Posted: Jun 09, 2012 - 08:15 PM |
i am trying to write code to control a bi-color led and a relay for a bypass circuit using an attiny 13a. this is my first program in C so any help or hints would be very welcome. using avr studio 6, haven't gotten a programmer yet but was going for the tinyusb...suggestions on this also needed and welcome.
the code:
*/using attiny13a/*
#include <time.h>
#define bled PB3
#define rled PB7
#define ryoff PB4
#define ryon PB0
#define switch PB1
void main() { */reset on power up, bypass mode, PORTB I/0 set/*
DDRB = 0b00011101;
switch = 0;
i = 0{
{output_high (PORTB, bled); */flash bled 2x's, then rled on until switch hit/*
delay_ms (250)};
{output_low(PORTB, bled);
delay_ms(250)};
{i = i++
if i >= 2
output_high (PORTB, rled)
goto switch1}
switch1 (){ */debounce attempt, start counter at tap, if not tappedfor/*
counter=0; */85msec cycles again, if so, moves to onstate/*
{while output_high (PORTB, switch);
start=counter;
if counter <85;
goto switch1;}
elseif counter >=85;
goto onstate;}
onstate ():
{{output_low (PORTB, rled); */rled off, bled on, relay on(will have to work this/*
output_high (PORTB, bled); */out a little better../*
output_high (PORTB, ryon);*/relay on/*
delay_ms (15)};
{if output_high (PORTB, switch);
goto switch2};
switch2 (): */debounce number 2 for off state.../*
counter=0;
start=counter;
if counter <85;
goto switch2;}
{elseif counter >=85;
goto offstate;}
offstate (): */self explanatory/*
{output_high (PORTB, rled);
output_low (PORTB, bled);
output_high (PORTB, ryoff);
delay_ms (15)}
goto switch1}
like i said, this could be missing huge pieces as it's my first attempt...any and all help needed and welcome. thanks in advance |
Posted: Jun 09, 2012 - 08:47 PM |
Posted: Jun 09, 2012 - 09:13 PM |
First off, you need to read your C textbook. Comments should be:
/* blah-blah */
Then you should make an attempt at formatting the code. e.g. fresh line for each statement. indent each block of statements.
This is not difficult. You will then be able to post some attractive code. You will get more readers this way.
Then you will get plenty of help.
Posted: Jun 09, 2012 - 09:34 PM |
*/using attiny13a/*
#include <time.h>
#define bled PB3
#define rled PB7
#define ryoff PB4
#define ryon PB0
#define switch PB1
void maint() { /*reset on power up, bypass mode, PORTB I/0 set*/
DDRB = 0b00011101;
switch = 0;
i = 0{
{output_high (PORTB, bled); /*flash bled 2x's, then rled on until switch hit*/
delay_ms (250)};
delay_ms(250)};
{i = i++
if i >= 2
goto switch1}
switch1 (){ /*debounce attempt, start counter at tap, if not tappedfor*/
counter=0; /*85msec cycles again, if so, moves to onstate*/
start=counter;
if counter <85;
goto switch1;}
goto onstate;}
onstate ():
{{output_low (PORTB, rled); /*rled off, bled on, relay on*/
output_high (PORTB, bled); /*out a little better..*/
output_high (PORTB, ryon); /*relay on*/
delay_ms (15)};
goto switch2};
switch2 (): /*debounce 2 for off state...*/
counter=0;
start=counter;
if counter <85;
goto switch2;}
goto offstate;}
offstate ():
delay_ms (15)}
goto switch1}
Posted: Jun 09, 2012 - 10:42 PM |
| Did that one compile ok? |
Posted: Jun 09, 2012 - 10:55 PM |
No way! There are LOTS of syntax errors. |
Posted: Jun 09, 2012 - 10:57 PM |
| Shhh! I'm hunting wabbits! |
Posted: Jun 09, 2012 - 10:58 PM |
Not on any standards compliant compiler:
Posted: Jun 09, 2012 - 11:22 PM |
| Shhh! Let Mr Nickelis tell us what his software development chain reports. He might have a full IAR Electronic Workbench setup that none of us know how to run. |
Posted: Jun 10, 2012 - 05:17 AM |
Nick,
Without spoiling the fun that others might be eliciting, could I suggest that you consult your C text book to see what it says about the use of {} pairs and where they should be placed.
