Jonathan87
PostPosted: Jul 05, 2012 - 02:59 PM
I am writing a triple axis motor control program and have run into some programming issues. In an attempt to clean up my code, I moved my incremental encoder coder to its own .h and .c file. When I call the function to read the encoder position it will only return an int, but not a long int. I am using quad counting for the encoder and need to use a long int since int will overflow. Any ideas on why this would occur? I am using Atmel Studio 6 to code and compile. I am using the ATMEGA328P.
I call the function using this:
long POS_X=Encoder_Read(1);
My library code is below:
/* encoder.h*/
#ifndef encoder_h
#define encoder_h
   #include <stdint.h>
   long Encoder_Read(int);
   long Encoder_Reset(int);
/*encoder.c  these are the functions for encoder.h*/
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include "encoder.h"
volatile uint8_t oldPosition=0;  // Initialize the old position as A=0, B=0.
volatile long IncPos_X=0;
volatile long IncPos_Y=0;
volatile long IncPos_Z=0;
 long Encoder_Read(int axis)
        switch(axis)
      case 1:
         return IncPos_X;
      case 2:
         return IncPos_Y;
      case 3:
         return IncPos_Z;
      default:
 long Encoder_Reset(int axis)
   IncPos_X=0;
   return IncPos_X;
   switch(axis)
      case 1:
         IncPos_X=0;
         return IncPos_X;
      case 2:
         IncPos_Y=0;
         return IncPos_Y;
      case 3:
         IncPos_Z=0;
         return IncPos_Z;
      default:
ISR(INT0_vect)
   PORTB ^= (1 << 5);
   uint8_t A = PIND & (1<<2);      // Read PD2 and set A equal to it
   uint8_t B = PIND & (1<<3);      // Read PD3 and set B equal to it
   uint8_t newPosition=A|B;      // Or A & B together to obtain the current values on the two interrupt pins
   switch(oldPosition)      // Based on the old position, determine if a step was made and if so, what direction
      case 0b00000000:                  // A=0, B=0
      switch(newPosition)
         case 0b00000000:            // No Change
         case 0b00001000:            // A=0, B=1 --> 1 tick CW (negative)
         IncPos_X++;
         case 0b00000100:            // A=1, B=0 --> 1 tick CCW (positive)
         IncPos_X++;//--;
         default:
      case 0b00000100:
      switch(newPosition)
         case 0b00000100:            // No Change
         case 0b00000000:            // A=0, B=0 --> 1 tick CW (negative)
         IncPos_X++;
         case 0b00001100:            // A=1, B=1 --> 1 tick CCW (positive)
         IncPos_X++;//--;
         default:                  // Default: Do not change the position
      case 0b00001000:
      switch(newPosition)
         case 0b00001000:            // No Change
         IncPos_X=IncPos_X;
         case 0b00001100:            // A=1, B=1 --> 1 tick CW (negative)
         IncPos_X++;
         case 0b00000000:            // A=0, B=0 --> 1 tick CCW (positive)
         IncPos_X++;//--;
      case 0b00001100:
      switch(newPosition)
         case 0b00001100:            // No Change
         case 0b00000100:            // A=1, B=0 --> 1 tick CW (negative)
         IncPos_X++;
         case 0b00001000:            // A=0, B=1 --> 1 tick CCW (positive)
         IncPos_X++;//--;
   oldPosition=newPosition;               // Set the oldPosition equal to the new position
Jonathan
PostPosted: Jul 05, 2012 - 03:09 PM
How do you know it's not returning long? IOW how are you observing this? I think it may be whatever tool you use to make the observation that's in error not the code itself. Also study the .lss, does it return 2 or 4 registers?
PostPosted: Jul 05, 2012 - 03:15 PM
As a test I built this:
__attribute__((noinline)) long Encoder_Read(int axis)
   switch(axis)
      case 1:
      return IncPos_X;
      case 2:
      return IncPos_Y;
      case 3:
      return IncPos_Z;
      default:
long POS;
   POS = Encoder_Read(1);
and got this:
00000092 <Encoder_Read>:
   switch(axis)
  92:   82 30          cpi   r24, 0x02   ; 2
  94:   91 05          cpc   r25, r1
  96:   79 f0          breq   .+30        ; 0xb6 <Encoder_Read+0x24>
  98:   83 30          cpi   r24, 0x03   ; 3
  9a:   91 05          cpc   r25, r1
  9c:   a9 f0          breq   .+42        ; 0xc8 <Encoder_Read+0x36>
  9e:   81 30          cpi   r24, 0x01   ; 1
  a0:   91 05          cpc   r25, r1
  a2:   d9 f4          brne   .+54        ; 0xda <Encoder_Read+0x48>
      case 1:
      return IncPos_X;
  a4:   40 91 68 00    lds   r20, 0x0068
  a8:   50 91 69 00    lds   r21, 0x0069
  ac:   60 91 6a 00    lds   r22, 0x006A
  b0:   70 91 6b 00    lds   r23, 0x006B
  b4:   13 c0          rjmp   .+38        ; 0xdc <Encoder_Read+0x4a>
      case 2:
      return IncPos_Y;
  b6:   40 91 64 00    lds   r20, 0x0064
  ba:   50 91 65 00    lds   r21, 0x0065
  be:   60 91 66 00    lds   r22, 0x0066
  c2:   70 91 67 00    lds   r23, 0x0067
  c6:   0a c0          rjmp   .+20        ; 0xdc <Encoder_Read+0x4a>
      case 3:
      return IncPos_Z;
  c8:   40 91 60 00    lds   r20, 0x0060
  cc:   50 91 61 00    lds   r21, 0x0061
  d0:   60 91 62 00    lds   r22, 0x0062
  d4:   70 91 63 00    lds   r23, 0x0063
  d8:   01 c0          rjmp   .+2         ; 0xdc <Encoder_Read+0x4a>
  da:   03 c0          rjmp   .+6         ; 0xe2 <Encoder_Read+0x50>
      default:
  dc:   34 2f          mov   r19, r20
  de:   25 2f          mov   r18, r21
  e0:   cb 01          movw   r24, r22
  e2:   63 2f          mov   r22, r19
  e4:   72 2f          mov   r23, r18
  e6:   08 95          ret
As you can see in the three case:'s four registers are loaded then the routine ends with a bit of jiggery-pokery to arrange for the result to be in the ABI registers R25..R22.
That sure looks like returning a "long"!
This was built in AS6 with the default compiler (4.6.2)
BTW there does seem to be a missed optimisation here - why can the compiler not simply load direct to the ABI return registers?
