mochi321
PostPosted: Jul 08, 2012 - 07:58 AM
I am working on an LED. I am now able to control the marquee of the LED. But when i want use switches to control the LED ,it doesnt respond according to the switches.
this is my code:-
int main( void )
DDRD = 0x00;
DDRB = 0xFF;
switch (PIND)
case '0x01':
PORTB = 0x01;
case '0xfe':
PORTB = 0x02;
case '0x04':
PORTB = 0x04;
case '0x08':
PORTB = 0x08;
case '0x10':
PORTB = 0x10;
case '0x20':
PORTB = 0x20;
case '0x40':
PORTB = 0x40;
case '0x80':
PORTB = 0x80;
default:
PORTB = 0x00;
Can anyone help to figure out what is wrong with the code please?
i am using STK500 and ATMEGA168 to do the work.
larryvc
PostPosted: Jul 08, 2012 - 08:21 AM
Your program falls right out the bottom with the return 0; statement and terminates. You need to enclose your switch and case statements within a while loop. Even then it will not work as coded.
Larry
PostPosted: Jul 08, 2012 - 08:24 AM
this is my code:-
int main( void )
    DDRD = 0x00;
    DDRB = 0xFF;
switch (PIND)
   case '0x01':
         PORTB = 0x01;
   case '0xfe':
         PORTB = 0x02;
   case '0x04':
         PORTB = 0x04;
   case '0x08':
         PORTB = 0x08;
   case '0x10':
         PORTB = 0x10;
   case '0x20':
         PORTB = 0x20;
   case '0x40':
         PORTB = 0x40;
   case '0x80':
         PORTB = 0x80;
   default:
         PORTB = 0x00;
The switch() statement normally uses a break; between every case clause.
The case takes a numeric value like 0x41 or 'A'.
'0x41' is not a valid expression.
It you trace your program by hand, you will see that for any value of PIND it will end up with the default case. i.e. all LEDs on.
Also note that your fingers will struggle to achieve any value like 0x80. You need to press all the switches SW0..SW6 while starting your program.
A pressed switch is 0 and not 1.
You normally use 'internal pull-ups' on a pin that is connected to a switch. The STK500 already has some external pull-ups (I think).
If you put the switch inside a while () loop, it will work continuously. Your program just reads the value of PIND at program start-up.
mochi321
PostPosted: Jul 09, 2012 - 08:47 AM
Hi David, I follow your suggestion to write this code is
int main( void )
    DDRD = 0x00;
    DDRB = 0xFF;
switch (PIND)
   case 'FE':
         PORTB = 0x01;
   case 'FD':
         PORTB = 0x02;
   case 'FA':
         PORTB = 0x04;
   case 'F8':
         PORTB = 0x08;
   case 'EF':
         PORTB = 0x10;
   case 'DF':
         PORTB = 0x20;
   case 'AF':
         PORTB = 0x40;
   case '8F':
         PORTB = 0x80;
   default:
         PORTB = 0xff;
$ Fixed CODE tags - JS $
but it still doesn't respond according to the switches.
Can you help to figure out what is wrong with the code or would it be possible for me to have some sample code from you please?
snigelen
PostPosted: Jul 09, 2012 - 08:55 AM
Did you get any warnings?
Try something like this:
   switch (PIND)
   case 0xFE:
       PORTB = 0x01;
   case 0xFD:
       PORTB = 0x02;
PostPosted: Jul 09, 2012 - 09:06 AM
mochi321 please use the CODE button when posting code, I have fixed the post above.
mochi321
PostPosted: Jul 09, 2012 - 09:23 AM
For snigelen
I get the warnings to following:
../LED_switch.c:12:9: warning: character constant too long for its type
../LED_switch.c: In function 'main':
../LED_switch.c:12: warning: case label value exceeds maximum value for type
../LED_switch.c:15:9: warning: character constant too long for its type
../LED_switch.c:15: warning: case label value exceeds maximum value for type
I try your suggestion ,but i get the same result.
thygate
PostPosted: Jul 09, 2012 - 09:31 AM
For snigelen
From those warnings it is clear you did not remove the quotes.
Lose the quotes, you cannot compare strings in a switch statement anyway.
single quotes are used for single characters, double quotes for strings. You want a numeric value that you represent in hexadecimal, so only use the 0x prefix.
change
case 'FE':
to
case 0xFE:
as was explained by David, and repeated by snigelen.
