Posted: Jun 20, 2012 - 03:10 PM |
I find this almost amusing. So I took your code and built it and got the same errors you see. So I double clicked the first error to go to the source line involved and it says:
DDRC &=~((1<<PC0)|(1<<PC1)|(1<<PC2)|(1<<PC3)|(1<<PC4));// ADC i/p R,B,Y & Gnd, neutral
To be honest I cannot see anything wrong with that line so I do the natural thing and start to look back to a previous line where the actual error may be. I don't have to go very far before I get to:
DDRB |=(1<<PB0)//error occur
//set portC0-4 as i/p with pull up resistor
The comment even says "// error occur". Do you not see why? That line has no terminating semi-colon (just because it ends in a comment does not make the semi-colon statement terminator optional!)
After fixing that one the error that remains is:
else(adc_result[i]<690)//checking for 230V
I wonder IF you are missing some keyword in that line?
Having fixed those two lines the code compiles without error - of course there's no guarantee that it actually does what you hope when it runs!
You need to learn to do what I just did - when you get an error (or a warning - don't just ignore those) you need to take the line number given in the message and go to that line in the source (most IDE let you double-click on the message to get there). Then study the line that's been highlighted. Either it has an obvious error (like your second error here missing "if") or if the line looks OK the chances are the problem has actually occurred on a previous line (which can sometimes even mean in a #include'd .h file) and you have to look back through the code for anything that looks suspicious - like your missing semi-colon. |
Posted: Jun 21, 2012 - 08:47 AM |
So, you have...
1) A definition of F_CPU that is in the wrong place, or possibly redundant
and
2) Likely a missing semicolon somewhere above line 97 in protector.c |
Posted: Jun 21, 2012 - 08:59 AM |
how can i simulate this code with analog signal.
I want to know about the behaviour of the code?
#include <stdio.h>
//# define F_CPU 1000000UL //system clock @1MHz
//Global variable
int adc_result[5]={0,0,0,0,0};//for storing the adc out put
uint8_t ch=0;
uint8_t y=0;
uint8_t i=0;
int k=0;
/* PORT INIT */
void port_init (void)
DDRB |=(1<<PB1);//set portB.1 as output drive for relay
PORTB&=~(1<<PB1);//initially set 0 as o/p drive
DDRB |=(1<<PB0);//error occur
PORTC |=((1<<PC0)|(1<<PC1)|(1<<PC2)|(1<<PC3)|(1<<PC4));
//set up port D 0-4 as output
DDRD &=~((1<<PD0)|(1<<PD1)|(1<<PD2)|(1<<PD3)|(1<<PD4));//o/p led for R,B,Y and GLP
void init_adc(void)
ADCSRA |= ((1 << ADPS1) | (1 << ADPS0));// Set ADC prescaler to 8 - 125KHz sample rate @ 1MHz
ADCSRA |= (1 << ADEN); // Enable ADC
ADCSRA |= (1 << ADIE); // Enable ADC Interrupt
ADCSRA |= (1<<ADSC);//start conversion
while (!(ADCSRA & (1<<ADIF)));//wait for coversion to be completed
void init_glp(void)
i=ch;
ADMUX=ch;
init_adc();
adc_result[i]=ADCW;
i=ch;
port_init();
ADMUX=ch;
init_adc();
ADCSRA |= (1<<ADSC);//discarding the first adc result
// Loop Forever
ch=0;
init_adc();
if(ch<3)
for(ch=0;ch<3;ch++)
ADMUX=ch;
init_adc();
adc_result[i]=ADCW;
if (adc_result[i]>795)//checking for 265V
PORTD=y;//OV indication led on
_delay_ms(1);
init_adc();
adc_result[i]=ADCW;
while(adc_result[i]>810)//checking for 270V
do
PORTB|=(1<<PB1); // o/p drive ON
init_adc();
_delay_ms(1);
adc_result[i]=ADCW;
}while(adc_result[i]>795);
PORTD=0x00;//off the OV indicator led
PORTB&=~(1<<PB1);// o/p drive off
else if(adc_result[i]<690)//checking for 230V
do
PORTD|=(1<<PD3);// on the led corresponding to UV indication
init_adc();
adc_result[i]=ADCW;
}while(adc_result[i]<690);//checking for 230V
y++;
y=0;
else if((2<ch)&&(ch<5))
ch=3;
init_glp();
ch++;
init_glp();
k=(adc_result[4]-adc_result[3]);
if(k>30)//checking for 230V
PORTD|=(1<<PD4);//ON the led corresponding to GLP indication
_delay_ms(1);
ch=3;
init_glp();
ch++;
init_glp();
if(k>45)//checking for 15V difference
do
ch=3;
init_glp();
ch++;
init_glp();
}while(k>30);//checking for 15V difference
PORTD&=~(1<<PD4);//OFF the led corresponding to GLP indication
PORTB|=(1<<PB0);
Posted: Jun 21, 2012 - 09:16 AM |
| how can i make a stimuly file for above code? |
Posted: Jun 21, 2012 - 10:17 AM |
What did the user manual tell you?
