| Author |
Message |
Posted: Nov 19, 2010 - 12:27 AM |
i am using codevision to write a program for a mega64.
in my definitions i used:
#define input PORTG.0
and then in the program i used:
if (input == 1)
do this do that etc
but when I compile it gives me an error sayin:
"the first argument of the '.' operator must be of 'struct' or 'union' type" and highlights the 'if' line which refers to the #define input line.
Is there something wrong with my syntax? How can I do this, what am I doing wrong?
searching the net, help files, data sheets hasn't really lead me anywhere so your help will be much appreciated.
Thanks |
Posted: Nov 19, 2010 - 12:35 AM |
Look up your PORTG<decimal>0 syntax in a C manual. The decimal point has a special meaning in C.
If you want to input from an AVR pin, use the PIN register, not the PORT register. Also use a different method of selecting pin 0. |
Posted: Nov 19, 2010 - 12:52 AM |
As far as I remember, the CodeVision's portName.pinNumber extension works only for the first 32 registers. PORTG is outside that area. Therefore you have to access it using standard C methods. For example:
#define input ((PORTG & (1 << 0)) != 0)
But as Mike says, make sure that PORTG is really what you want. You say "input", which means that you probably want PING, not PORTG.
Eugene |
Posted: Nov 19, 2010 - 01:04 AM |
thanks for that. that explains why the codevision picks up portg as an error and not ports a c and d which i also did using the same way.
Mike is also right I want to use PING0. Can I do that the same way as you mentioned:
also if you could please write this in binary, like #define input PING = ob_____ that will be a huge help for me to understand this better.
thanks a lot guys. knowledge gained!! |
Posted: Nov 19, 2010 - 01:09 AM |
yes that's right. I should really be using the PIN register. so thanks for that. When you say use a different method. What method could I used??
thank you |
Not sure what you mean exactly. Maybe this?
#define input ((PING & 0b00000001) != 0) |
Posted: Nov 19, 2010 - 01:23 AM |
thanks for that. sorry if i'm bein annoying... but from what I understand the above is exactly the same as:
#define input ((PING & (1 << 0)) != 0)
and what this does is it defines 'input' as PING0, ya??
cheers. thanks again. |
Posted: Nov 19, 2010 - 04:26 AM |
Yes.
What it does is give you the current value of bit 0 of the PING register. |
_________________ Regards,
Steve A.
Posted: Nov 19, 2010 - 10:56 AM |
