ka7ehk
PostPosted: Jun 12, 2012 - 07:53 PM
This may, at first, seem to be a generic c question, but what I wonder about is the actual implementation.
Suppose that you have an 8-bit hardware register, REG. And, you write:
REG |= 0b00010001;
Does it get implemented in the AVR-universe as a read of of REG into a temporary register, followed by the bitwise-OR, and then a write back? Or, if that register happens to be at an address that allows bit-set operations, does it do 2 bit-sets? Does the choice of bitset or full-byte OR depend on the number of bits that are true in the constant?
What happens if it is ORed with a variable?
Is the operation guaranteed to be atomic in either implementation?
And, what happens with a 16-bit hardware register?
Is this behavior consistent across compilers, especially targeting different processor families?
Thanks again!
Jim Wagner
PostPosted: Jun 12, 2012 - 08:00 PM
Jim,
As you posted in avr-gcc forum you will find that if only ONE bit is being changed and the target is in range of SBI/CBI (so 0x00..0x1F) then yes it uses an atomic SBI/CBI instruction but if more bits are being changed in uses IN/op/OUT - sdly it does not do two SBI/CBI when just 2 bits are being changed.
As soon as an RMW is used it's not atomic so the programmer should be aware of this and protect if necessary.
BTW it's easy to try stuff out to find out - this for mega16:
   PORTB |= 0b00100000;
  92:   c5 9a          sbi   0x18, 5   ; 24
   PORTB |= 0b01000100;
  94:   88 b3          in   r24, 0x18   ; 24
  96:   84 64          ori   r24, 0x44   ; 68
  98:   88 bb          out   0x18, r24   ; 24
   PORTB |= 0b10010011;
  9a:   88 b3          in   r24, 0x18   ; 24
  9c:   83 69          ori   r24, 0x93   ; 147
  9e:   88 bb          out   0x18, r24   ; 24
   TIMSK |= 0b00000001;
  a0:   89 b7          in   r24, 0x39   ; 57
  a2:   81 60          ori   r24, 0x01   ; 1
  a4:   89 bf          out   0x39, r24   ; 57
glitch
PostPosted: Jun 12, 2012 - 08:01 PM
It will most likely do a Read-OR-Write operation as you first described [for multi-bit sets]. However there are no hard and fast rules here, if you want to know what YOUR compiler is doing... you will have to look at the generated code from your compiler for the optimization settings you have selected. [results likely will differ between compilers, versions of compilers and optimization levels]
ka7ehk
PostPosted: Jun 12, 2012 - 08:27 PM
Thanks, folks -
At my "normal" computer, Windows (and, hence Studio) comes via VMWare. The computer, not being mine, is severely memory-challenged, and takes a good 5 minutes to get Windows on its feet. Its reasonable, once running, but takes forever to get there. Thus, its not so easy to investigate what should be easy test cases.
Sorry for the noise!
Jim Wagner
PostPosted: Jun 12, 2012 - 08:33 PM
Luxury...
(Sorry, couldn't resist!)
jayjay1974
PostPosted: Jun 12, 2012 - 08:40 PM
Probably because that's not the same as in/or/out where all bits change state simultaneously.
snigelen
PostPosted: Jun 12, 2012 - 09:22 PM
JohanEkdahl wrote:
Luxury...
Oh, Monty Python?
Monty Python wrote:
Luxury. We used to have to get out of the lake at six o'clock in the morning, clean the lake, eat a handful of 'ot gravel, work twenty hour day at mill for tuppence a month, come home, and Dad would thrash us to sleep with a broken bottle, if we were lucky!
PostPosted: Jun 12, 2012 - 09:25 PM
Let's say the compiler did that. Now, you would have a glitch of a couple AVR cycles. But the programmer wants/needs them to be set at the same time! Shoot-through, anyone?
As is demonstrated above, if you want two bit sets then program two single-bit operations.
Atomicity is indeed a concern. My short answer is it shouldn't be too hard to look at the ISRs and note any I/O work done there--it usually isn't much. If none, then the mainline shouldn't need to worry about atomicity.
SprinterSB
PostPosted: Jun 12, 2012 - 09:46 PM
REG |= 0b00010001;
Yes.
No. That would be a bug with respect to volatile correctness.
"What comprises a volatile access" is implementation defined, yet implementations chose to translate to code that has the same number of reads and the same number of writes in the same order as given by the source code.
It depends on the available instructions, of course. If there are no atomic operations that have the same volatile footprint, the you cannot use such operations, of course.
Same. IN-OR-OUT or LDS-OR-STS cum granum salis.
No. Not even PORTB |= 1 is guaranteed to be atomic, even if SBI is available. The compiler tries to use it but there is no guarantee. For example, try avr-gcc without optimization.
Same. even if just bit 0 is changes to high part must be loaded/stored to satisfy volatile correctness.
That will depend on the compiler and on the target. For gcc see for example
gcc: What constitutes an access to an object that has volatile-qualified type
There are situations where the compiler inforinges volatile correctness, for example on AVR, some SFRs behave differently with SBI compared to an IN-OR-OUT sequence. Yet the avr-gcc might use SBI in that case.
