| Author |
Message |
Posted: May 22, 2011 - 03:43 PM |
Dear freaks,
I work in a project using and the 8 adc chanels in atmega16( avr studio gcc) and i want t read and the 8 chanels and to send them to the serial port. The problem is when i try to change analog chanel and i choose the one who i had used before the atmega read always the same chanel.
For example
Code:
adc0=0
adc1=10
adc2=20
adc3=30
First time read adc0 and sends 0
Second time reads adc1 sends 10
Third time reads adc2 sends 20
Fourth time reads adc3 sends 30
Fifth time reads adc0 sends 30
Six time reads adc1 sends 30
And the problem stops when ia reset the atmega16
The code
Code:
#include <avr/interrupt.h>
#include <util/delay.h>
#define USART_BAUDRATE 9600
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
//adc~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
void InitADC()
ADMUX=(0<<REFS0)|(0<<REFS1);
ADCSRA=(1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(0<<ADPS0);
uint16_t ReadADC(uint8_t ch)
//Select ADC Channel ch must be 0-7
ch=ch&0b00000111;
ADMUX|=ch;
//Start Single conversion
ADCSRA|=(1<<ADSC);
//Wait for conversion to complete
while(!(ADCSRA & (1<<ADIF)));
ADCSRA|=(1<<ADIF);
return(ADC);
//-----------------------MAIN
int main (void)
//serialINSTAL
UCSRB |= (1 << RXEN) | (1 << TXEN);
UCSRC |= (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1);
UBRRL = BAUD_PRESCALE;
UBRRH = (BAUD_PRESCALE >> 8);
//ENDserialINSTAL
uint16_t adc_result;
InitADC();
char a;
begin:
while ((UCSRA & (1 << RXC)) == 0) {}; // Do nothing until read serial
a=UDR;
if(a==((char) '1')){
adc_result=ReadADC(0);
while ((UCSRA & (1 << UDRE)) == 0) {};
UDR=adc_result;
goto begin;
if(a==((char) '2')){
adc_result=ReadADC(1);
UDR=adc_result;
goto begin;
if(a==((char) '3')){
adc_result=ReadADC(2);
UDR=adc_result;
goto begin;
if(a==((char) '4')){
adc_result=ReadADC(3);
UDR=adc_result;
goto begin;
if(a==((char) '5')){
adc_result=ReadADC(4);
UDR=adc_result;
goto begin;
if(a==((char) '6')){
adc_result=ReadADC(5);
UDR=adc_result;
goto begin;
if(a==((char) '7')){
adc_result=ReadADC(6);
UDR=adc_result;
goto begin;
if(a==((char) '8')){
adc_result=ReadADC(7);
UDR=adc_result;
goto begin;
goto begin;
I use 8Mhz external clock and the pin AREF is connected to VCC pin(5volts)
My analog inputs are potensiomters in series with resistors
Does anyone knows what is happeneing?
Thaks! |
Posted: May 22, 2011 - 04:10 PM |
ch=ch&0b00000111;
ADMUX|=ch;
If you want to change the adc channel, you have to
Code:
first clear the old channel
ADMUX &= 0b11111000
then OR the new one
ADMUX |= ch;
PS
Another way
Code:
// define reference
#define REF (1<<REFS0)|(1<<REFS1)
// set/change channel
ADMUX = REF | channel
Posted: May 22, 2011 - 04:39 PM |
ch=ch&0b00000111;
ADMUX|=ch;
Code:
ADMUX &= 0b11111000
then OR the new one
ADMUX |= ch;
PS
Another way
Code:
// define reference
Dear Visovian,
Thanks for response and for your solution  |
Posted: May 22, 2011 - 07:07 PM |
| Once again, a Gem of General AVR C Advice will be missed by all users of the Other Compilers. Hey Eivind! Lets change to vBulletin so we can rate the threads and tag the good replies. |
_________________ Imagecraft compiler user
Posted: May 22, 2011 - 07:14 PM |
Make up your mind, Bob. Or post your rules for being politically-correct in choosing which Forum. I remember you complaining about fairly generic questions in the main Forum after it was seen that the poster used gcc. "You've got your own Forum for that compiler brand" or something like that.
I can't play the game if I don't know the rules.
Lee |
Posted: May 22, 2011 - 07:33 PM |
| I guess just post a sticky thread in the AVR forum that says "If you are trying to learn General C, you better read the GCC forum too, because that's what most people use, so that's where the most advice is dished out". Otherwise, does vBulletin let you add tags to posts? Then you could search for [mega32] [adc] [c source] [cv] or [mega168] [twi] [gcc] |
Posted: May 22, 2011 - 08:08 PM |
Yeah, stickies telling new people where to post have been proven to work SO well - not!
You have to accept that newbies ARE going to post in the wrong place. What you can do is contact a moderator and ask them to move any such thread.
Should I move this one - even though it is "[solved]"? |
Posted: May 22, 2011 - 08:17 PM |
| I don't REALLY care. I'm just input overloaded. The list of stuff I Don't Know Anything About keeps getting bigger. I barely know c on one compiler. I need to learn about ARMs, TFT lcds, decomposing program into tasks, learn some modern languages like c#. And I have 30+ years of experience in embedded microcontrollers. It must be real hard for the new guys to get going. Tell em to read both forums I guess. |
