Posted: May 22, 2012 - 12:43 PM |
Well, I presume that you have a full CodeVision license. And the CodeWizard will create your interrupt code.
The mcu is used more efficiently with interrupts. It only executes instructions when required.
When you poll, you sit in a tight loop doing nothing apart from wait for a bit to be set.
Yes, the interrupt handling is more complex than polling. The CodeWizard writes it for you. Or you can use Atmel app notes. Or any code written for any cpu ever invented.
Before you can use any <stdio.h> functions, you must #include <stdio.h>
printf("Hello World\r\n");
while (1) {
if (kbhit()) {
putchar(getchar());
Posted: May 22, 2012 - 01:06 PM |
btw kbhit() that you mean is this :
//special macro
#define kbhit() (rx_counter!= 0)
or this?
while (rx_counter0) // anything there ?
getchar(); // eat it.
thx 4 the previous help again  |
Posted: May 22, 2012 - 01:32 PM |
| You have used the word "packet" several times. I think we have some confusion of the use of this word. If you fill out your city and country in your profile, it will help the English speakers to recognize translation problems. I might respectfully suggest that you use a slightly more normal text style to improve the understandability of your messages. All thos lowercase abbreviations are hard to read. No need to save characters. You didn't respond to my question in a previous message. Some might regard this as an affront. |
Posted: May 22, 2012 - 01:51 PM |
ah sorry my bad, i'm still learning how to type in english well , and sometimes i get internet connection problems so the comment i submit is sometimes not displayed correctly (or even failed to submit) and it will take time to edit it again
actually i did respond your comments on here:
e0ne199 wrote:
the packet transfer and receive routines are all already included in the code, and the problems are when my mcus are trying to send an array of packets and receive it in master side ...the transmit code on the slave is like this :
interrupt [USART1_RXC] void usart1_rx_isr(void)
char status,data;
status=UCSR1A;
data=UDR1;
request_=data;
if(request_==0x20) { putchar1(real_packet[1]);}
if(request_==0x30) { putchar1(real_packet[2]);}
if(request_==0x40) { putchar1(real_packet[3]);}
if(request_==0x60) { putchar1(real_packet2[0]);}
if(request_==0x70) { putchar1(real_packet2[1]);}
if(request_==0x80) { putchar1(real_packet2[2]);}
if(request_==0x90) { putchar1(real_packet2[3]);};
btw, when i try to compile my program (slave side) with codevision AVR by enabling 2 non-default warnings i have just set recently, after compilation i receive a message "possible loss of precision" on lines containing commands to send the array of packets...do you know how to solve this??
looks like the transmitted packet on slave side is distorted or something like that..
before that, thx for helping
Posted: May 22, 2012 - 03:10 PM |
First off. How can anyone work with unformatted code?
Secondly. You have fiddled with the RX_USART ISR()
You appear to be peeking into a transitory value 'packet'
Instead you should read a whole sequence of bytes with getchar(). The whole point of buffered interrupts is that you will catch EVERY byte regardless of whether your robot is busy.
If you replace your 'packet' with getchar() you will process each byte in the correct order that it was received. (you can just do 4 getchar()s if you know there are 4 chars available otherwise you test rx_counter0)
David.;;
Project : automatic system for final project
Version : 1.0
Date : 4/20/2012
Author : E-1
Company : E-1 Engineering Inc.
