valusoft
PostPosted: May 28, 2012 - 09:29 AM
Techrepublic cites this real world mistake.
I once got a call from a user who said that he thought that either a circuit breaker had been tripped or his power strip had gone bad because neither his computer nor his monitor were receiving any power. This guy was normally pretty sharp, so I assumed that his diagnosis was probably correct.
When I showed up with a new power strip, I began unplugging everything from the old power strip only to discover that the power strip was plugged into itself rather than being plugged into an electrical outlet.
Ross McKenzie
ValuSoft
Melbourne Australia
PostPosted: May 28, 2012 - 09:46 AM
And what wrong with that? With the carbon tax coming in we need those kind of self powering strips.
PostPosted: May 28, 2012 - 03:12 PM
The liquid hydrogen in the superconducting power cable must have boiled off.
ossi
PostPosted: May 28, 2012 - 03:19 PM
Sort of regenerative energy Surprised
PostPosted: May 28, 2012 - 03:48 PM
We've had AC and DC for a long time but BC and CC have been missing up until now.
CC is the Circular Current you get when plugging a power strip into itself, and Bob referred correctly to Bolied-off Current (or BC).
Had it not been bolied off it would have flown forever, a.k.a EC (Eternal Current).
FC and further down the alphabet are not defined yet. You are free to invent them..
Very Happy
zbaird
PostPosted: May 28, 2012 - 06:59 PM
OC - ouroboros current
Chuck Baird
http://www.cbaird.org
PostPosted: May 28, 2012 - 07:53 PM
FC - future current (and then of-course PC - past current)
DocJC
PostPosted: May 28, 2012 - 08:07 PM
Of course there is ZC, (Zap Current).
It becomes evident when one's finger touches the exposed conductor.
JC
larryvc
PostPosted: May 28, 2012 - 08:10 PM
JC - DocJC current, like his avatar
Larry
ossi
PostPosted: May 28, 2012 - 08:12 PM
Google has a lot of hits about circulating currents (cc)
http://www.icee-con.org/papers/2008/pdf/O-150.pdf
DocJC
PostPosted: May 28, 2012 - 08:13 PM
Yep. The JC current is easy to detect, as it emits a mono-polar magnetic field, which is generally repulsive. Shocked
JC
larryvc
PostPosted: May 28, 2012 - 08:16 PM
I think we are all running on OCC.
OCC - Obsessive Cumpulsive Current.
Larry
thavinator
PostPosted: May 28, 2012 - 09:51 PM
See, the trick is to first plug the power strip into the wall to get it charged up, then you need to unplug it from the wall and REALLY QUICKLY plug it into itself to keep the power circulating. If you're not fast enough, all the electrons spill out and then you'll look like an idiot when tech support shows up.
PostPosted: May 28, 2012 - 10:14 PM
I find this hard to believe since the speed of the electrons is 1/1000 of an inch per second. Say the chord is one metre (approx 40 inches). then it takes an electron about 40000 seconds to travel the length of the loop. Conversely, for each second you're out of the outlet and still not in the loop only 1/40000 of the electrons spill out. That's the good news.
The bad news is that it takes 40000 seconds to fully load the power strip with electrons. That's more than 11 hours.
Excuse me - gotta go... I need lay out the 25 metre extension chord. I'm planning on using the electric lawn mover somewhere around midsummer...
(MC - Mowing Current)
PostPosted: May 29, 2012 - 12:09 AM
In order not to have current spill out from the strip one has to make sure that the unused outlets have been plugged up.
Graynomad
PostPosted: May 29, 2012 - 12:45 AM
So that's what those little 3-pin plastic plug things are for.
______
Rob
PostPosted: May 29, 2012 - 01:53 AM
Of course!! They are not made simply to keep little people's fingers from poking things into the outlets.
Of course not many people know that......
ossi
PostPosted: May 29, 2012 - 06:20 AM
And if you connect the cables right through you get DC,
while reversing the orientation yields AC.
zbaird
PostPosted: May 29, 2012 - 06:55 AM
Can you get 220v instead of 110v by plugging two power strips into each other?
Chuck Baird
barnacle
PostPosted: May 29, 2012 - 06:57 AM
Only in series, not in parallel.
Neil Barnes
www.nailed-barnacle.co.uk
ossi
PostPosted: May 29, 2012 - 07:11 AM
Start parallel on one side and serial at the other ?
(RF freaks call that transmission line transformers)
see fig 14.15 in
http://www.ve7zsa.net/technical/advsgtx ... ne_r00.htm
PostPosted: May 29, 2012 - 08:22 AM
...only crazy people would post here...
valusoft
PostPosted: May 29, 2012 - 08:52 AM
The more posts ... the crazier Laughing
Ross McKenzie
ValuSoft
Melbourne Australia
davef
PostPosted: May 29, 2012 - 10:54 AM
ouroboros. Had to Google that one Chuck! At first I thought is was a play on the words <aurora borealis>
Well, it is a type of electron flow . . . ABC.
Torby
PostPosted: May 29, 2012 - 02:46 PM
Well, I had to laugh at myself once for making the same mistake in the tangle of wires and cables behind the desk. I'd plugged the UPS into the power strip powered by the ups. Couldn't figure out why the silly thing was beeping.
Discursive design,
Torby
EW
PostPosted: May 29, 2012 - 09:01 PM
Laughing
Special kudos for knowing what ouroboros means! Wink
Eric Weddington
Marketing Manager
Open Source & Community
Atmel
Torby
PostPosted: May 29, 2012 - 10:02 PM
I had to google
Discursive design,
Torby
PostPosted: May 29, 2012 - 11:25 PM
C'mon everybody knows that, it's electricity that grows on trees.
larryvc
PostPosted: May 29, 2012 - 11:39 PM
Gum Trees
Larry
zbaird
PostPosted: May 30, 2012 - 04:47 AM
Gum Trees
Lightning Trees
Chuck Baird
larryvc
PostPosted: May 30, 2012 - 05:02 AM
zbaird wrote:
The fractal discharge pattern is believed to extend down to the molecular level.
"believed to"? Take a look at that guy's back and decide for yourself. Shocked
Larry
barnacle
PostPosted: May 30, 2012 - 06:55 AM
BC - boustrophedonic current.
Neil Barnes
zbaird
PostPosted: May 30, 2012 - 06:59 AM
Let the Google Wars begin...
Chuck Baird
Torby
PostPosted: Jun 01, 2012 - 04:18 PM
When I was little, Mom had me completely terrified of outlets. I mean, to the point where I didn't even go near that side of the room. I finally realized, "if they are so dangerous that just being near them was harmful, they probably wouldn't put them in little boys' rooms."
Discursive design,
Torby