For an example see this post and the subsequent discussion.
ka7ehk
PostPosted: Jun 12, 2012 - 09:52 PM
Thanks -
I really appreciate the explanation. Pretty much makes sense!
I vaguely recall reading somewhere on this list that wrapping the non-atomic operations in sei/cli pair does not really achieve atomic operation. Is this true? If so, is this generally true across compilers?
Jim Wagner
PostPosted: Jun 12, 2012 - 10:05 PM
Oh, wow--I more than vaguely recall it, but it will take some time perhaps to dig out. IIRC GCC might re-order code in certain cases, and your cli/sei may not end up where you think they might. Digging...
[edit] I think there is another thread similar to this link, but this should give you an idea of sei/cli handling in GCC and the recommendation to use atomic.h:
http://www.avrfreaks.net/index.php?name ... torder=asc
This next link is to a thread that doesn't address the issue quite as directly. However, read it through and follow the links to the prior discussions. Interesting stuff:
skeeve
PostPosted: Jun 12, 2012 - 10:39 PM
ka7ehk wrote:
REG |= 0b00010001;
Except in the single-bit case, read-modify-write is the only allowed implementation.
The definition of access is implementation-defined and that provides a lot of wiggle-room, but two consecutive writes could produce an externally visible surprise.
Even an SBI in the single-bit case can produce arguments.
Also SBI, SBI would be slower than IN, ORI, OUT.
Read-modify-write.
No.
Definitely not atomic.
In fact, assignments to distinct 16-bit registers can interfere with each other.
They can share intermediate high bytes that exist to allow atomicity when assigning 16-bit registers.
Some depend on the available instruction set and therefore must be consistent.
Atomicity cold be provided.
Michael Hennebry
ka7ehk
PostPosted: Jun 12, 2012 - 11:09 PM
Duhhh, of course you would not want two non-simultaneous bit-set operations when the code implies simultaneous. As in
REG |= 0b00010001;
Comes from not thinking things through well enough. But, discussions like this DO help the clear thinking thing.
Thanks, all!
Jim Wagner
wek
PostPosted: Jun 13, 2012 - 05:51 AM
If you desire control, use asm.
JW
SprinterSB
PostPosted: Jun 13, 2012 - 07:51 AM
Assembler is not that trivial, because in general you don't want to propagate the need of assembly to the whole function. That is: you want to use inline assembler.
How would an inline assembler function C code look like that cared for all situations in the best way?
• SBI available or not?
• IN/OUT available or not?
• Mask is a power of two or not?
• LAS instruction available or not?
avr-gcc NewsABIOptions4.8-WindowsInline Asm
wek
PostPosted: Jun 13, 2012 - 09:55 AM
Control means you know what are you doing, and you do it deliberately and willingly. So there's no free lunch, read, pre-chewed automatism, sorry.
JW
PostPosted: Jun 13, 2012 - 10:02 AM
This was because sei() and cli() are basically just one line asm macros that insert SEI or CLI opcodes and there is no guarantee about the ordering of where they appear. Now maybe this has changed in later iterations of the compiler but this was the reason for Dean Camera adding <util/atomic.h> to AVR-LibC:
http://www.nongnu.org/avr-libc/user-man ... tomic.html
As that article notes someone very near here wrote this:
http://www.nongnu.org/avr-libc/user-man ... de_reorder
Do remember that atomicity is only an issue when dealing with something that is actually shared between main() and ISR() so if you limit those (or pick naturally atomic entities) you can reduce the requirement for atomicity protection.
ka7ehk
PostPosted: Jun 13, 2012 - 05:17 PM
Thanks for the clarification on "atomic". As earlier, the insight is genuinely appreciated.
Now, if there were a simple way to "bookmark" such threads to make later access simpler, when the grey matters fail to recover the key details .....
Jim Wagner
jayjay1974
PostPosted: Jun 13, 2012 - 06:11 PM
Ctrl-D... at least in FF.
PostPosted: Jun 13, 2012 - 10:15 PM
I run a password protected wiki on a web hotel, and there I can edit wiki pages making notes of all sorts of stuff. E.g. links to interesting threads here at AVRfreaks.
Thus I can reach them form any Internet-able computer.
PostPosted: Jun 14, 2012 - 09:04 AM
Can't you store your "password vault" as a PGP encrypted document there then? Wink
larryvc
PostPosted: Jun 14, 2012 - 09:52 AM
How is Johan going to remember/access the password for the web hotel when it is in the "password vault"? Wink
Larry
PostPosted: Jun 14, 2012 - 01:58 PM
The two remarks above are referring to another thread, where I was asking for opinions re "password repository applications". My answer to the two comments above can be ound in that thread.
Or rather, it won't. The crappy dorum software on the edge of collapse now refuses to show the listings pages of my posts (only first page works, then it is just crap). Atmel should be embarrased aout the state of this site, but obviously care for more or less about $1 worth.
Just consider this and the two preceding posts OT static and proceed with the RMW discussions.
