Posted: Mar 26, 2001 - 04:06 PM |
We are shifting our development work to the avr-gcc compiler, and as part of that effort I have ported a medium size assembler application to the avr-as assembler (from the Atmel assembler). The main reason for this is that we have new libraries written in C which we have to integrate with the existing code. We are also under pressure to meet deadlines so rather than re-write the application from scratch, we are persisting with the port.
So far it looks good. We spent several days with the code and it now compiles clean under avr-as/gcc, plus I did the first test integrating C code and it works nicely. Note, 'main' function is written in assembler and the C functions are called from the assembler code. Our problem now is that I have not been able at any stage to get AVR-Studio to "see" our assembler or C source files when I try to simulate the code. In fact, when I load our object file, the only source file that AVR-Studio sees is the gcrt1.S run time startup file. I can simulate this, but as soon as I run off the end (step over the "jmp main") at the end, AVR-Studio does not step any more code, until the first timer0 interrupt brings it back to gcrt1.S. If I press the break button, and change to disassemly listing, I can step through the assembler code as normal. I still can't see any souce.
I have tried various fixes, including specifiying full paths in the makefile and source files (.includes ....). This did stop AVR-Studio from complaining that "some source files could not be found" and "Error in Nordic object file", but that it - still no source.
Any advice would be appreciated. The programming team here are pulling their hair out having to simulate at the disassebly level!
Cheers
Scott |
Posted: Mar 27, 2001 - 08:04 AM |
Are you aware of that the AVR studio is not capable of having the source in different paths? Also try to remove all AVR-studio related files and start over from scratch if you haven't done that ten times already :-)
/Bengt |
_________________ My favorites:
1. My oscilloscope, Yokogawa DLM2024.
2. My soldering iron, Weller WD2M, WMRP+WMRT.
3. JTAGICE mkII emulator and debugWire.
4. ImageCraft ICCAVR C compiler.
5. ATmega168
Posted: Feb 19, 2009 - 01:59 PM |
Does anybody know about the Atmel ATA2270-EK1?
im using it for a college project but i have no idea what output is coming from it- is it analog or digital or how many bits??! also how do i connect the main board to an 8051 microprocessor?
SOMEBODY PLEASE HELP ME!!! |
Posted: Feb 19, 2009 - 03:54 PM |
First, this thread is 8 years old.
Second, your post has absolutely nothing to do with the original post.
Third, there is plenty of documentation on it (including code) on Atmel's web site. |
Posted: Feb 19, 2009 - 07:32 PM |
| Forth, this is a cross post. There is another thread where the discussion is on-going. |
Posted: Mar 05, 2009 - 01:45 PM |
gee tanx for help, jus tryin get sum help ere if ya know anythin, then help if not then i hav no interest in wat u hav 2 say
this is a passive post..coz i dont give a donkeys boll*x |
Posted: Mar 05, 2009 - 07:08 PM |
| FYI, I wasn't posting to inform you that it was a cross post. I was posting to inform everyone else so that they don't risk wasting time posting in more than one thread. |
Posted: Mar 06, 2009 - 02:12 PM |
Posted: Jun 24, 2012 - 12:02 AM |
Scott Pitcher, I'm in that same boat with you. In my case, I'm converting a project that was originally done in a defunct (unsupported) IAR workbench to AVR. I've given up on doing it in AS6 IDE; too many hang-ups.
I'm re-buildng at the command-line. I've re-built the C files with avr-gcc to produce .o objects. However, I'm hung up on using avr-as for the one assembly source in the project.
If you or anyone has answers on how to use avr-as and avr-ld, please lend me a hand. I need to put this thing to bed.
Bolt |
Posted: Jun 24, 2012 - 03:59 AM |
His boat sailed more then 11 years ago, Mar 27, 2001. He is probably doing something more useful like growing vegetables.
May want to start a new thread in the AS5/6 forum. |
Posted: Jun 24, 2012 - 10:09 AM |
Porting C files from IAR to avr-gcc is fairly straightforward. There is a useful page: Porting From IAR to AVR GCC
IAR ASM syntax is only a question of changing a few directives.
However it probably makes assumptions for register usage that differs from the avr-gcc calling conventions.
Personally, I would re-write the ASM functions as C functions. Then only use avr-as if necessary. It is easier to just hand-optimise what the C compiler has generated.
Just quote which directives / sequences you have trouble with.
As js has suggested, a new thread is worthwhile. Your problem is not related the this thread's Subject Title !