PostPosted: Jul 09, 2012 - 10:01 AM
For snigelen
Did that not make you wonder "why is it telling me that the character constant is too long?". Did it not prompt you to take a look at your C manual and find out how to specify integer constants. All these are valid (in GCC)
1
0b1011
037
0x4F
'A'
'\r'
While none of these are
4F
'hello'
'FA'
'037'
'0x47'
If you don't understand why this is it's time to hit the books and brush up on some fundamentals of C programming.
Anyway it seems like madness to try and act on all 8 bits of PIND at once. You are likely only interested in whether one button (one bit) is set or clear at any one time so I'd do something like:
uint8_t switch;
switch = PIND;
if (switch & (1<<0)) {
  // do stuff for button 0 being pressed
if (switch & (1<<1)) {
  // do stuff for button 1 being pressed
if (switch & (1<<2)) {
  // do stuff for button 2 being pressed
if (switch & (1<<3)) {
  // do stuff for button 3 being pressed
etc.
For the STK500 where the buttons are active low then you would actually invert that using C's NOT operator:
switch = PIND;
if (!(switch & (1<<0))) {
if (!(switch & (1<<1))) {
if (!(switch & (1<<2))) {
if (!(switch & (1<<3))) {
etc.
I wouldn't have said that either a switch()/case or if()/else if()/else if() construct would be appropriate here as you might want to act on the fact that both button 0 and button 3 are both pressed. Those two constructs tend to imply you are only willing to consider one of the 8 buttons being pressed.
mochi321
PostPosted: Jul 09, 2012 - 11:00 AM
My revised code:
int main( void )
    DDRD = 0x00;
    DDRB = 0xFF;
switch (PIND)
   case  0xFE:
         PORTB = 0x01;
   case  0xFD:
         PORTB = 0x02;
   case  0xFA:
         PORTB = 0x04;
   case  0xF8:
         PORTB = 0x08;
   case  0xEF:
         PORTB = 0x10;
   case  0xDF:
         PORTB = 0x20;
   case  0xAF:
         PORTB = 0x40;
   case  0x8F:
         PORTB = 0x80;
   default:
         PORTB = 0xff;
the code don't has any error and warning,
but it doesn't respond according to the switches.
PostPosted: Jul 09, 2012 - 11:20 AM
    DDRD = 0x00;                // switches are input
    PORTD = 0xFF;               // internal pull-ups on switches.
    DDRB = 0xFF;                // LEDs are output
    while (1)                   // loop forever
        switch (~PIND)          // human readable switches
        case 0x01:
            PORTB = ~0x01;      // active-low LEDs
        default:
            PORTB = ~0x00;      // active-low
It takes a little while to get your head around active-low. Personally, I just work in human, and then invert the result when I write to the PORT.
Likewise, I read the switches and turn them into human (with the ~ operator).
Note that you can read several switches at a time as a separate case. i.e. all 256 possible finger combinations of the 8 push-buttons.
If you just want to consider switches as 8 different combinations, you use the if ((PIND & 0x01) == 0) style.
Again, I would use a human_switch = ~PIND variable.
Then you can use if (human_switch & 0x01) ...
danni
PostPosted: Jul 09, 2012 - 12:09 PM
But it's an impossible task to press two keys simultaneous from the CPU view Exclamation
Since no human was able to press both within the same microsecond or so.
Thus CPU see always a single press at first.
Also testing only a single bit would be smaller and faster code, since then the compiler can use the bit instructions (SBIS, CBIS).
Peter
PostPosted: Jul 09, 2012 - 12:13 PM
Eh? On my STK500 I can happily hold down 3/4/5 of the buttons at the same time? In fact if I really tried I reckon I could hold down all 8 at the same time.
EDIT: no I tried it about 7 is the most I can press at once as need a finger/thumb to grip the STK500 board itself while I'm trying to do this.
danni
PostPosted: Jul 09, 2012 - 01:01 PM
I meant not the pressed state.
I meant the moment, when the key was closed.
The CPU see at first only a single key press, then two, then three and so on.
Since you can not press all keys at the same time.
There are several milliseconds difference.