(oh and just to be clear AS4.19 has the most advanced stimuli functionality ever produced by Atmel. AS5 and AS6 have not yet got the same functionality so you must use Studio 4.19 if you want to be able to write stimuli scripts). |
Posted: Jun 21, 2012 - 12:33 PM |
| how can i write write stimuli scripts? |
Posted: Jun 21, 2012 - 12:36 PM |
By following the guidance in the manual. It's what all other programmers trying to use the feature do too. Or did you want someone to read the manual out to you or something? This is the example shown in the manual - it even shows them faking values in to the ADC registers:
The example also shows use of logging and break directives.
// Initial delay
#100
// Set up logging ADC and ADCSRA to file adc.log
$log ADCL
$log ADCH
$log ADCSRA
$startlog adc.log
// start of repeat loop
$repeat 100
// Assuming TCNT1 is running, use as data for ADC
ADCL = *TCNT1L
ADCH = *TCNT1H
// Set ADIF flag in ADCSRA, this will trigger ADCC interrupt
ADCSRA |= 0x10
#30
$endrep
// Stop logging (close log file)
$stoplog
// break program execution
$break
Posted: Jun 21, 2012 - 12:43 PM |
Cliff! It seems it is time for following the new policy and just walk away.
Justin! Over several threads you have repeated more or less the same question. You have been given directions as to what to study, but we have seen no or little response or reaction to those advice. Instead a similar question is just posed again.
While it may not be so, it makes you come through as either lazy or spoiled or possibly both. In the past, such a situation might have led to "flaming" or harsch language. There is a new policy in place here at AVRfreaks which means that in such a situation there should be no flaming or harsh words, but rather that one should just walk away and not comment on the question(s) at all.
To be blunt: We are not here to spoon-feed you a solution. We are here because we are looking for interesting discussions, because we are genuinely interested in seeing other people learn how to solve AVR-related problems, or we might be here and answer just to rub our egos. Nothing in your threads fulfils any of those goals for anyone of us.
I will now walk away. |
Posted: Jun 21, 2012 - 12:49 PM |
| First thing that I saw was lots of calls to init_adc(). Seems like the a/d should just be initialized once at the top of the program. Then it looks like the actual reading of the a/d is sort of distributed all over with lots of redundancy. The concept of 'subroutine' is applicable here. Why not have one function called readadchan(n) that selects admux channel n, inits conversion, polls the adsc bit till it goes low, then returns the value of the a/d? Then you could even have another function called readadchannels() that calls readadchan(n) in a loop. Then your main loop would be something like a while(1) loop with a call to readadchans() and processadvalues(). That would be easier to format and indent because it would be shorter and simpler. Unlike this message. |
Posted: Jun 21, 2012 - 02:02 PM |
thanx Mr bobgardner for your answer and patience.
here is the my updated code
is it look to be a standared code? can we predicts its nature
#include <stdio.h>
//Global variable
uint16_t adc_result[5]={0,0,0,0,0};//for storing the adc out put
uint8_t ch=0;
uint8_t y=0;
uint8_t i=0;
int k=0;
/* PORT INIT */
DDRD &=~((1<<PD0)|(1<<PD1)|(1<<PD2)|(1<<PD3)|(1<<PD4));//o/p led for OV,UV and GLP
void init_adc(void)
void read_adc(void)
_delay_ms(1);
adc_result[i]=ADCW;
void init_glp(void)
i=ch;
ADMUX=ch;
read_adc();
adc_result[i]=ADCW;
void glp(void)
init_glp();
ch++;
init_glp();
i=ch;
port_init();
ADMUX=ch;
init_adc();
read_adc();
// Loop Forever
ch=0;
if(ch<3)
for(ch=0;ch<3;ch++)
ADMUX=ch;
read_adc();
if (adc_result[i]>792)//checking for 255V
PORTD|=(1<<PD0);//OV indication led on
_delay_ms(1);
read_adc();
while(adc_result[i]>823)//checking for 265V
do
read_adc();
}while(adc_result[i]>792);//Should be in the state off until voltage reaches under 255V
else if(adc_result[i]<621)//checking for 200V
read_adc();
while(adc_result[i]<495)// checking for 160V
do
read_adc();
}while(adc_result[i]<543); _delay_ms(1);
PORTD&=~(1<<PD3);//Off the UV indicator
i++;
ch++;
//GLP SECTION
ch=3;
glp();
if(k>22)//checking for 7V
_delay_ms(1);
ch=3;
glp();
if(k>22)//checking for 9V difference
do
ch=3;
glp();
}while(k>3);//Should be in the state off until voltage reaches under 7V
ch=0;
PORTB|=(1<<PB0);
________________________________________
Be keep patience to those who needs it.
