Posted: Jun 20, 2012 - 04:49 PM |
Hi i am new in c programming, and now i have a problem/question.
My ADC will only show 4092mV althoug i measure on the 5V VCC point, and i came down to that it has something to do with this line of code:
ADC_result = (ADC_result * (5000 / 1023));
Can it realy be right that i need to use a float/double as sub calculations to get the right result?
I am curretly running the code on a atmega16 and i would like to keep it simple and low on ressources |
Posted: Jun 20, 2012 - 05:01 PM |
| 5000/1023 = 4 using integer math. Using 50000/1023 and then dividing by the final result by 10 will get you closer. There is probably another ratio approach that will get you even closer without using float. |
_________________ Mr. Informer
Posted: Jun 20, 2012 - 05:58 PM |
| Or do the multiplication first
ADC_result = (ADC_result * 5000UL) / 1023;
(the parenthesis isn't really needed). |
Posted: Jun 20, 2012 - 06:48 PM |
| Thanks but think i use a double, its more precise. |
Posted: Jun 20, 2012 - 06:53 PM |
As you posted in GCC forum note that you are kidding yourself if you think avr-gcc has "double". It does not float==double=32bit IEEE754 which means you never get 64bit (16 decimal digits) floats but just 32 bit (6.5 decimal digit) numbers. This may or may not be an issue for you.
To be honest I don't know why you'd use float/double for this anyway. Surely ints are far tighter/faster and if you want to hold more accuracy scale them. |
Posted: Jun 20, 2012 - 07:01 PM |
This metod work even better than with a double:)
But how can it work, if i do the math 1023 * 5000 is 5115000, way more than ADC_result can represent as it is a unsigned int? |
Posted: Jun 20, 2012 - 07:08 PM |
| Notice the UL in 5000UL, it means that it's an unsigned long (32 bits in avr-gcc), so the calculation is done in 32 bit math, and when ADC_result * 5000UL is divided by 1023 the result fits in 16 bits. |
Posted: Jun 20, 2012 - 07:33 PM |
And floating point will be particularly useless if the result is cast to an int anyways. |
Posted: Jun 20, 2012 - 08:01 PM |
| Thanks, every new day is a day to learn. |
Posted: Jun 20, 2012 - 10:02 PM |
Also think about what "accuracy" and "precision" mean.
In this case, let me put it this way: You said "Thanks but think i use a double, its more precise." But that ignores the fact that you are starting with a 10-bit A/D value. In all likelihood you are losing a few bits of accuracy unless you have a squeaky-clean analog subsystem in your app. At most, no matter how many decimal places you print out from your "double" you still only have about three useful significant digits. You can print out 1.23456789 but that really represents about 1.23 +/-0.01. |
Posted: Jun 21, 2012 - 04:19 AM |
I hope you are aware that the ADC only has 10 bits of resolution, and unless you pay close attention to your AREF and your AVCC and your timing and de-coupling, you may actually get less than that.
So, an unsigned long has all the precision you will ever need for this application, and spending time with the floating point emulation does nothing but waste perfectly good CPU cycles. |
Posted: Jun 29, 2012 - 07:41 PM |
| Also, you should be dividing by 1024, NOT 1023. |
Posted: Jun 29, 2012 - 08:25 PM |
| Why? (ok it's cheaper). Isn't 1023 max?
octave:8> 5000*1023/1024
ans = 4995.1
octave:9> 5000*1023/1023
ans = 5000
Posted: Jun 29, 2012 - 08:46 PM |
| Because it's the correct equation. An ADC can't read full-scale Vcc value, which the wrong eq'n implies ( A 3 bit system would read to 7/8*Vcc, NOT 7/7*Vcc = Vcc for example ). 1023 is max COUNT, but there are 1024 STATES. It's always ( 2^N ) -1 / 2^N. |
Posted: Jun 29, 2012 - 08:51 PM |
Posted: Jun 29, 2012 - 09:38 PM |
theusch wrote:
In practice it >>usually<< doesn't matter much even when trying to get "good" ADC results:
I know. I just get a little pissed of when people that don't know that shout
NOT
Posted: Jun 30, 2012 - 05:36 PM |
No, you are wrong. Think of it as a pie. If the pie is cut into 8 pieces, and you have all 8 pieces, then you have 8/8's of a pie. But the pie has 9 "states" (0-8). With your logic, if you had all 8 pieces you would have only 8/9's of a pie. |
Posted: Jun 30, 2012 - 07:37 PM |
No, you are wrong. Think of it as a pie. If the pie is cut into 8 pieces, and you have all 8 pieces, then you have 8/8's of a pie. But the pie has 9 "states" ( 0-8 ). With your logic, if you had all 8 pieces you would have only 8/9's of a pie.
I don't know about your pie analogy ( made me hungry though ), but you don't have a '0' slice like you have a count of 0 for 0 volts ( Your 1st slice would have a cnt of 1, not 0. ). But if you built a 5V, 3 bit ADC you will not read, the count of 7 happens at ~4.3V, NOT ( my caps is for emphasis, NOT shouting ) 5V. Which is when it would hit 7 if you were right.
Edit: Steve, your pie only has 8 states, 0-7 with a max. cnt of 7 ! Now I need to go to Marie Callender's ! |
