\file WSNEndDeviceApp.c
\brief
\author
Atmel Corporation: http://www.atmel.com \n
Support email:
avr@atmel.com
Copyright (c) 2008-2011, Atmel Corporation. All rights reserved.
Licensed under Atmel's Limited License Agreement (BitCloudTM).
\internal
History:
13/06/07 I. Kalganova - Modified
#ifdef _ENDDEVICE_
#include <WSNDemoApp.h>
#include <WSNVisualizer.h>
//request parameters for APS_DataReq primitive
extern APS_DataReq_t messageParams;
extern AppMessageRequest_t appMessage;
extern AppState_t appState;
extern bool subTaskRequested;
extern void appLeaveNetwork(void);
static ZDO_SleepReq_t sleepReq;
static void APS_DataConf(APS_DataConf_t *confInfo);
static void ZDO_SleepConf(ZDO_SleepConf_t *conf);
static void appSensorsesGot(void);
void APS_DataIndDevice(APS_DataInd_t *indData);
void appInitDeviceEndDevice(void);
Process end device functionality.
Parameters:
none
Return:
none
void appEndDeviceTaskHandler(AppEvent_t event, void *param)
switch (appDeviceState)
case WAITING_DEVICE_STATE:
switch (event)
case APP_SENDING_DONE:
if (APS_SUCCESS_STATUS == ((APS_DataConf_t *)param)->status)
visualizeAirTxFInished();
failedTransmission = 0;
appDeviceState = SLEEPPING_DEVICE_STATE;
if (APP_THRESHOLD_FAILED_TRANSMISSION < ++failedTransmission)
appDeviceState = INITIAL_DEVICE_STATE;
appLeaveNetwork();
return;
appDeviceState = SENDING_DEVICE_STATE;
appPostSubTaskTask();
case APP_SLEEP_DONE:
if (ZDO_SUCCESS_STATUS == ((ZDO_SleepConf_t *)param)->status)
// visualizeSleep();
case APP_READING_DONE:
appStopSensorManager();
default:
case READING_SENSORS_STATE:
switch (event)
case APP_PROCESS:
appStartSensorManager();
appReadLqiRssi();
appDeviceState = WAITING_DEVICE_STATE;
appGetSensorData(appSensorsesGot);
default:
case SENDING_DEVICE_STATE:
switch (event)
case APP_PROCESS:
visualizeAirTxStarted();
APS_DataReq(&messageParams);
default:
case SLEEPPING_DEVICE_STATE:
switch (event)
case APP_PROCESS:
visualizeSleep();
ZDO_SleepReq(&sleepReq);
case APP_WOKEUP:
visualizeWakeUp();
appDeviceState = READING_SENSORS_STATE;
default:
case INITIAL_DEVICE_STATE:
switch (event)
case APP_PROCESS:
sleepReq.ZDO_SleepConf = ZDO_SleepConf;
// Prefilling request parameters
messageParams.profileId = simpleDescriptor.AppProfileId;
messageParams.dstAddrMode = APS_SHORT_ADDRESS;
messageParams.dstAddress.shortAddress = CPU_TO_LE16(0);
messageParams.dstEndpoint = 1;
messageParams.clusterId = CPU_TO_LE16(1);
messageParams.srcEndpoint = simpleDescriptor.endpoint;
messageParams.asduLength = sizeof(appMessage.data);
messageParams.asdu = (uint8_t *)(&appMessage.data);
messageParams.txOptions.acknowledgedTransmission = 1;
#ifdef _APS_FRAGMENTATION_
messageParams.txOptions.fragmentationPermitted = 1;
#endif // _APS_FRAGMENTATION_
#ifdef _LINK_SECURITY_
messageParams.txOptions.securityEnabledTransmission = 1;
messageParams.radius = 0x0;
messageParams.APS_DataConf = APS_DataConf;
default:
case REINITIAL_DEVICE_STATE:
switch (event)
case APP_PROCESS:
default:
default:
// appEndDeviceTaskHandler must be called from main state machine after this function
if (WAITING_DEVICE_STATE == appDeviceState)
appDeviceState = REINITIAL_DEVICE_STATE;
appEndDeviceTaskHandler(APP_READING_DONE, NULL);
appEndDeviceTaskHandler(APP_SLEEP_DONE, conf);
appEndDeviceTaskHandler(APP_SENDING_DONE, confInfo);
indData = indData;
//eof WSNEndDevice.c