Comments: Simple implementation of my program model for my main system :)
Chip type : ATmega324PA
Program type : Application
AVR Core Clock frequency: 18.432000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 512
#include <mega324a.h>
#include <delay.h>
#include <stdlib.h>
#include <stdio.h>
#ifndef RXB8
#define RXB8 1
#ifndef TXB8
#define TXB8 0
#ifndef UPE
#define UPE 2
#ifndef DOR
#define DOR 3
#ifndef FE
#define FE 4
#ifndef UDRE
#define UDRE 5
#ifndef RXC
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<DOR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
//PWM
#define left_pwm OCR1BL
#define right_pwm OCR1AL
//global variables
char start, packet, val1, val2, val3, val4, val5, val6, val7, val8;
eeprom char id[3];
eeprom char location[4][3] = { {0, 0, 0},
{0, 0, 0},
{0, 0, 0},
{0, 0, 0}
int id_count = 0, count = 0, soft_left, soft_right, row = 0, line = 0;
// USART0 Receiver buffer
#define RX_BUFFER_SIZE0 32
char rx_buffer0[RX_BUFFER_SIZE0];
#if RX_BUFFER_SIZE0 <= 256
unsigned char rx_wr_index0, rx_rd_index0, rx_counter0;
#else
unsigned int rx_wr_index0, rx_rd_index0, rx_counter0;
// This flag is set on USART0 Receiver buffer overflow
bit rx_buffer_overflow0;
// USART0 Receiver interrupt service routine
interrupt [USART0_RXC] void usart0_rx_isr(void)
char status, data;
status = UCSR0A;
data = UDR0;
start = data;
packet = data;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN)) == 0) {
rx_buffer0[rx_wr_index0++] = data;
#if RX_BUFFER_SIZE0 == 256
// special case for receiver buffer size=256
if (++rx_counter0 == 0) {
#else
if (rx_wr_index0 == RX_BUFFER_SIZE0)
rx_wr_index0 = 0;
if (++rx_counter0 == RX_BUFFER_SIZE0) {
rx_counter0 = 0;
rx_buffer_overflow0 = 1;
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART0 Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter0 == 0);
data = rx_buffer0[rx_rd_index0++];
#if RX_BUFFER_SIZE0 != 256
if (rx_rd_index0 == RX_BUFFER_SIZE0)
rx_rd_index0 = 0;
#asm("cli")
--rx_counter0;
#asm("sei")
return data;
#pragma used-
// Get a character from the USART1 Receiver
#pragma used+
char getchar1(void)
char status, data;
while (1) {
while (((status = UCSR1A) & RX_COMPLETE) == 0);
data = UDR1;
return data;
#pragma used-
// Write a character to the USART1 Transmitter
#pragma used+
void putchar1(char c)
while ((UCSR1A & DATA_REGISTER_EMPTY) == 0);
UDR1 = c;
#pragma used-
inline void init()
// Crystal Oscillator division factor: 1
#pragma optsize-
CLKPR = 0x80;
CLKPR = 0x00;
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
// Port B initialization
PORTB = 0x0F;
DDRB = 0x00;
//Port C initialization
PORTC = 0x00;
DDRC = 0xF0;
//Port D initialization
PORTD = 0x30;
DDRD = 0x30;
//for dynamixel
PORTD.7 = 0;
DDRD.7 = 1;
//motor config
//using OCR1AL & OCR1BL
TCCR1A = 0xF1;
TCCR1B = 0x02;
TCNT1H = 0x00;
TCNT1L = 0x00;
ICR1H = 0x00;
ICR1L = 0x00;
OCR1AH = 0x00;
OCR1AL = 0x00;
OCR1BH = 0x00;
OCR1BL = 0x00;
// USART0 initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART0 Receiver: On
// USART0 Transmitter: On
// USART0 Mode: Asynchronous
// USART0 Baud Rate: 115200
UCSR0A = 0x00;
UCSR0B = 0x98;
UCSR0C = 0x06;
UBRR0H = 0x00;
UBRR0L = 0x09;
// USART1 initialization
// USART1 Receiver: On
// USART1 Transmitter: On
// USART1 Mode: Asynchronous
// USART1 Baud Rate: 115200
UCSR1A = 0x00;
UCSR1B = 0x18;
UCSR1C = 0x06;
UBRR1H = 0x00;
UBRR1L = 0x09;
void packet_received()
putchar(0x10);
val1 = packet;
putchar(0x20);
val2 = packet;
putchar(0x30);
val3 = packet;
putchar(0x40);
val4 = packet;
//motor movement---------------------
void forward(int left, int right)
left_pwm = left;
right_pwm = right;
PORTC.7 = 1;
PORTC.6 = 0;
PORTC.5 = 1;
PORTC.4 = 0;
void backward(int left, int right)
left_pwm = left;
right_pwm = right;
PORTC.7 = 0;
PORTC.6 = 1;
PORTC.5 = 0;
PORTC.4 = 1;
void left(int left, int right)
left_pwm = left;
right_pwm = right;
PORTC.7 = 1;
PORTC.6 = 0;
PORTC.5 = 0;
PORTC.4 = 1;