Don't worry ... we want to help you; spoon feeding doesn't help though.
Ross |
ValuSoft
Melbourne Australia
Posted: Jun 10, 2012 - 09:36 PM |
| well, i've used BASIC...thanks for further discouraging an already discouraged attempt at C...gettin back to the books.... |
Posted: Jun 10, 2012 - 11:05 PM |
| I find that the short chapter called "c in 16 pages" in the imagecraft help file that comes with the compiler is informative. Its a free dl. If you know basic, I think that is a big help. The procedural languages like c, basic, pascal and fortran are all more similar than different. They all have signed and unsigned integers of 1,2 and 4 byte length, they all have subroutines that take parameters and return a value, they all have a for loop, a loop that tests at the top, a loop that tests at the bottom, an if then else statement and a switch statement. Copy the operator page out of the c book. C uses & instead of AND, so you need to either remember it or look it up. |
Posted: Jun 10, 2012 - 11:11 PM |
Don't be discouraged, it took me 20 years++ before I started to use it.  |
Posted: Jun 10, 2012 - 11:18 PM |
| From another thread
Read the "c in 21 pages" in the imagecraft help file
here
did they cut down the number of pages due to the bad economy or do you get a reduction for good behaviour?  |
Posted: Jun 10, 2012 - 11:39 PM |
Different optimizer switch. |
_________________ Chuck Baird
http://www.cbaird.org
Posted: Jun 11, 2012 - 12:05 AM |
| I've seen a couple of short summary cheat sheets, but that's the one I can usually remember while sitting at the keyboard. I hope you can find it in the help file even though I forgot how many pages it was. |
Posted: Jun 11, 2012 - 01:25 AM |
Posted: Jun 11, 2012 - 12:03 PM |
| thank you. I will look into all of these...the help page definitely is informative and the site you posted larry, should help a lot...i'll re-post once i feel i get to someting a little more legible... |
Posted: Jun 12, 2012 - 11:55 AM |
Well,there are things I do not understand:
what do you do with the veriables 'start and ' counter (they both seem stuck to 0). Perhaps you should make them evolve a little?
The construction " {while output_high (PORTB, switch); "
might be "while output_high (PORTB, switch){"
(in the fist case, one loops without doing anything unless output_high becomes .. low.
The same thing with " if counter <85;
goto switch1;" which is likely to become
"if counter <85 goto switch1;" |
Posted: Jun 12, 2012 - 12:00 PM |
Sorry - you are advocating that a beginner start out using "goto" in C? What is the thinking behind that? Have you heard of the term "structured programming"?
http://en.wikipedia.org/wiki/Structured_programming |
Posted: Jun 12, 2012 - 12:59 PM |
Bonjour, Monsieur Clawson
Yes,
I first read of the term "structured programming" in 1979 (two millenia) .
I also know languages such as R where gotos do not even exist at all (no need to forbid them : people remain happy without goto's)...
But
I had noticed he knew basic and I kow gotos are not forbidden ic C (should be reserved for escaping when an error happens into abyssally deep program structures).
And
one should be indulgent with beginners.... (and even you did not protest whis his goto's)
And
I would be happy to understand what he wants to do, because I am curious and because I am old and silly enough not to understand.... |
Posted: Jun 12, 2012 - 01:02 PM |
Teaching them bad programming practice?
Even BASIC these days is a structured language since the need for line numbers GOTO and GOSUB were removed. There's simply no excuse for bad programming technique in 2012.
(and yes goto has it's place even in C but it's usually for escaping early from a heavily nested situation when a serious error has occurred (like malloc() returned 0) and should not be considered for "normal" programming)
I was formally taught programming 31 years ago at university using Pascal and even back then the idea of using goto was severely frowned upon - hopefully things have progressed in 30 years.
(anyway you were advocating "goto switch1" when it's actually the name of a function not a goto label so the syntax didn't make sense even if the goto did) |
Posted: Jun 12, 2012 - 01:21 PM |
"anyway you were advocating "goto switch1" when it's actually the name of a function not a goto label so the syntax didn't make sense even if the goto did"
was "switch1" the name of a void function in his mind?
(in my mind, I did not read the () and thought of a badly spelled label..., if he had not spoken about basics, maybe I would have read the "()"...)
