning_word = ((unsigned long long)frequency * 4294967296ULL) / DDS_XTAL
The intermediate part of this is likely to overflow otherwise.
But the 4294967296ULL / 180000000UL terms in this are fixed constants and my calculator says that is 23.86092942222 so why not simply multiply 'frequency' by that number? Depending on the accuracy you are looking for it could be that an integer multiply by 24 might be OK?
If you do need to use 23.8609etc then this is going to bring in 700 bytes of FP lib. But either way use:
unsigned long tuning_word = frequency * (4294967296.0f / DDS_XTAL)
which will at least force the division to occur at compile time. The .0f suffix will guarantee that it's replaced by a float constant.
maximax
PostPosted: Jun 08, 2012 - 06:40 PM
Ok, I will try to clarify. The original formula came from an arduino example I found on the net, it works just fine but then space was not an issue on a mega328 without sw usb stack.
I have tried using both UL and float types for frequency, so far the following produces the least code but still it wont quite fit.
#define DDS_MULT 23.8609294  /* ( pow(2, 32) / 180000000 ) */
float frequency = 1000.0;
unsigned long tuning_word = frequency * DDS_MULT;
I am now thinking I need to order up a mega88 and just be done with it.
Edit: Sorry Cliff, you posted while I was typing, looks like we think alike but still no dice.
PostPosted: Jun 08, 2012 - 06:45 PM
How about:
#define DDS_MULT 238609UL
uint16_t frequency = 1000;
uint32_t tuning_word = (frequency * DDS_MULT) / 10000;
That still allows "headroom" for frequencies up to 18,000 and keeps everything in 32bits. But to use scaled integers like this you need to think about if you need any decimal places of accuracy in frequency or is it OK in integer steps? If you want more digits of accuracy in DDS_MULT and more in freuqnecy (by scaling it) then this would spill into uint64_t which are almost as bad as floats.
PostPosted: Jun 08, 2012 - 06:56 PM
still no dice.
Any of the small(er) ratios below are off by less than 0.001:
23.8609294 0.000181711111110872 859 36
23.8609294 0.000464283720930325 1026 43
23.8609294 0.000929400000000413 1193 50
23.8609294 0.000609061538462186 1551 65
23.8609294 0.000181711111110872 1718 72
23.8609294 0.000169906329112735 1885 79
23.8609294 0.000464283720930325 2052 86
23.8609294 0.000714346236559749 2219 93
23.8609294 0.000772727659573036 2243 94
23.8609294 0.000929400000000413 2386 100
23.8609294 0.000456738613863195 2410 101
23.8609294 0.000181711111110872 2577 108
23.8609294 5.98347826077372E-05 2744 115
23.8609294 0.000273662295082744 2911 122
23.8609294 0.000859217886180375 2935 123
23.8609294 0.000464283720930325 3078 129
23.8609294 0.000609061538462186 3102 130
23.8609294 0.000635282352941857 3245 136
23.8609294 0.000384468613138012 3269 137
23.8609294 0.000789539860139854 3412 143
23.8609294 0.000181711111110872 3436 144
23.8609294 0.000929400000000413 3579 150
23.8609294 2.24768211865012E-06 3603 151
23.8609294 0.000912705263157676 3627 152
23.8609294 0.000169906329112735 3770 158
23.8609294 0.000705820125787682 3794 159
23.8609294 0.000323339393940358 3937 165
23.8609294 0.000516383132531217 3961 166
23.8609294 0.000464283720930325 4104 172
23.8609294 0.000342276300578703 4128 173
23.8609294 0.000594204469273052 4271 179
23.8609294 0.000181711111110872 4295 180
23.8609294 0.000949053038674208 4319 181
23.8609294 0.000714346236559749 4438 186
23.8609294 3.31668449184974E-05 4462 187
23.8609294 0.000772727659573036 4486 188
23.8609294 0.00082577305699516 4605 193
23.8609294 0.00010465773195989 4629 194
23.8609294 0.000609061538462186 4653 195
23.8609294 0.000929400000000413 4772 200
23.8609294 0.000232882587063443 4796 201
23.8609294 0.000456738613863195 4820 202
23.8609294 0.000352476923076495 4963 208
23.8609294 0.000314619138755745 4987 209
23.8609294 0.000975361904760774 5011 210
23.8609294 0.000464283720930325 5130 215
23.8609294 0.000181711111110872 5154 216
23.8609294 0.000821752073733251 5178 217
23.8609294 0.000569039639639612 5297 222
23.8609294 5.71470852008815E-05 5321 223
23.8609294 0.000677742857142505 5345 224
maximax
PostPosted: Jun 08, 2012 - 07:04 PM
Thanks for the suggestions and insight guys but among other things, I plan to use this as a VFO for a homebrew shortwave receiver so frequency needs to be in the range of 100KHz - 30MHz accurate to the nearest 1Hz or so.
