PostPosted: Jun 09, 2012 - 01:43 PM
Well, how about commenting out the continue in the while in the putchar? (Once again, one of those gee I'll try this to see if it works test)
benjwy
PostPosted: Jun 09, 2012 - 02:00 PM
Removing the continue didn't change things. I really appreciate you all giving your time to this problem I must say.
This seems significant:
I created a dummy function (I tend to call these things "weasel")
Declaring (inside main):
char *message = "Hello!";
This outputs 'H' (as expected)
void weasel(char *str)
    uart_putchar(str[0]);
This however, crashes things.
    uart_putchar(str[1]);
sternst
PostPosted: Jun 09, 2012 - 02:13 PM
Please check the address where the global data is stored. Perhaps this is one of the cases where it accidentally starts at 0x60 instead of 0x100.
Stefan Ernst
PostPosted: Jun 09, 2012 - 02:21 PM
Your avr-gcc build looks fairly recent. Winavr-2010 is gcc version 4.3.3
However, Winavr builds are tried and tested.
Atmel Toolchain works fairly well.
Bingo's Linux builds are tried and tested.
I strongly suspect that your toolchain is seriously broken. And it is mystery to me why anyone should choose an 'unusual' build.
I will quite happily run Rowley Crossworks on Ubuntu and have a reliable compiler / debugger / IDE.
I don't mind compiling with avr-gcc on Ubuntu something that is already debugged.
Otherwise, why not use the best tools for the job. This probably means running or emulating Windows.
benjwy
PostPosted: Jun 09, 2012 - 02:26 PM
00800060 <__data_start>:
  800060:       48 65           ori     r20, 0x58       ; 88
  800062:       6c 6c           ori     r22, 0xCC       ; 204
  800064:       6f 21           and     r22, r15
Is this the info you're after? That's my string in there Wink
sternst
PostPosted: Jun 09, 2012 - 02:37 PM
Yes, and this
should be 00800100 instead.
Try to find a toolchain without that bug, or as a workaround put this into the command line:
-Wl,-Tdata=0x100
Stefan Ernst
benjwy
PostPosted: Jun 09, 2012 - 02:45 PM
sternst wrote:
Yes, and this
-Wl,-Tdata=0x100
You. Are. The. Man. I can't thank you enough.
Just so I can learn something from this all, could you please tell me what tipped you off to this, and how you knew that the .data section should start at 0x0100, but might be at 0x0060 by mistake?
Thank-you very much to everyone who helped!
PostPosted: Jun 09, 2012 - 03:35 PM
avr-gcc is often built by people who don't follow all the news / patches / bug reports.
Personally, I wait until a new build has 'settled down' before using it. i.e. let the others have the grief.
AFIK, the 0x0060 / 0x0100 feature is a build problem.
Most of the Atmel Toolchain features are down to Atmel putting typos in their typos into XML files. Then creating duff system header files.
PostPosted: Jun 09, 2012 - 07:45 PM
When you use code such as this:
    char message[7];
    message[0] = 'H';
    message[1] = 'e';
    message[2] = 'l';
    message[3] = 'l';
    message[4] = 'o';
    message[5] = '!';
    message[6] = 0;
the compiler generates code along the lines of:
  LDI YL, low(message)
  LDI YH, high(message)
  LDI R24, 'H'
  ST  Y+, R24
  LDI R24, 'e'
  ST  Y+, R24
  LDI R24, 'l'
  ST  Y+, R24
etc.
that is the actual data initialisers ('H', 'e', 'l'..) are built into the code image. When you use:
char message[] = "Hello!";
No code is immediately generated for this. Instead the string "Hello!" is tagged onto the end of the code image (after .text) and the C compiler simply relies on the fact that the C Run Time (CRT) code that runs before the entry to main() will have a _do_copy_data loop that knows the sizxe of all the initial values in the .data copy following .text in flash and it (in theory!) knows where .data will ultimately be located in RAM then it just does an LPM based copying loop to block copy the entire data from the flash copy and out to RAM. In your case to the wrong place.
Stefan would have recognised that:
is relying on _do_copy_data and you would not believe the number of thread we get here were someone's home brew makefile has an avr-obcopy command that does something like:
avr-obcopy -O ihex -j .text proj.elf proj.hex
when ,if -j's are to be used, it should be:
avr-obcopy -O ihex -j .text -j .data proj.elf proj.hex
as you also want a copy of .data in the .hex file. Both Stefan and I thought that's why your objcopy must be wrong and like him I was slightly surprised when you presented an avr-objcopy command that apparently does not suffer from the "missing .data syndrome" that we see so regularly.
But the reason why the .data stuff was missing in your case is far more pernicious. If your Linux can install .deb then go to my website and get one there:
www.wrightflyer.co.uk/avr-gcc/
By the way your avr-objcopy is NOT safe if you ever use <avr/eeprom.h> or <avr/fuse.h> or <avr/lock.h> so I'd suggest you also seek out "Mfile" and use it to generate your Makefile's (or at least just steal the "good stuff" from its makefile_template),
snigelen
PostPosted: Jun 09, 2012 - 08:09 PM
Since he's using a FreeBSD port of avr-gcc, I guess he's using FreeBSD. Isn't Jörg the maintainer of that port?
benjwy
PostPosted: Jun 10, 2012 - 01:21 AM
Thanks for the in-depth reply clawson, it's appreciated. Now that I look in my datasheet, I see that RAM starts at 0x100. At least I learned something from you guys Smile
@snigelen, correct. I think he maintains all of the AVR-related ports. I was unsure whether to send a PR to him, or someone else.
Cheers.
engineer.pk
PostPosted: Jun 16, 2012 - 08:43 PM
The error may be in
void my_puts(char *str)
while (*str) {
uart_putchar(*str++);
change it to
while (*(str) != '\0') {