Therefore, he might happily remove the gotos here if switch is meant as a void function...
and what makes
while(conditionx);
if (conditiony);
except testing the conditions (x y)?
Is that was he was meaning?
But, if one shows too many errors at a time, that might be discouraging! An error after the other is more efficient.
I was not advocating anything, but before structuring |
Posted: Jun 12, 2012 - 01:42 PM |
@nickelis,
Your C syntax is seriously wrong in many places.
I see this as a minor problem that is easily resolved.
However the first job is to lay your program out neatly even in pseudo-code.
1. Indent blocks of code.
2. Put each statement on a fresh line
3. Add explanatory comments that say what you want to do.
Once you have done this, you can translate into C, Pascal, Java or whichever language you choose.
You can lookup the correct syntax for if() or while() in your textbook, and we will help you to get everything right.
Those (1), (2), (3) steps are your responsibility. Get them sorted and translating into C is trivial.
Posted: Jun 21, 2012 - 02:36 PM |
Bonjour Nickelis
I found some code which debounces a push button switch here (http://www.elektor.fr/extra/programmation-en-c-des-microcontroleurs-risc-avr.966219.lynkx, download and unzip AVRprog-VF.zip and have a look at the very well written c source in AVRprog\commut2 :
when the bounce switch is high, it waits 50 ms (you prefer 85 ms) and, if it is confirmed, it waits until it gets low... (in the book, the switch is connected to PORTA, but it doesnot seem that complicated to move it where you want)
Perhaps you should have a variable, let it be called "state", whith two values (this "state" increases each time the button is pressed and released, and if it goes too high, it cames back to its lower value)
state 1 : relay is on, LED A is on, led B is off
state 2 : relay is off, LED A is off, led B is on
BTW: perhaps led A and relay might be put together , and I do not understand why your relay needs two inputs .... This would spare 1 or 2 pins and therefore some hardware complexity
I do not understand hou you initialise it (you make a kind of greeting with a LED blinking?) but your topic is interesting (is already in a book if I do not make any misunderstanding) though it seems simple... |
Posted: Jun 21, 2012 - 03:41 PM |
| Before expending too much worry about false button presses due to bouncing, maybe just try to get the program running using no debouncing at all, and just limit the loop time of the program to about 30Hz or 50Hz. (33ms or 20ms per loop, well within the carbon based unit's perception of 'crisp response'). Buttons don't bounce more than a couple of times a couple of ms apart, and a 20 ms loop time might just make the problem moot. |
Posted: Jun 21, 2012 - 11:14 PM |
A latching relay? 1 input for on 1 input for off. |
Posted: Jun 23, 2012 - 04:27 PM |
Bonjour js:
well, I wish to thank you for the idea of latching delays (according to wikipedia, it remains in a given state even if not power supplied).
Bonjour Bobgardner:
well, perhaps giving a function which changes states and one of which parameters is the delay to debounce would be versatile enough.
Such a function would be
// for syntax checking under cygwin and native gcc (gcc -c or gcc -S)
// should be deleted, of course, with avr-gcc
#define PORTB 1
#include <stdint.h>
#define TIME2DEBOUNCE 85 // ms to see whether the switch is dreaming
#define MAXSTATES 2 // Two states are allowed (1 , 2)
uint8_t changestate(uint8_t state, uint8_t behavior, uint8_t push_button,
uint8_t debouncetime){
/* push-button is the portsB'sspin
* behavior is what one wants to do
* == 1 -> one waits until key is depressed
* else -> one goes on, the LEDS and the relay being
* allowed to change states every
* 1/10 seconds...
* state is the present state
uint8_t aux;
aux = state;
if (~input_high(PORTB,push_button)) return (state); // do not change state
delay_ms(debounce_time);
if (input_high(PORTB,push_button))
aux = state + 1;
if (aux > MAXSTATES) aux=1;
* some code to account quickly for state changes could be put there
if (behavior == 1)
while (input_high(PORTB,push_button)) ;
return(aux);
Once input_high is defined, perhaps it might work... or there is a better push button "manager".... |
Posted: Jun 23, 2012 - 04:33 PM |
@me
s/debounce_time/debouncetime/ and be sorry for posting before syntax checking... |