PostPosted: Jun 08, 2012 - 07:14 PM
I'd say that's an impossible dream. The crystal that clocks your AVR is probably only good for 30ppm yet you are asking for 0.03ppm
Because 1 is a 16 bit int. You need (1ULl << 32).
But 180000000 is divisible by 256, so you could use:
unsigned long tuning_word = frequency * (1ULL<<24) / 703125;
What is the range and accuracy of frequency and what accuracy do you expect from the result?
maximax
PostPosted: Jun 08, 2012 - 07:30 PM
I am not sure I follow you, the crystal clocking the avr only needs to be good enough for v-usb. The dds module has it's own crystal and I do not know the accuracy of this module in practice. I guess I mean to say that I want the control frequency to be specified in Hz to the nearest 1Hz. What I actually get may be another matter.
Koshchi, thanks, I will look at your suggestion more closely and see if that helps. I hope the above answers your question regarding accuracy.
PostPosted: Jun 08, 2012 - 07:36 PM
So that's a sub 1ppm crystal is it?
What is the point in allowing control in 1Hz steps if you cannot be sure within 10's of Hz. Let's say that 180MHz crystal is 30ppm (many are about that). So it's only accurate to +/- 30 * 180 = +/-5,400Hz. So, yeah, maybe let the user step in 5kHz steps but 1Hz steps is not realistic. Also doing the maths to more accuracy than 5Khz in 180MHz does not make much sense either.
Some of those integer ratios Lee presented looked pretty good to me. Especially 3603 / 151 = 23.860927152317880794701986754967 so you multiply 'frequency' by 3603 then divide by 151.
maximax
PostPosted: Jun 08, 2012 - 07:50 PM
The best info I can find on the module is available here:
http://www.rocketnumbernine.com/2011/10/25/programming-the-ad9851-dds-synthesizer
For more info you would need to refer to the AD9851 datasheet.
All I know is that when used as a vfo in a simple direct conversion receiver, I am able to hear subtle changes in ssb modulation as I tune in steps of 1 or 2Hz
PostPosted: Jun 08, 2012 - 07:58 PM
BTW: Along the lines of crystal precision and such, you might want to do a bit of numerical analysis on the results if you >>do<< the float stuff using Mega88 or whatever: A GCC float has only a 22 bit mantissa giving 23 bits after normalization (IIRC). The point is that it is only 6-7 decimal digits so your constant is only good to a 1/10000 probably anyway.
kavrcalc says that putting 23.8609294 into a float and then bringing it back gives 23.86093.
maximax
PostPosted: Jun 08, 2012 - 08:16 PM
The example in the link I posted above actually uses double for frequency. Not sure if that makes much difference to what you are saying.
If I do opt for the bigger part I will probably stick with the pow function as this has been proven to work and produces no more code than the constant equivalent.
PostPosted: Jun 08, 2012 - 08:49 PM
Yeah, it does, 'cause given the forum you are posting in, in your toolchain "float" and "double" are synonymous. (They have the same storage size and thus precision.)
That is pretty cool. Given the discussion about absolute accuracy, one approach would be to do as you are doing to get to the "nominal" frequency, and then tweak in one-count steps of "tuning_word". That's as small a step as it looks like you can get. From that, you can display e.g. the +/- in unitless "steps" from the nominal/programmed value, and if desired back-calculate the estimated frequency.
