Binarus
PostPosted: Feb 07, 2011 - 07:53 AM
Wannabe
I just wanted to warn everybody to use the MOVHI instruction which is documented in the AVR32 architecture manual.
I have found that the assembler generates illegal / wrong opcodes when assembling this instruction. This is very hard to find, and that's the reason why I am posting this.
My configuration: AVR32 studio 2.6 as downloaded from atmel.com; support for UC3C added from within the welcome page; toolchain upgraded to the version from 2010-12-01 by using integrated update mechanism (look into the "Help" menu).
The problem seems to be solved when using MOVH instead. So we have a documented instruction which leads to wrong opcodes and unexplainable code behaviour and a non-documented instruction which seems to work.
Only Atmel knows why there are two instructions for the same purpose, the documented one of them getting assembled without any warning or error messages and nevertheless leading to illegal / wrong opcodes.
Binarus
hce
PostPosted: Feb 07, 2011 - 11:53 AM
Which device are you using? The movhi insn was added in architecture revision 2, e.g. -march=ucr2 when you compile with GCC. My guess is movh is a gas insn that will translate into the appropriate instruction for the arch.
Could you post some correct and wrong code?
Binarus
PostPosted: Feb 07, 2011 - 04:53 PM
Wannabe
I am using the UC3C0512C and have given that as target to the toolchain. The MCU info is:
Code:
Device information:
  Device Name                                   UC3C0512C
  Device Revision                               D
  JTAG ID                                       0x3200003f
  SRAM size                                     64 kB
  Flash size                                    512 kB
Processor configuration:
  CPU Revision                                  0
  Architecture Type                             0 (AVR32A)
  Architecture Revision                         3
  Memory Management Unit Type                   3 (Memory Protection Unit)
  Number of Entries in the IMMU                 1
  Number of Entries in the DMMU                 9
  Floating Point Unit                           Yes
  Java Extension                                No
  Performance Counters                          No
  OnChip Debug                                  Yes
  SIMD Instructions                             No
  DSP Instructions                              Yes
  Memory R-M-W Instructions                     Yes
  Number of Sets in the Instruction Cache       1
  Instruction Cache Line Size                   1 bytes
  Instruction Cache Associativity               Direct Mapping
  Number of Sets in the Data Cache              1
  Data Cache Line Size                          1 bytes
  Data Cache Associativity                      Direct Mapping
If you would like to reproduce please note paragraph 3 of my original post. From now on, I am relating to AVR32 Architecture manual rev B. (32000B–AVR32–11/07) which is quite old but seems to be the newest one.
Could you please explain what insn means? Is it short for instruction?
The MOVHI instruction is described at page 222 of the manual although even the description is wrong in itself (look at the syntax part: MOV (!!!) definitely should do other things than MOVHI, so syntax has to be movhi Rd, imm16 and not mov Rd, imm - sigh).
I have attached a project which makes it easy to reproduce the behaviour. Note the following part of the listing / elf:
Code:
MOVHI R12, HI (FINDME)
8000011a:   f9 bc          *unknown*
8000011c:   80 00          ld.sh   r0,r0[0x0]
8000011e:   d7 03          nop
which is generated by this harmless assembler code:
Code:
.pushsection .text
.global FINDME
.type FINDME, @function
FINDME:
.popsection
Obviously, f9 bc is NOT the opcode of the MOVHI instruction. According to the manual, the opcode should begin with fc. If it wasn't such serious it would be funny that the toolchain knows about the "unknown" opcode but generates it nevertheless...
As I already wrote, for getting correct code just replace MOVHI by MOVH.
Binarus
Binarus
PostPosted: Feb 16, 2011 - 07:16 AM
Wannabe
I have reported this to Atmel and got the answer that they will change the architecture manual accordingly.
On one hand, I appreciate that they confirmed the problem not being due to my stupidness; on the other hand, I am very disappointed that they obviously don't plan to change the assembler (as AND gcc-asm).
I really think the assemblers have to be changed so that they just throw an error when encountering a MOVHI instead of silently generating illegal / wrong opcodes.
Since my questions have been answered, the problem has been confirmed and the cause is clear, I am flagging this as solved.
Cheers,
Binarus
aboyapati
PostPosted: Feb 23, 2011 - 06:30 PM
Rookie
I never knew this! Tried a simple testcase:
asm("movhi r8, hi(16)");
return 1;
The compilation shows the opcode as f9... which in my opinion is illegal. movh works fine.
Thanks for the update Binarus.
Anitha
Binarus
PostPosted: Feb 24, 2011 - 01:23 PM
Wannabe
So now we know that avr32-gcc is also generating wrong / illegal opcodes. I hadn't tested this because I rarely have to use the inline assembler, but often have to write whole assembler modules contained in assembler source files.
Thanks for testing, Anitha!
Binarus