Peter
PostPosted: Jul 09, 2012 - 01:03 PM
Yeah but OP is sitting in a while() loop polling PIND. My contention is that on any of the reads of PIND either 0 or 1 or 2 or 3 or 4 or 5 or 6 or 7 or 8 buttons may be found to be pressed. If the code processing that PIND reading just handled the first button it found pressed and stopped it would miss the fact that others were also being held.
mochi321
PostPosted: Jul 09, 2012 - 01:11 PM
For David
I try your code,but it still doesn't respond according to the switches.
so I maybe to try "if" to revised the code
PostPosted: Jul 09, 2012 - 01:41 PM
Oops. I should have tested the code that I posted.
        switch (~PIND & 0xFF)   // human readable switches
What happens with a straight ~PIND is that you get PIND extended to an int before the NOT is applied. Hence 0xFE is extended to 0x00FE and when inverted you get 0xFF01.
I am sorry for complicating matters. If you use an 'unsigned char' for the state of the switches:
    unsigned char human;
        human = ~PIND;          // don't need to worry about int extension.
        switch (human)          // human readable switches
        case 0x01:
        default:
danni
PostPosted: Jul 09, 2012 - 03:03 PM
mochi321 wrote:
For David
That's why you still not follow the suggestions to test only a single pin instead the whole byte. Crying or Very sad
Especially on the ATmega168 PORTB may be no fully accessible. Exclamation
And if accessible, then on the STK500 PB6,7 are routed to the XTAL1,2 connector.
Thus checking the bit was always the favoured way to read a key.
Peter
mochi321
PostPosted: Jul 10, 2012 - 08:37 AM
My code finally works!
Thanks everyone for your kind help, I greatly appreciate it.
My code is
        if (human == 0x01)
          PORTB = ~0x01;
         else if (human == 0x02)
         PORTB = ~0x02;
         else if (human == 0x04)
         PORTB = ~0x04;
         else if (human == 0x08)
         PORTB = ~0x08;
         else if (human == 0x10)
         PORTB = ~0x10;
         else if (human == 0x20)
         PORTB = ~0x20;
         else if (human == 0x40)
         PORTB = ~0x0F;
         else if (human == 0x80)
         PORTB = ~0x30;
         PORTB = ~0x3f;
PostPosted: Jul 10, 2012 - 09:00 AM
Your if else-if structure where you test for specific values with == is exactly the same as using switch - case - default.
If you use another variable, it means you can keep your human brain at room temperature:
    unsigned char human, leds;
        case 0x01:
            leds = 0x01;        // keep regular logic
        case 0x02:
            leds = 0x02;        // keep regular logic
        case 0x04:
            leds = 0x04;        // keep regular logic
        case 0x08:
            leds = 0x08;        // keep regular logic
        case 0x10:
            leds = 0x10;        // keep regular logic
        case 0x40:
            leds = 0x0F;        // keep regular logic
        case 0x80:
            leds = 0x30;        // keep regular logic
        default:
            leds = 0x3F;        // light 7 leds
        PORTB = ~leds;          // active-low for LED to light.
Note that you can easily change your PORT or active-high / active-low sense. You might also prefer showing which LED in a more intuitive way:
        case 0x80:
            leds = 0b00110000;  // keep regular logic
The 0b notation for binary constants is supported by avr-gcc but is not regular C.
mochi321
PostPosted: Jul 10, 2012 - 09:09 AM
I try this code,but it doesn't works.
I don't know what's wrong happen
PostPosted: Jul 10, 2012 - 09:23 AM
Just saying "I try this code,but it doesn't works" is not very helpful to you or your readers.
Please describe what you expected, and what you got.
I confess. I just wrote the example code, and never tested it in real-life.
I have just tried it, and it behaves as I expected. The STK500 has PORTB.6 and PORTB.7 on the PORTE/AUX header.
Oops. I forgot the 0x20 case. I leave this as an exercise for the reader.
mochi321
PostPosted: Jul 10, 2012 - 09:55 AM
sorry, i want expected when i try your code by using switch - case - default.
        case 0x01:
        case 0x02:
        case 0x04:
        case 0x08:
        case 0x10:
        case 0x40:
        case 0x80:
        default:
but it doesn't light up when i press the swithches
PostPosted: Jul 10, 2012 - 10:18 AM
Well, I connected PORTD to switches and PORTB to LEDs with the two 10-way ribbons.
With no buttons pressed, all 6 LEDs light up. LED0..LED5
Press SW0 and just LED0 lights
ditto for SW1 to SW5.
Press SW6 and LED0..LED3 light.
Press SW7 and LED4,LED5 light.
Do the switches light with no buttons pressed?
Did you copy-paste my code, or type it by hand?