void right(int left, int right)
left_pwm = left;
right_pwm = right;
PORTC.7 = 0;
PORTC.6 = 1;
PORTC.5 = 1;
PORTC.4 = 0;
void stop()
PORTC.7 = 0;
PORTC.6 = 0;
PORTC.5 = 0;
PORTC.4 = 0;
void arrange_position()
while (val4 > 77) {
putchar(0x40);
val4 = packet;
right(254, 250);
while (val4 > 50) {
putchar(0x40);
val4 = packet;
left(254, 250);
void dynamixel_push()
putchar1(0xFF);
putchar1(0xFF);
putchar1(0x00);
putchar1(0x07);
putchar1(0x03);
putchar1(0x1E);
putchar1(0x10);
putchar1(0x03);
putchar1(0x00);
putchar1(0x03);
putchar1(0xC1);
delay_ms(1000);
void dynamixel_pull()
putchar1(0xFF);
putchar1(0xFF);
putchar1(0x00);
putchar1(0x07);
putchar1(0x03);
putchar1(0x1E);
putchar1(0xFE);
putchar1(0x01);
putchar1(0x00);
putchar1(0x03);
putchar1(0xD5);
delay_ms(1000);
void preliminary()
while (1) {
if (start == 0xFF) {
if (packet == 0xAA) {
id[id_count] = getchar();
switch (id[id_count]) {
case '9':
location[1][1] = 1;
case 'F':
location[2][1] = 1;
case '%':
location[1][2] = 1;
//some extra books
case '3':
location[2][2] = 1;
case '<':
location[1][1] = 1;
default:
id_count++;
if (id_count == 2) {
id_count = 0;
if (PINB.0 == 0) {
putchar(0x01);
delay_ms(250);
if (PINB.1 == 0) {
putchar(0x02);
delay_ms(250);
if (PINB.2 == 0) {
putchar(0x03);
delay_ms(250);
if (PINB.3 == 0) {
putchar(0x04);
delay_ms(250);
void transmit()
PORTD.7 = 1;
DDRD.7 = 1;
void receive()
PORTD.7 = 0;
DDRD.7 = 1;
void soft_start()
soft_left = soft_right = 0;
while (soft_left < 255 || soft_right < 255) {
forward(soft_left, soft_right);
soft_left++;
soft_right++;
delay_ms(5);
void straight()
while (1) {
packet_received();
forward(255, 255);
if (val1 < 45) {
forward(254, 255);
delay_ms(60);
if (val1 > 76 && val1 < 86) {
forward(255, 250);
delay_ms(80);
if (val4 == 0) {
forward(255, 255);
delay_ms(1200);
stop();
delay_ms(5);
void turn_left()
left(254, 250);
delay_ms(800);
while (val4 < 45) {
packet_received();
left(254, 250);
delay_ms(250);
stop();
void turn_right()
right(254, 250);
delay_ms(800);
while (val4 > 50) {
packet_received();
left(254, 250);
delay_ms(250);
stop();
void main(void)
init();
#asm("sei")
preliminary();
while (1) {
// soft_start(); //'heating' the system ^_^
//straight();
//turn_left();
while (1) {
packet_received();
forward(0, 255);
if (val1 < 45) {
delay_ms(1);
stop();
Posted: May 22, 2012 - 04:01 PM |
David.;;
[HUGE requote of entire previous post removed - moderator]
i'm afraid if i change it become getchar() the process will be halted because getchar() will loop until the packet is received...CMIIW..and if i do so, the interrupt will be useless, or? |
Posted: May 22, 2012 - 04:09 PM |
| The interrupt reads the char from the uart and puts it in an array/buffer/queue (my mental model is an array. Old basic and fortran habit). Kbhit() returns true if there is something in the array (input index has been incremented), getchar pulls out a char from the output index. The indexes chase each other from 0 up to max then back to zero. |
Posted: May 22, 2012 - 05:31 PM |
First off. Please edit your last post to remove the COPY of my post. Long stretches of code are ok as one-offs. It serves no purpose to repeat them verbatim. [done that for him - moderator]
Read any book on C. Think about your PC. Think about most things in life. Your PC receives all your key-presses via interrupts. Even if it was busy writing to disk, reading a DVD, downloading from the internet.
You call getchar() when you want to see the next key in the queue. If there is not one available, it waits until there is.
This is why you call kbhit() to check first. Only call getchar() when kbhit() says there is something to get.
Try any of the CodeVision examples with buffered RX interrupts. You will see that nothing is lost. (unless you are silly, a 64 byte buffer is fine for most AVR projects)
I am still fascinated by whether people really do work with unformatted code. And if so, how do you do it ?
