Posted: Jun 07, 2012 - 04:12 AM |
jan_dc wrote:
Ross, I'm a strong believer of the principles of the "Darwin Awards" and I've absolutely no desire to reduce the possible errors in a probable design which I have to guess based on little information.
... and you are entitled to stay silent ... as we all are. But that would make for an awfully quiet forum. Some would say that would be a good thing; I happen to disagree.
jan_dc wrote:
For me there is sometimes a too high level of Hyacinth from "Keeping up appearences" (TV show from the BBC). If you know the show, I like to refer to things like this: http://www.imdb.com/title/tt0098837/quotes?qt=qt1517339
Yes ... an oldie and a goodie.
Ross |
ValuSoft
Melbourne Australia
Posted: Jun 07, 2012 - 05:08 AM |
Jan - you seem to confuse galvanic isolation with noise. Galvanic isolation doesn't necessarily isolate you from noise - in fact many fast transients can pass straight through. At DC, the isolation id near perfect but as the frequency rises, the isolation isn't that perfect as there is capacitance between the transformer windings. similarly with optocouplers. Having an isolated converter helps with having voltage drops due to high currents. consider two devices, both powered from the same source but separated by a significant length of wire. Let's say you get 4V of voltage drop across the 0V. With CAN, the 0V reference between the two devices would differ by 4V which might cause a problem. If there was some isolation involved, the voltage drop of the supply voltage would be immaterial and the 0V reference for both devices would be another conductor, but passing very little current in order that they share the same reference.
Further to my mention of the inter-winding capacitance of the dc dc converter transformer, this can couple the switching frequency into both sides of the converter so you need to shunt this with an external capacitor which further degrades any isolation at frequencies above DC. |
Posted: Jun 07, 2012 - 07:08 AM |
Well... I'm more in the low frequency business. The fastest ADC we use runs at 10SPS, others are 2SPS or even less. The microcontrollers all run at 1.8MHz and I'm going to experiment with a partial design running at 128kHz (with 16 bit ADC's, processing and bus communication). We've got more problems with oscillating opamps (oscillations lower than 1kHz) and with noise injection from one part to an other part depending on certain external parameters (yes, I'm vague). So I probably think of 'noise' in a different way. Anyway I understand the issues with HF things and that galvanic isolated DC-DC converters will not help there.
My point is: the OP wants to have 24V from batteries converted to 5V, I'm not seeing a question for isolating 2 different designs. Thus I fail to see any reason for isolation or even noise reduction at the battery side. Thus a 'normal' switching regulator would suffice. There are millions of reasons to use or not use DC-DC converters (aka galvanic isolated DC-DC converters) but that is out of the scope of the question from the OP.
I sometimes just miss focus in this forum. Sometimes it's good because then you can learn something new but most of the time it's filling pages with no information. |
Posted: Jun 07, 2012 - 07:32 AM |
I'm glad you disagree with that. There is no need for a quiet forum.
And I am not staying silent, I just believe in the problem solving capabilities of any human and that you need to learn from your mistakes.
If you have a question and I can give you an good answer (or at least I think it's a good answer) I'll do that. I'm not going to debate your question. Nor will I even try to understand the design behind that question unless it's explained.
In short: I like to help solving problems. But I am not responsible for the effect of solving that problem. I have no clue of the design behind that problem and for me it is very arrogant to think to know a design at it's possible flaws just by reading a post in a forum. Some posts are very patronizing. |
Posted: Jun 07, 2012 - 08:32 AM |
Jan,
The OP wanted to know the difference between a 'switching' and dc dc converter. I took that as being the difference between something like a buck or boost design vs a transformer isolated type. I sought to outline the differences. You wanted to know why you would want to use an isolated converter in a battery circuit. For the most part, one would probably use a non-isolated converter in a battery circuit. |
Posted: Jun 07, 2012 - 10:14 AM |
Kartman wrote:
Jan,
Euhm, actually the OP wanted to know which one is more efficient and what the advantage of an isolated DC-DC would be in his design. I can't read anything more than that and I see it more or less as "should I use a switching regulator as a 7605 replacement or a 24V to 5V (isolated) DC-DC converter". Maybe he didn't choose the correct words but that doesn't mean he's totally clueless.
My question was answer to the quite patronizing post from mbedder. And I am very happy that you gave an excellent and useful answer to my question. |
Posted: Jun 07, 2012 - 11:07 AM |
In my first post in this thread I intentionally stated "if you need isolation - use this, if you don't - use that". This was done to satisfy both the newbies and the stubborn asses like you, but haven't worked in your case because you decided to catch me and got stuck to me like a faggot. Please choose somebody else for your idiotic games - you're out of luck, I'm not one of them  |
Posted: Jun 07, 2012 - 02:22 PM |
| I could see the train wreck coming! Mbedder was faster in opening the can. |
Posted: Jun 18, 2012 - 08:56 PM |
DC to DC converter very use full for device are working at higher level from battery level
such as the battery power is 3V but the device voltage rate is 5V, then is will very use DC to DC converter,
and level isolated must be used when DC supply use for driving H-Bridge which screate double voltage at AC output from bridge, yes it requirement an isolated DC to DC converter, if you don't want to blown your uC controller for motor controler at same supply |
Posted: Jun 18, 2012 - 09:00 PM |
There may be a "language issue" here, but most of that last post seems meaningless.
Jim |
_________________ Jim Wagner
Posted: Jun 18, 2012 - 10:18 PM |
I think what the xxstreme means is that a DC/DC converter can be used to step up a low voltage to some more suitable, higher voltage for your widget (e.g. a single AA cell to 5V).
The last part seems to be about how isolating DC/DC convertors can be useful in H-Bridge/motor applications. |
Posted: Jun 18, 2012 - 11:03 PM |
| wrong post page, swt |
Posted: Jun 18, 2012 - 11:18 PM |
Posted: Jun 19, 2012 - 12:09 AM |
Where ids the OP?
here op op op
EDIT: just trying to cut through the noise |