Justin |
Posted: Jun 21, 2012 - 02:07 PM |
Change this:
adc_result[i]=ADCW;
For one thing you don't have to use ADIE to be able to use ADIF but if you do use ADIF then because it goes to 1 at the end you have to reset it. Using ADSC to determine when the conversion completes is a better idea as it automatically returns to 0.
to this
while ((ADCSRA & (1<<ADSC)));//wait for coversion to be completed
adc_result[i]=ADCW;
Posted: Jun 21, 2012 - 03:46 PM |
| I recommend that programs should be tested and debugged without the use of interrupts from the a/d and uarts. Using interrupts means you have to turn them on and off and write the interrupt handlers correctly and name the interrupt vectors correctly, and its just generally error prone for newer programmers. Interrupts are used to get better performance as the program gets bigger and slower. This program isnt there yet. |
Posted: Jun 22, 2012 - 11:20 AM |
thanx Mr.bobgardner
i update my code as
#define THRES_255V 792
#define THRES_265V 823
#define THRES_200V 621
#define THRES_160V 495
#define THRES_175V 543
#define THRES_9V 28
#define THRES_7V 22
#include <stdio.h>
//Global variable
uint8_t ch=0;
uint8_t y=0;
uint8_t i=0;
int k=0;
/* PORT INIT */
DDRB |=(1<<PB0);//error occur pin
void init_adc(void)
void read_adc(void)
i=ch;
_delay_ms(1);
adc_result[i]=ADCW;
void init_glp(void)
ADMUX=ch;
read_adc();
void glp(void)
init_glp();
ch++;
init_glp();
i=0;
i=ch;
port_init();
ADMUX=ch;
init_adc();
read_adc();
// Loop Forever
PORTD&=~(1<<PD0);//OV indication led off
if(ch<3)
for(ch=0;ch<3;ch++)
ADMUX=ch;
read_adc();
if (adc_result[i]>THRES_255V)//checking for 255V
_delay_ms(1);
read_adc();
while(adc_result[i]>THRES_265V)//checking for 265V
do
read_adc();
}while(adc_result[i]>THRES_255V);//Should be in the state off until voltage reaches under 255V
else if(adc_result[i]<THRES_200V)//checking for 200V
read_adc();
while(adc_result[i]<THRES_160V)// checking for 160V
do
read_adc();
}while(adc_result[i]<THRES_175V);
ch++;
//GLP SECTION
ch=3;
glp();
if(k>THRES_7V)
_delay_ms(1);
ch=3;
glp();
if(k>THRES_9V)
do
ch=3;
glp();
}while(k>THRES_7V);
PORTD&=~(1<<PD4);//off the led corresponding to GLP indication
ch=0;
PORTB|=(1<<PB0);// Error in microcontroller programming
ch=0;
Posted: Jun 22, 2012 - 11:22 AM |
is 1 MHz is the default system clock?
is i need to add any extra oscillator in my ciruit for setting system clock? |
Posted: Jun 22, 2012 - 11:46 AM |
It is. So if you haven't changed fuses that is likely the speed the AVR is running at. The reason you set that #define in the code is simply so that _delay_ms() and _delay_us() can have a good go at working out how many cycles to run for to delay for the given number of milli or micro seconds.
I cannot see anything else in your code that makes use of F_CPU. |
Posted: Jun 23, 2012 - 07:12 AM |
Posted: Jun 23, 2012 - 07:33 AM |
how can i...? how can i...? I am not trying to be rude or callous, but, how can we make you understand that there is a point that you will have to sit down and figure out some things on your own like everybody else here has done or is doing. Most of us here have a lot of patience and will go to extremes at times to help someone understand whatever it is they don't understand. There is a limit to that patience, and when we see that there is no initiative on the part of the person we are helping, then that patience ends.
Start to take the initiative and look things up on your own by using google, bing, baidu or whatever search engine you have access to. |
_________________ Larry
Posted: Jun 23, 2012 - 03:30 PM |
| I'd just like to see Justin write a small program that reads one a/d channel and prints the result in a loop. You can test it with a pot from 5V to gnd. Should see smooth change from 0x000 to 0x3ff. The next program could read 3 channels and print them out. At least give us a spec of what a glp is and what the R G and Y represent. Its like a puzzle. If you need design help, explain the requirements. If you want program debugging help, listen to the suggestions that the programmers post. If you need programming help, show us your whack at the read-an-a/d-channel-and-print-it-out program. |
Posted: Jun 25, 2012 - 11:40 AM |
| is a direct 5v ac can be supplied to adc pin of atmega series?is it need to be rectified? |
Posted: Jun 25, 2012 - 11:50 AM |
| Is that 5V AC with a 2.5V DC offset (so the entire wave is in the positive domain or is it centred at 0V so it +2.5V and -2.5V at the peaks? If the latter you are going to find your AVR does not like negative voltages (be ready with a butterfly net to catch the smoke cloud!). If the signal needs to be offset I think our sparky friends would advise the use of an op-amp. |
