Jamiro14
PostPosted: Jul 19, 2012 - 06:09 PM
Hi.
I'm currently using a LCD with this driver, ILI9341 and I'm trying to interface it in 8080 16-bit mode.
Does anyone has a library or at least some initialization routine working?
Thank you.
PostPosted: Jul 19, 2012 - 07:24 PM
Its in the Atmel Software foundation! Must be a UC3 board with that controller.
PostPosted: Jul 19, 2012 - 11:50 PM
2nd hit on google https://bitbucket.org/fabienroyer/nwaze ... /ILI9341.c
PostPosted: Jul 20, 2012 - 07:44 AM
Actually it's working with SAM, UC3 and XMEGA controllers. The driver is designed to be SPI compatible only, but you can probably just alter the byte write routine for parallel interface writes.
Jamiro14
PostPosted: Jul 20, 2012 - 09:41 AM
Thank you for your answers, but I had already tried those libraries without success. Sad
I have no idea what I'm doing wrong. I have already used some LCDs in the past but this one doesn't want to do its job. Confused
PostPosted: Jul 20, 2012 - 10:15 AM
It's an absolute PAIN of a controller, it took me many iterations to get it to actually work. Have you checked the configuration lines to the controller to ensure its in the correct mode? Do you get any activity at all?
Jamiro14
PostPosted: Jul 20, 2012 - 10:47 AM
The only activity I'm getting is when i turn the backlight on. Laughing
When you say configuration lines you're talking about IM[0..3] pins right? I'm not sure as I only have access to IM0.
Right now I'm trying to convert the ASF library from serial to parallel. If I'm successful i'll post it here.
meslomp
PostPosted: Jul 20, 2012 - 11:46 AM
why not use serial to see if it works all together? then convert to parallel...
at this point you probably do not even know the display works at all....
and what controller are you actually using? that could also trigger more direct questions on you version of the code.
regards
2)tutorial forum
3)Newbie start here
Jamiro14
PostPosted: Jul 20, 2012 - 12:47 PM
I'm using an ATxmega 128A1 but I don't have access to the serial pins only the parallel ones, so I can't use serial to test if the display is working. Sad
PostPosted: Jul 20, 2012 - 01:04 PM
Yes, you need to know what the other IMx pins are connected to - otherwise the controller may be in a completely different state than what you think it is.
Jamiro14
PostPosted: Jul 26, 2012 - 04:20 PM
I've decided to use 8-bit mode instead of 16-bit, although I'm not seeing any interaction in both modes.
Is there anyone who has access to this LCD and can test my code? I'm not sure what I'm doing wrong. Thank you.
void TFT_WriteCommand(unsigned char commandToWrite )
   RD_HIGH;
   COMMAND_MODE;
   CS_LOW;
   WR_LOW;
   _delay_us(WAIT_TIME);
   LSB_PORT = commandToWrite;
   WR_HIGH;
   DATA_MODE;
void TFT_WriteData( unsigned char dataToWrite )
   RD_HIGH;
   DATA_MODE;
   CS_LOW;
   WR_LOW;
   LSB_PORT= dataToWrite;
   WR_HIGH;
void TFT_Init(void)
   // VCI=2.8V
//************* Reset LCD Driver ****************//
    //Hardware reset
   RST_HIGH;
   _delay_ms(200);
   RST_LOW;
   _delay_ms(200);
   RST_HIGH;
   _delay_ms(200);
   //Software Reset
   TFT_WriteCommand(0x01);