Posted: May 22, 2012 - 05:36 PM |
Or comments.  |
Posted: May 22, 2012 - 05:51 PM |
I can cope without the comments. If you choose your names wisely, a formatted listing can be understood.
Mind you, I have a pretty good idea what opinion the OP's teacher will have.
Even if the code does not work, if she has documented it well, the student is more likely to impress an employer.
It is a genuine question. When I used to write 6502 ASM, my editor formatted automatically. What was stored on disk was without any indentation.
Are there C editors that do this ?
Posted: May 22, 2012 - 05:54 PM |
I'll bet the editor was forced to do that in the days when every byte on disk was a precious resource! I doubt that modern C editors have the same impetus to implement such a feature. |
Posted: May 22, 2012 - 06:27 PM |
Yes, Cliff. I wrote the editor!
Yes, when I started to use PCs with more RAM and more disk, there was little point in continuing with compressed code.
All the same, modern PCs could quite easily format automatically. Personally I am happy with a specific 'format' command. Any auto-anything makes me feel uncomfortable.
Hand-formatting takes very little brain power. The average student could come home drunk. Format her assignment. Collapse in a heap. Still gain a reasonable mark even if the assignment does not 'work' perfectly.
Posted: May 22, 2012 - 08:25 PM |
thx for the detail explanation, i have tested it and it did hold the values first in the buffer before it is called
still not understand with the unformatted code you're talking about.  |
Posted: May 22, 2012 - 08:42 PM |
about this code :
char status,data;
status=UCSR1A;
data=UDR1;
request_=data;
i deliberately place my own code into the codevision ISR() so that i can get direct response when the packet is requested from other devices / mcu...or do anyone have a better way to get a direct response just like what i did with this code anyway?  |
Posted: May 22, 2012 - 10:24 PM |
You normally have short ISR()s that simply fill buffers or set a simple flag.
Your foreground code examines any flags or empties a buffer as a separate operation.
There is no right and wrong way in software. There are often efficient and inefficient or better and worse techniques.
By all means choose your own approach to interrupts and definitely your own approach to formatting.
Incidentally, atomiczombie apparently writes ASM code in a single monster file with no indentation.
Yet he produces some impressive software and hardware.
Posted: May 25, 2012 - 12:11 AM |
thx for the response.. btw i have 2 last question :
1) Do you know how to flush USART rx if it is not interrupt-driven?
2) btw if i use kbhit(), will the rx receive the data from outside in correct order?
thx before  |
Posted: May 25, 2012 - 07:50 AM |
For buffered input, you examine whether there is anything in the buffer.
// for interrupt-driven RX on USART0:
#define kbhit() (rx_counter0 != 0)
For polling, you check the USART itself.
// for polled RXC
#define kbhit() (UCSR0A & (1<<RXC0))
You flush a buffer in exactly the same way for either method. i.e.
while (kbhit()) getchar();
kbhit() is just a common name for a function/macro that tests whether there is a byte available.
Since you have CodeVision with its very capable CodeWizard, you might just as well try your own experiments. e.g.
#include <delay.h>
char c;
printf("type away regardless. Typing 'S' will sleep the display for a second\r\n");
while (1) {
if (kbhit()) {
c = getchar();
if (c == 'S') delay(1000);
putchar(c);
If you use interrupts, you will not lose any characters at all. If you use polling, any keys typed while the AVR is 'delaying' will be lost.
As I tried to explain earlier, your PC does not lose characters when the disk is running or you are playing a CD. Your PC works like the Wizard interrupt.
Posted: May 25, 2012 - 12:54 PM |
// for polled RXC
#include <delay.h>
char c;
while (1) {
if (kbhit()) {
c = getchar();
putchar(c);
wew, what a great explanation!
thx for your help, i'll test it soon  |
Posted: May 26, 2012 - 01:24 AM |
oh yah, one more question...
@bobgardner said that i may not put my modified code inside codevision's ISR() and what he said is right, if i put my modified code inside ISR() it will hang my mcu...btw do you know how to do a fast call without using ISR()? at least it wouldn't take time more than 500ms on each call, thx again for the help  |
Posted: May 26, 2012 - 08:23 AM |
I suggest that you leave the ISR() unchanged. The Wizard creates perfectly correct code.
You should put any program logic into the foreground code (which will call getchar() as required)
Since you never lose any keypresses, you can process at whatever speed you like. In fact the AVR will be able to do more work because it is never waiting for hardware.
Have you tried my example program?
