Post new topic   This topic is locked: you cannot edit posts or make replies.
rayhall
PostPosted: Jul 03, 2012 - 10:33 AM
I am using the Mega168 at 8 MHz, with Timer2 as PWM. Mode 2 (CTC OCRA Immediate) is begin used, to produce a PWM from 10hz to 500hz. I get no output on pin PD3.
Ray.
    DDRD |= (1 << DDD3);   // PD3 OC2B
   ASSR = 0x00;
   OCR2A = 125;
   OCR2B = 100;
   TCNT2 = 80;
   TCCR2A = (1<<COM2B1) | (1<<COM2B0) | (1<<WGM21);  // CTC OCRA Immediate
   TCCR2B = (1<<CS20) | (1<<CS21); // clk/32
   TIMSK2 = 0x00;
    sei(); // Enable Global Interrupts
MBedder
PostPosted: Jul 03, 2012 - 11:19 AM
Why? What for? Who will service it - your uncle or Uncle Sam?
sternst
PostPosted: Jul 03, 2012 - 11:48 AM
What exactly means "no output"? What output do you expect?
With your setup there will be only one single transition from low to high a short time after starting the timer, and then nothing more until you reset the controller.
Stefan Ernst
Kartman
PostPosted: Jul 03, 2012 - 12:53 PM
Ray, do you want pwm or variable frequency? If you want variable frequency, use the CTC mode.
Kartman
PostPosted: Jul 03, 2012 - 01:19 PM
try:
TCCR2A = (1<<COM2B0) | (1<<WGM21);
CTC mode with output toggle. You selected output high on match.
rayhall
PostPosted: Jul 03, 2012 - 10:10 PM
Smart Ass useless replys are part of the problem on this forum. If you have noting usefull to add, then go away.
Ray.
rayhall
PostPosted: Jul 03, 2012 - 10:11 PM
I want to vary the frequency from 10hz to 500hz. Duty will be 50% at all times.
Ray.
PostPosted: Jul 03, 2012 - 10:35 PM
The OP is Australian, so it is no likely to be Uncle Sam. My guess is Bob Very Happy
rayhall
PostPosted: Jul 03, 2012 - 10:45 PM
I asked for help, and now as usual I am being used for your entertainment. Will be sending this to Atmel to further complain about Atmel support.
Kartman
PostPosted: Jul 03, 2012 - 10:55 PM
Ray, you got your answer. Not even thanks for the effort i put in reading the datasheet for you. Maybe i should lodge a complaint at rayhall.support for poor manners.
PostPosted: Jul 03, 2012 - 11:16 PM
??? Now I'm >>way<< confused. If you wanted support directly from Atmel for your AVR question, why didn't you send it to Atmel directly instead of posting on an open forum? After all, your complaint will be going to the same email address, won't it?
As your original post has [nearly] all the stuff I'm looking for, and the sei() given the entire program is benign, our old friend MBedder must have been casting about for underlings to flog. Pay no attention. [The missing piece is the toolchain (and version) but that can be inferred.]
PostPosted: Jul 03, 2012 - 11:32 PM
I was mocking mbedder, not you.
PostPosted: Jul 03, 2012 - 11:54 PM
I'll lock this thread then, if Atmel supports wants to reopen it they can do so.
It's amazing that anyone is ready to try and help you with your attitude and the attitude you have shown in the past.
EW
PostPosted: Jul 04, 2012 - 12:04 AM
MBedder wrote:
No matter how the OP has acted in the past, please do not post snide remarks.
It is better to walk away and say nothing then to continue to add to the problem.
Eric Weddington
Marketing Manager
Open Source & Community
Atmel
PostPosted: Jul 04, 2012 - 09:27 AM
Hi Ray, I just received your support request ticket.
I'll respond later today once I have some time, but please keep in mind that this is a community forum of volunteers, thus while sarcastic responses are undesirable we aren't going to shut down the forums because they crop up occasionally.
