EmpireJones
PostPosted: Jan 16, 2011 - 05:29 AM
Newbie
I'm trying to get AVR32 Studio to program a 32UC3C0512C via a JTAGICE mkII. I'm using the AT32UC3C-EK (Eval Kit).
I'm getting the following error when I try programming via AVR32 Studio:
Action failed due to mismatch between target and detected MCU.Detected part UC3C0512C differs from specified part UC3C0512CRevC
Any ideas? The part without "Revision C" isn't listed as an option in the JTAGICE mkII target's device list.
Thanks!
EmpireJones
PostPosted: Jan 16, 2011 - 05:39 AM
Newbie
I'm going to give the AVR32 2.7 beta a shot
EmpireJones
PostPosted: Jan 16, 2011 - 07:38 AM
Newbie
As far as I can tell, the beta fixed the issue. However, none of the examples for the AT32UC3C are available in the beta, so I can't actually test it fully (just tested reading, not writing).
How can I get these example projects on the 2.7 release?
sma
PostPosted: Jan 16, 2011 - 12:43 PM
Posting Freak
Go on the UC3C-EK atmel web page, download the board support package and use the standalone makefile in AVR32 Studio like described here: http://www.atmel.com/dyn/general/tech_d ... ily_id=607 [How to Compile the standalone AVR UC3 Software Framework in AVR32 Studio V2 ]
-sma
EmpireJones
PostPosted: Jan 16, 2011 - 05:22 PM
Newbie
Thanks! I downloaded ASF 2.2.2 and was able to program an example from there after building using the instructions that you referenced.
sma
PostPosted: Jan 17, 2011 - 08:59 AM
Posting Freak
Good Very Happy
samgm2
PostPosted: Apr 03, 2011 - 11:37 PM
Newbie
It took 2 hours to find this at
http://support.atmel.no/bin/customer.ex ... amp;id=994
edit the uc3c0512c.xml and change <part_name>UC3C0512C</part_name> XML field in <part_name>UC3C0512CREVC</part_name>. In that way AVR32Studio will recognize this part (UC3C0512C) has a known part (UC3C0512CREVC).
