naturephoenix
PostPosted: May 19, 2012 - 09:02 PM
I was working on a book "C Programming for
Microcontrollers Featuring ATMEL’s AVR Butterfly and the Free WinAVR Compiler",
and I failed on start Sad.
Actually all went good till I write the program
"Blinking LEDs – Your First C Program"
into butterfly and (but dont ask why) I plugged out the
battery (3V panasonic from Japan).
After I plugged in battery, and when I press/ move joystic upward I get on my display some weird text which rolls or spins in circle with high speed, so I cant really see with my eyes what does it say on display.Frequency is very high.
How to fix it, is that cuz I loaded this code into butterfly, or something else with battery?
Here's the code:
#include <avr/delay.h>
int main (void)
// set PORTD for output
DDRD = 0xFF;
      for(int i = 1; i <= 128; i = i*2)
      PORTD = i;
      _delay_loop_2(30000);
   for(int i = 128; i > 1; i -= i/2)
         PORTD = i;
   return 1;
smileymicros
PostPosted: May 20, 2012 - 01:43 AM
You hold the joystick button pressed to the center and while it is pressed you insert the battery or if you are using an external battery you turn it on - while the button is pressed. Then you can release the button - but it must be pressed before you try to send the program to it. This button procedure sends out a series of question marks that the uploader needs to recognize that the Butterfly bootloader is ready to receive code.
The unreadable display is peculiar - has it been programmed before?
naturephoenix
PostPosted: May 20, 2012 - 07:31 AM
Yes,I programmed it with ""Blinking LEDs",
and after that things go bad but I repeat, only after I plugged out the "circle battery" which is placed on the board.
Display look's like it's scrolling some text with high speed.
naturephoenix
PostPosted: May 20, 2012 - 08:59 AM
I have done that with success but I had to set up butterfly in bootloader mode before.
Od cource now I can't get any of my modes, all I see
is that fast scrolling text.
Is it possible that is running the program
"blinking leds"?
smileymicros
PostPosted: May 20, 2012 - 05:39 PM
"blinking leds"?
If you loaded the blinking LED program then of course it could be running that program. Did you hook up the LEDs to see?
If you finish reading that chapter you'll see:
NOTE: the Butterfly LCD dances like crazy with each LED pass, because some of the Port D pins are also tied to the LCD. It’s a bug in our design, but in the world of marketing it would be called a free bonus feature available exclusively to you for an unheard of low price if you act immediately. Will it harm the LCD? Probably not, but I don’t know for sure, so don’t leave Blinky running overnight.
Could this be what you are seeing?
naturephoenix
PostPosted: May 20, 2012 - 06:44 PM
"blinking leds"?
Yes it's that probably, and I manage to open AVR prog,
So can you tell me how to remove blinky program, or I have to overwrite it with some program who does nutin
I just want to see default "AVR Butterfly screen" and to be able again to open all modes which comes into it
thx
smileymicros
PostPosted: May 20, 2012 - 06:53 PM
You have to reload the original AVR Butterfly application. It is also in my downloads section and you install the hex file just like you installed the Blinky file.
naturephoenix
PostPosted: May 20, 2012 - 07:21 PM
Thank you, It works!
And does this mean that any time I load some program into butterfly I will lose the original butterfly application.?
What If I place myprogram.c into the bf_gcc folder(original avr butterfly aplication folder)
and then I load the original .hex
Don't mind, but if I countinue to read a book, and I will for sure, u can expect more dumb questions Razz
PostPosted: May 21, 2012 - 10:59 AM
Yes.
