Posted: Jul 09, 2012 - 10:41 PM |
Hello everybody, I am using aATtiny25 and have a problem to change a value of a symbol with the .SET assembler directive. It says in the manual that i can change the value at any time in the program code, but it dosen't, and when i assembler the code in the AVR studio4 it dosen’t give any errormessage either.
For example:
mov r16, r5
sbrc r16, 2
rjmp Skift
.SET P_long = 1
.SET P_kort = 2
rjmp Outskift
Skift:
.SET P_long = 2
.SET P_kort = 1
Outskift:
sbis pinb, P_long
rjmp long
sbis pinb, P_kort
rjmp kort
The purpose is to change the input-pins when bit 2 in r16 change status.
It is always the last .set who sets the value of the variables.
I would be greatful if i could have some help to solve this problem because I am stucked here.
/Rapnaza |
Posted: Jul 09, 2012 - 11:03 PM |
| .SET is an assembly time assignment, not runtime. It works regardless of the program flow and just silently overwrites the previous assignment. Do not use it at all because 1) you do not understand how it works and 2) you do not need it to get your scenario working properly. |
Posted: Jul 09, 2012 - 11:10 PM |
For example:
mov r16, r5
sbrc r16, 2
rjmp Skift
.SET P_long = 1
.SET P_kort = 2
rjmp Outskift
Skift:
.SET P_long = 2
.SET P_kort = 1
Outskift:
sbis pinb, P_long
rjmp long
sbis pinb, P_kort
rjmp kort
/Rapnaza
The Assembler just assembles. It does not follow your program flow.
So P_long is always going to be 2 in your sbis statement.
If you want different behaviour, you need to have :
rjmp Skift
Outskift:
sbis pinb, 1
rjmp long
sbis pinb, 2
rjmp kort
Skift:
sbis pinb, 2
rjmp long
sbis pinb, 1
rjmp kort
If you want your skips to change at run time, you must put the value of PINB into a register and test a mask.
Posted: Jul 09, 2012 - 11:19 PM |
| Okey, thanks for the answers. Is there another whay to change the variable value to achive my purpose to change the pins? |
Posted: Jul 09, 2012 - 11:45 PM |
There are several ways. David's is the simplest and most direct.
To set a port pin, you can read the port, OR the desired pin mask with the port value, and write it back. To clear a port pin, read the port, AND the complement of the desired pin mask with the port value, and write it back.
On newer chips you can toggle a port pin in PORTx by writing to the PINx register.
Jim |
_________________ Jim Wagner
Posted: Jul 10, 2012 - 07:58 AM |
rjmp Skift ;2
Outskift:
sbis pinb, 1 ;
rjmp long
sbis pinb, 2
rjmp kort
Skift:
sbis pinb, 2 ;2
rjmp long
sbis pinb, 1 ;1
rjmp kort ;2
Untested
Skift:
ldi r19, 0b00000110 ;1 flip test bits 1,2
rjmp any ;2
OutSkift:
ldi r19, 0b00000000 ; regular
any:
in r18, pinb ;1
eor r18, r19 ;1 change bits or not
sbrs r18, 1 ;2
rjmp long
sbrs r18, 2 ;1
rjmp kort ;2
Quite honestly, the boring first solution looks efficient, uses no registers.
There are many ways of doing this. e.g. mask and branch, use T bit, ...
In practice, saving a couple of cycles is seldom important. Clear bug-free code is far more important.
Posted: Jul 10, 2012 - 09:05 AM |
Okey, thanks Jim and David again for your advice.
But clearly I havent described my problem properly. I have apparently entered the wrong expression to this topic, the purpose is to swap (sorry not change) the input pins in the beginning of the program code so I could use the swap function further down in the program, that is why I would like to change the value in the variable because then I dont have to add the extra code that David gave me as an example.
/Rapnaza |
Posted: Jul 10, 2012 - 09:14 AM |
If you want to map pins at run-time, you can use a look-up table or a set of masks or several other methods.
I am a believer in keeping regular human logic, and writing all your functions in these terms.
You only need to map your hardware layout when you read a port, and remember to write any results back to the mapped pins.
Posted: Jul 10, 2012 - 10:33 AM |
Yes David, but it still reminds me of the .SET directive.
The .SET directive can be overridden by a later .SET in the program unlike and differ from the .EQU directive as it says in the manual.
I still don’t get it when can I use this .SET directiv then?
/Rapnaza |
Posted: Jul 10, 2012 - 10:45 AM |
| .set is something that happens on you PC while the program is being assembled. It has nothing to do with what happens inside the AVR when it is running. If you want variables that change at runtime then use one of the 32 machine registers or some location in SRAM . |
Posted: Jul 10, 2012 - 11:06 AM |
THANK YOU clawson, this calmed my curiosity and replied to my question.
Best Regards
/Rapnaza |
Posted: Jul 10, 2012 - 11:41 AM |
Well to be honest I didn't really say anything more than:
so you already had the answer in the first response. |
Posted: Jul 10, 2012 - 12:07 PM |
Well it my be so, but after all discussion with Jim and David and you at the end repeated the first response but in a more understanding way in your latest post. I finaly understod how it should be. Thanks again and also a big THANKS to Jim and David who helpt me in this topic.
Best Regards
Rapnaza |
Posted: Jul 10, 2012 - 03:55 PM |
Perhaps you need to brush up on your Russian.  |
_________________ Larry
