Posted: Jul 11, 2012 - 03:44 PM |
want to know the pbobs in the code
// Using DTMF(Dual Tone Multiple Frequency) to check the password and
// then using the LEDs to indicate the no's entered.
#include<avr/io.h>
#include<util/delay.h>
#include"lcd.h"
#include"lcd.c"
void main()
int i;
DDRD=0xFF;
DDRC=0x00;
lcd_init(LCD_DISP_ON);
label_one;
lcd_puts("Enter Password");
// for checking the entered password.
while((PINC&15)!=5)
lcd_clrscr():
lcd_puts("Wrong password");
lcd_puts("5");
while((PINC&15)!=4)
lcd_clrscr();
lcd_puts("wrong");
goto label_one;
lcd_puts("4");
while((PINC&15)!=3)
lcd_clrscr();
lcd_puts("wrong");
goto label_one;
lcd_puts("3");
lcd_clrscr();
lcd_puts("Correct Password");
// for glowing the LEDs after pressing the no in mobile
for(i=0;i<13;i++)
while((PINC&15)==i)
PORTD=i;
_delay_ms(250);
Posted: Jul 11, 2012 - 04:01 PM |
What is connected to the bottom 4 bits of PORTC? It looks like it must be a keypad that actually returns a BCD code or something?
Anyway I suggest you research the topic "finite state machine" which would be a better way to implement this. |
Posted: Jul 11, 2012 - 04:09 PM |
Shirley, you read the inputted string / DTMF tones and compare it with the password. Then pass or fail
You don't tell the user what the password should be.
You probably only maintain the last 3 digits received. e.g. char digits[3];
As a new digit arrives, you shift the existing ones to make room. Then compare with memcmp(digits, password, 3).
Posted: Jul 11, 2012 - 04:40 PM |
yes, the bottom 4 bits of PORTC are conneced to the output of DTMF circuit |
Posted: Jul 11, 2012 - 04:44 PM |
I only want to check the the password here which is 432.If the password is correct then only the no's entered by the caller are obtained on the LEDs.This is the aim and I am not getting what u want to tell. |
Posted: Jul 11, 2012 - 04:46 PM |
As it stands if I start pressing 0/1/2/3.. then when I press 5 the display switches from "Wrong password" to "wrong" so I am left in no doubt that the first digit is 5. Not a great idea.
BTW are you sure the device really outputs BCD on 4 pins? |
Posted: Jul 11, 2012 - 05:27 PM |
Yes, DTMF chips will output the BCD on 4 pins.
No, I can't see that the code is going to be difficult to crack.
You could possibly set off alarms, fire guns, drop nets, ... when the burglar enters a wrong number.
The normal procedure in films is scary music with loud heartbeats.
Posted: Jul 12, 2012 - 04:03 AM |
So can you tell what should i do instead of that?? |
Posted: Jul 12, 2012 - 05:58 AM |
First: In dtmf receiver there is a pin which indicates that the next number is on the output.
You have to watch it.
It is named NUM_CHANGED and supposed active high in the code. After a delay this bit goes back to LOW.
The code is not tested.
#define NUM_CHANGED 5 // pinc.5
char password[10];
uint8_t i;
for (i=0; i<4; i++)
loop_until_bit_is_set(PINC,NUM_CHANGED);
password[i] = (PINC & 15) + '0'; // save as ascii
loop_until_bit_is_clear(PINC,NUM_CHANGED);
password[i+1] = 0; // terminate string
if (strcmp(password, "5432") == 0)
lcd_puts("Wrong Password");
Posted: Jul 12, 2012 - 06:41 AM |
password[i] = 0; // terminate string
Posted: Jul 12, 2012 - 06:54 AM |
sternst:
For an unknown reason I had an illusion that i=3 after the for loop.
Thanks. |
Posted: Jul 12, 2012 - 11:41 AM |
Thank you all for your efforts.
But i have simply a dtmf ckt containing the dtmf decoder IC, so i just want to check that the entered password is 432 otherwise it would show "wrong password" and if the password is correct then i want to knowthe digits entered by the caller using led.
As i m new to avr so want your help in determining the faults or the cons in the code that i have written above.
Thnks |
Posted: Jul 12, 2012 - 12:06 PM |
You appear to have rushed into implementation without stopping to consider the design first. You really need a clear picture of how you want this to operate before attempting to write the code.
Visovian has told you that the DTMF chip also has an output to say "new digit typed" (his NUM_CHANGED) so that is going to be key to your design (rather than just sitting in while loops repeatedly rereading the last digit typed). It's also been pointed out that you probably want to buffer the digits as they are typed. The user may well know the password is 432 but suppose they start typing 433 then realise they have made an error - then what? There is no concept of a "go back" key so if the password really is going to be 3 digits long then you need to keep a copy of the last 3 digits typed. The user who typed 433 can now just go on and type 432 and as they do that the 3 digits held will be 433 then 434 then 343 then 432 and they are in. But something else you may also want to consider is exactly how many attempts are you going to give them? If you don't limit it they could just type 000001002003004..998999 and at some point they would break in. So you might want to give them the chance to type maybe 6 or 8 digits and then, if they haven't got the PIN number in that (which is enough digits to correct an error), then you maybe wait for N seconds before allowing them to type again (for this you would need some kind of user feedback like a red LED or something to say "you are locked out and I'm not listening" - maybe an LCD message?)
Only once you have followed this kind of process (and there's probably other design considerations I haven't thought of above yet) can you then say: "This is how it's got to work". Then you are in a position to start writing some C code to actually implement the design you have come up with. Of course the implementation may have bugs and there may be one or two things you still haven't thought of that only come to light when you start to use what you implement but you then think about (that's very important!) then fix/change those things.
So a few things you need are a loop that doesn't even do anything else but wait until the chip has told you that another digit has been typed. A "rolling" buffer that holds the last 3 or 4 digits typed. Possibly a "lock out" to prevent multiple attempts in a short space of time. A conversion of the binary digits into ASCII for display on the user interface.
Visovian has shown you the basis of something that already has some of these elements but think out the big picture of how everything will work first, then put all the pieces together.
Your code that just sits in while() loops waiting for digits to change is not great. Suppose you actually want to set the PIN to be 339 - how would that work in your current scheme if you don't use the NUM_CHANGED mechanism?
EDIT: terrible typos! |
Posted: Jul 12, 2012 - 12:58 PM |
Absolutely
This is fundamental to any form of software development - no just the AVR.
(actaully, applies to any form of development work - not just software)
A State Machine (aka Finite State Machine, FSM) has already been suggested as an appropriate approach. |
Posted: Jul 13, 2012 - 01:19 PM |
Thnx
i would try to implement all the suggestions. |
