Bingo600
PostPosted: Mar 04, 2011 - 10:09 PM
Quick hack for compiling the Atmel AS toolchain (afaik this isn't the one used in AS5).
But i cant seem to find those patches ...
See - http://distribute.atmel.no/tools/opensource/avr-gcc/
It uses avr-gcc-4.4.3 , but avr-libc-1.7.1.
And a newer gmp & mpfr ... (dont think gmp/mpfr versions makes much difference in the avr code).
You can skip get-patches.sh (they are already in the patches dir) , and just run getfiles.sh
Im skipping avr-libc support for the xmega32x1 & xmega128b1
I cant get the Atmel patches to work (build)
I also had to make a patch for binutils Makefile.in -
56-binutils-2.20.1-avrtiny10-makefile-in.patch
Wonder if "Atmel" ever tested the sources that is in the above url (on a build) ????
# Drop avr-libc patching for now , i cant get the Atmel sources to work
# We are skipping support for the xmega32x1 & xmega128b1
# See - avrlibc : http://distribute.atmel.no/tools/opensource/avr-gcc/
As usual there is no warranties , and i can not be held responsible for any damage caused by the use of this script , ot what it creates.
There might be a slight error with delay.h complaining (See below).
And I just had a "hint" that the solution is to include <math.h> from within <util/delay.h">
/Bingo[/quote]
Bingo600
PostPosted: Mar 05, 2011 - 08:41 AM
@Eric / Atmel
This isn't to "pollute" the Crosstool talk on the acr-gcc list.
It was mostly to try the patches , and to see some tiny10 support.
btw: Thanx for the patches , i suppose the new patchset for the AS5 toolchain will popup in the near future.
/Bingo
madworm
PostPosted: Mar 07, 2011 - 05:15 PM
Rookie
Your Sir are a god! Very Happy Very Happy Very Happy
It worked Wink Now I can finally program my ATtiny4313...
I suggest to add these two things:
a) patch for avrdude.conf for ATtiny4313 as found here.
b) at least a note mentioning udev-rules
THANK YOU !
madworm
PostPosted: Mar 07, 2011 - 06:28 PM
Rookie
One issue I've had so far is this:
Everything I compile using my makefile works. It uses avr-gcc, no C++ stuff involved.
Now as I am on linux, I tried to fire up the Arduino IDE and compile some code there as well. It compiles, except the last few steps that involve avr-g++ for compiling C++ code.
It chokes on including <avr/delay.h>, which seems to want to use functions 'ceil()' and 'fabs()', which are defined in 'math.h', which doesn't get included in 'delay.h'.
Code:
 avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=8000000L -DARDUINO=22 -I/xxx/arduino-0022/hardware/arduino/cores/arduino /xxx/arduino-0022/hardware/arduino/cores/arduino/HardwareSerial.cpp -o/tmp/build5414833210231722667.tmp/HardwareSerial.cpp.o
In file included from /usr/local/avr/lib/gcc/avr/4.4.3/../../../../avr/include/avr/delay.h:37,
                 from /xxx/arduino-0022/hardware/arduino/cores/arduino/wiring_private.h:30,
                 from /xxx/arduino-0022/hardware/arduino/cores/arduino/HardwareSerial.cpp:28:
/usr/local/avr/lib/gcc/avr/4.4.3/../../../../avr/include/util/delay.h: In function 'void _delay_ms(double)':
/usr/local/avr/lib/gcc/avr/4.4.3/../../../../avr/include/util/delay.h:149: error: 'fabs' was not declared in this scope
/usr/local/avr/lib/gcc/avr/4.4.3/../../../../avr/include/util/delay.h:149: error: 'ceil' was not declared in this scope
/usr/local/avr/lib/gcc/avr/4.4.3/../../../../avr/include/util/delay.h: In function 'void _delay_us(double)':
/usr/local/avr/lib/gcc/avr/4.4.3/../../../../avr/include/util/delay.h:226: error: 'fabs' was not declared in this scope
/usr/local/avr/lib/gcc/avr/4.4.3/../../../../avr/include/util/delay.h:226: error: 'ceil' was not declared in this scope
I can force this error to show up as well, when trying to compile my code (which compiles with avr-gcc) with avr-g++.
Then I inserted math.h into delay.h and it got a bit further, but was then complaining about missing stuff in math.h line 426.
Maybe something is not quite ok.
madworm
PostPosted: Mar 07, 2011 - 06:42 PM
Rookie
Hmmm.
It seems that with this version, I need to explicitly include 'math.h' before including 'util/delay.h' - in every file of code (using avr-g++). Very odd. But now I know about it Wink
bperrybap
PostPosted: Mar 07, 2011 - 06:50 PM
Resident
Ooooooo.
Well, I've been very active lately with <util/delay.h> and contributed to the latest version.
The latest version has some rounding capabilities and thats where those functions come in.
Normally, they are builtins for the compiler.