   CS_HIGH;
   _delay_ms(1000);
//************* Start Initial Sequence **********//
   //Power control A
   TFT_WriteCommand(0xCB);
   TFT_WriteData(0x39);
   TFT_WriteData(0x2C);
   TFT_WriteData(0x00);
   TFT_WriteData(0x34);
   TFT_WriteData(0x02);
   CS_HIGH;
   //Power control A
   TFT_WriteCommand(0xCF);
   TFT_WriteData(0XC1);
   TFT_WriteData(0X30);
   CS_HIGH;
   //Driver timing control A
   TFT_WriteCommand(0xE8);
   TFT_WriteData(0x85);
   TFT_WriteData(0x78);
   CS_HIGH;
   //Driver timing control B
   TFT_WriteCommand(0xEA);
   CS_HIGH;
   //Power on sequence control
   TFT_WriteCommand(0xED);
   TFT_WriteData(0x64);
   TFT_WriteData(0x03);
   TFT_WriteData(0X12);
   TFT_WriteData(0X81);
   CS_HIGH;
   //Pump ratio control
   TFT_WriteCommand(0xF7);
   TFT_WriteData(0x20);
   CS_HIGH;
   //Power Control 1
   TFT_WriteCommand(0xC0);
   TFT_WriteData(0x23);
   CS_HIGH;
   //Power Control 2
   TFT_WriteCommand(0xC1);
   TFT_WriteData(0x10);
   CS_HIGH;
   //VCOM Control 1
   TFT_WriteCommand(0xC5);
   TFT_WriteData(0x2B);
   CS_HIGH;
   //Memory Access Control
   TFT_WriteCommand(0x36);
   TFT_WriteData(0x48);
   CS_HIGH;
   //Frame Rate Control (In Normal Mode/Full Colors)
   TFT_WriteCommand(0xB1);
   TFT_WriteData(0x1B);
   CS_HIGH;
   //Display Function Control
   TFT_WriteCommand(0xB6);
   TFT_WriteData(0x0A);
   CS_HIGH;
   //Enable 3G
   TFT_WriteCommand(0xF2);
   CS_HIGH;
   //COLMOD: Pixel Format Set
   TFT_WriteCommand(0x3a);
   TFT_WriteData(0x05);
   CS_HIGH;
   //Gamma Set
   TFT_WriteCommand(0x26);
   TFT_WriteData(0x01);
   CS_HIGH;
   //Positive Gamma Correction
   TFT_WriteCommand(0xE0);
   TFT_WriteData(0x0F);
   TFT_WriteData(0x31);
   TFT_WriteData(0x0C);
   TFT_WriteData(0x0E);
   TFT_WriteData(0x08);
   TFT_WriteData(0x4E);
   TFT_WriteData(0xF1);
   TFT_WriteData(0x37);
   TFT_WriteData(0x07);
   TFT_WriteData(0x09);
   CS_HIGH;
   //Negative Gamma Correction
   TFT_WriteCommand(0XE1);
   TFT_WriteData(0x14);
   TFT_WriteData(0x11);
   TFT_WriteData(0xC1);
   TFT_WriteData(0x36);
   CS_HIGH;
   // Sleep Out
   TFT_WriteCommand(0x11);
   CS_HIGH;
   _delay_ms(120);
    //Display On
   TFT_WriteCommand(0x29);
   CS_HIGH;
void TFT_DrawPixel(uint16_t x, uint16_t y, uint16_t color)
   TFT_SetWindow(x, x, y, y);
   TFT_WriteData((unsigned char )((color>>8)&0xff));
   TFT_WriteData((unsigned char )(color&0xff));
   CS_HIGH;
void TFT_SetWindow(unsigned short x0, unsigned short y0,
               unsigned short x1, unsigned short y1)
   TFT_WriteCommand(ILI9341_CMD_COLUMN_ADDRESS_SET);
   TFT_WriteData((x0 >> 8) & 0xFF);
   TFT_WriteData(x0 & 0xFF);
   TFT_WriteData((y0 >> 8) & 0xFF);
   TFT_WriteData(y0 & 0xFF);
   CS_HIGH;
   TFT_WriteCommand(ILI9341_CMD_PAGE_ADDRESS_SET);
   TFT_WriteData((x1 >> 8) & 0xFF);
   TFT_WriteData(x1 & 0xFF);
   TFT_WriteData((y1 >> 8) & 0xFF);
   TFT_WriteData(y1 & 0xFF);
   CS_HIGH;
   TFT_WriteCommand(ILI9341_CMD_MEMORY_WRITE);
   CS_HIGH;
Jamiro14
PostPosted: Aug 03, 2012 - 11:19 AM
I've discovered my problem, it was a faulty LCD Shocked.
As promised here is a simple initialization and a draw pixel function in 8080 16-bit mode.
