PostPosted: Feb 19, 2012 - 09:41 PM
NOTE: The worst case is still 320. We will never have more than 320 test points connected. Should the size of the array STILL be a fixed 320 elements?
I certainly would. Then you keep a count, set at startup probably, of the actual number this run.
Or you might have two or three types of data with various module types. Your AVR still has a fixed amount of SRAM that you'd be willing to devote to this before stack space gets squeezed. If this configuration holds for a run of this program, then make it a fixed buffer and cast pointers to the different areas. The overhead will still be less than handling a linked list of module data.
skeeve
PostPosted: Feb 19, 2012 - 11:40 PM
NilRecurring wrote:
I had another question regarding arrays - what if it was necessary to determine the size of the array at runtime?
In that unlikely case, I'd use variable length arrays if possible.
The code is more obvious and the overhead is less.
The 320 elements needed is for the worst case and when the system is actually running with 320 test points. The hardware of the circuit is such that the design is extendable via "daughter-cards". The main board, which has the uC, has 72 test points.
The number of daughter cards connected is controlled by a DIP switch and each daughter card will have 72 test points. In this case, it would be necessary to determine the size of the array at runtime, wouldn't it?
Not necessarily.
Most likely.
Make it work.
Make it so you can tell it works.
Make it so other people can tell it works.
If it works with a fixed size array,
making it so you can tell it works favors the fixed size array.
This extendable design is something we are considering and I thought I'd ask here what it would mean when it comes to arrays and memory.
In your worst case, every array will be its worst case.
The time to consider variable sized arrays is when that is not true, e.g.
you need 200 ints and 50 longs or 100 ints and 100 longs,
but not 200 ints and 100 longs.
If you have enough memory for 200 ints and 100 longs,
fixed arrays would still be a good idea.
Michael Hennebry
lammelm
PostPosted: May 24, 2012 - 09:56 PM
JohanEkdahl wrote:
Well-well. I was convinced this was not allowed. You live and you learn.
The remaining warning then is that you should watch out so that you do not return (a pointer) to the array exiting the function where the variable was defined. At that point is is actually not "alive" any more, the memory it occupied is free for other uses and you might end up handling pure garbage later.
Example (sketchy, not tested):
int * foo(int theSize)
   int theArray[theSize];
   // Do something with theArray here...
   return theArray;  // DON'T DO THIS!
May I ask why wouldn't this code above work? By returning "theArray" pointer, the beginning address of the Array is provided to the caller, and the size of the Array is also known.
In an other thread this was posted by Clawson:
and then one that hasn't been proposed yet:
char * fillarray(void) {
  uint8_t i;
  static char staticarray[10];
  for (i=0; i<10 ; i++) {
    staticarray[i] = '0' + i;
  uint8_t i;
  char * data;
  data = fillarray();
  for(i=0; i<10; i++) {
    use(data[i]);
I guess he missed the "return" part from the called function though.
His suggestion seem very much the same for me compared to what say we shouldn't do. Am I missing something?
Please enlighten me about this, because I'm learning these things right now.
sternst
PostPosted: May 24, 2012 - 10:07 PM
But after exiting the function the array no longer exist, so the address of "nothing" is provided to the caller.
Yes, you are missing the "static".
Stefan Ernst
PostPosted: May 24, 2012 - 10:55 PM
Because the array variable is only valid as long as the function runs. As soon as the function exits that piece of memory may be used by something else. Every time the function is called a new instance of the local variable is allocated. This holds for variables that are not declared static.
For static local variables, it works in another way: Such variables are allocated once when the program starts, and no matter how many times the function is called all those instances of execution of the function will all access the same variable.
Example (sketchy, not actually compiled and run):
void foo(void)
   int anArray[10];
   anArray[7] = 42;
   return anArray;
void bar(void)
   int anotherArray[10];
   anotherArray[7] = 13;
   return anotherArray;
   int * aPointer;
   int * antherPointer;
   aPointer = foo();
   // At this point it is likely that aPointer[7] will evaluate to 42
   anotherPointer = bar();
   // At this point it is likely that aPointer[7] will evaluate to 13
PostPosted: May 25, 2012 - 09:25 AM
As others have said: "static" which means "leave this in memory so it can still be accessed even after this function exits". Without "static" the array is created on the stack on entry to the function and then destroyed/reused when it exits. If you return a pointer to it you are returning a pointer to somewhere in the stack that may now have other data or CALL/RET addresses in the middle.
While it might appear at the very moment of return that the data in the array is still there it would be EXTREMELY unwise to rely on this!
BTW returning pointers to automatics is one of the classic programming errors and while a C compiler probably won't spot such naughtiness a more aggressive checking tool such as lint or split should pick this up.
lammelm
PostPosted: May 25, 2012 - 10:29 AM
void foo(void)
   int anArray[10];
   anArray[7] = 42;
   return anArray;
void bar(void)
   int * aPointer;
   aPointer = foo();
But if you use static, and this function is in an other source file (for example an uart function in uart.c), then won't limit 'static' the scope of that variable to that source file?
snigelen
PostPosted: May 25, 2012 - 10:43 AM
You can't even access the variable outside the function it's defined in. But you can return a valid pointer to it that can be used anywhere.
sternst
PostPosted: May 25, 2012 - 10:54 AM
The scope of that variable is even limited to the function. But that has nothing to do with the "static" but with the fact that it is a local variable. "static" has two different meanings depending on whether it is a global or local variable (*). And "scope limiting" is only related to direct access to the variable (by its name). Access by a pointer is not affected by the scope.
"static" on global variable: scope limited to source file.
"static" on local variable: variable persists between calls of that function.
Stefan Ernst
PostPosted: May 25, 2012 - 11:16 AM
Do not mix up scope (visibility) and extent (lifetime).
PostPosted: May 25, 2012 - 12:24 PM
Also not that all rules about scope go out the window as soon as you starting handing pointers round Wink
Interesting recent thread on a similar subject (if you understand a bit about C++) here: http://www.avrfreaks.net/index.php?name ... p;t=120888