I'll have to go back and have a look (and a think) about how to deal with the additional
needs for the functions when using C++ in particular to see if it is a C++ thing or
just the Arduino IDE.
--- bill
Bingo600
PostPosted: Mar 07, 2011 - 07:38 PM
@Bill
I use the new avr-libc-1.7.1 , could that be it ?
/Bingo
Bingo600
PostPosted: Mar 07, 2011 - 07:45 PM
You will have to apply those patches your self.
I'm only using "General releases" , as in "plain" avrdude 5.10.
The "specialities" you have to add Cool
/Bingo
madworm
PostPosted: Mar 07, 2011 - 08:09 PM
Rookie
Fair enough.
How about adding a note in the readme file? Only to prevent localized outbreaks of rage and destroyed keyboards.
My favourite: http://www.youtube.com/watch?v=ddkBMWafLSQ
Bingo600
PostPosted: Mar 07, 2011 - 08:15 PM
@madworm
But they have to get to this thread to download the script , and they'll see your comments Smile
I will (hopefully soon) use my time updating the .deb packages on cliff's site , with new packages containing avr-libc-1.7.1.
Provided that Bill/Jörg can verify that the above math.h problem , isn't a problem ....
Edit: Just had a "hint" that the solution is to include <math.h> from within <util/delay.h">
/Bingo
madworm
PostPosted: Mar 07, 2011 - 09:07 PM
Rookie
Almost.
Adding 'math.h' to the deprecated <avr/delay.h> doesn't solve the issue. It must be added to <util/delay.h> directly - at least on my system. Then it works Wink
Bingo600
PostPosted: Mar 07, 2011 - 09:09 PM
@madworm
I think i corrected my prev. post from <avr/delay.h> to <util/delay.h> while you were writing the above.
/Bingo
madworm
PostPosted: Mar 07, 2011 - 10:26 PM
Rookie
So it seems Cool
BTW, as I've filed the lack of ATtiny4313 support as a bug on openSUSE, people over there are quite interested in getting this thing up and running again as well.
Avrdude has been updated in the 'CrossToolchain:/avr' repositories already Wink
bperrybap
PostPosted: Mar 08, 2011 - 02:47 AM
Resident
Bingo600 wrote:
@Bill
/Bingo
Yes, I believe that the new delay code (which is actually much better BTW) is in 1.7.1
I haven't had time to look at this or test it yet
to see what the real issue is.
My assumption is that there is some missing C++ wrapper foo to get the compiler to recognize the builtin functions fabs() and ceil().
An interim solution is to disable the newer delay code and
revert back to the old delay code that used the delay loops.
To do that, turn on the define:
__DELAY_BACKWARD_COMPATIBLE__
--- bill
salixer
PostPosted: Apr 05, 2011 - 02:00 PM
Newbie
Hi, I've built this on an OpenSuse x86_64 machine and I'm getting this error:
In file included from globals.h:28,
from lcd.c:15:
/opt/avr/bin/../lib/gcc/avr/4.4.3/../../../../avr/include/util/delay.h: In function 'vfnInitLcd':
/opt/avr/bin/../lib/gcc/avr/4.4.3/../../../../avr/include/util/delay.h:229: error: __builtin_avr_delay_cycles expects an integer constant.
I've thought problems with delay.h should be fixed in this release or am I missing something?
clawson
PostPosted: Apr 05, 2011 - 02:39 PM
10k+ Postman
Are you building with optimization enabled?
salixer
PostPosted: Apr 05, 2011 - 02:46 PM
Newbie
Yes, I'm using "-O2". To get rid of the warning I have to "#define __HAS_DELAY_CYCLES 0", which seems to use the old code. See delay.h:
Code:
#elif !__HAS_DELAY_CYCLES || (__HAS_DELAY_CYCLES && !defined(__OPTIMIZE__)) || defined (__DELAY_BACKWARD_COMPATIBLE__)
Bingo600
PostPosted: Aug 11, 2011 - 06:37 PM
For programming a T4313 with avrdude 5.10 , you need to add this "text definition"
http://savannah.nongnu.org/file/4313.txt?file_id=22038
Just add it to avrdude.conf after the ATtiny2313 block. I assume you’re using version 5.10.
/Bingo
SprinterSB
PostPosted: Aug 11, 2011 - 07:02 PM
Posting Freak
from lcd.c:15:
The error says that there is a problem in your code: You are using a function from delay.h (we don't see which as your code is secret) with a delay that is not a constant.
Note that by hacking around this by using older delay routines you might avoid the error but get completely unusable delay times and probably drag in float arithmetic.
salixer
PostPosted: Aug 12, 2011 - 08:27 AM
Newbie
Hey, as you are saying this I've found the problem. In this function I'm using:
Code:
_delay_us(LCDSPI_DATA_DELAY);
while LCDSPI_DATA_DELAY in lcd.h is defined as:
Code:
#define LCDSPI_DATA_DELAY ((64 / (F_CPU / 1e6)) * 9)
