cshutchinson
PostPosted: May 18, 2012 - 03:54 PM
Here is my setup:
AVROne with 6pin ISP connection to ATTiny13.
ISP Header------>Tiny13
Pin 1------>Pin 6 (MISO)
Pin 2------>Vcc (5V)
Pin 3------>Pin 7 (SCK)
Pin 4------>Pin 5 (MOSI)
Pin 5------>Pin 1 (RESET)(also 10K pullup)
Pin 6------>Pin GND
The DWEN fuse is not set, and I can program it and read the device ID.
My understanding from the documentation is as follows:
debugWIRE OCD
Attempt to start a debug session on the debugWIRE part. If the debugWIRE interface is not enabled, Atmel Studio will offer to retry, or attempt to enable debugWIRE using SPI programming. If you have the full SPI header connected, debugWIRE will be enabled, and you will be asked to toggle power on the target - this is required for the fuse changes to be effective.
Where should I start looking if I am not offered to attempt to enable debugWire via SPI programming?
Let me also note....
I can do this full circle manually, enable DW, debug the part, disable DW through one wire, and then be able to use SPI again to program. But, this is not the way you are supposed to do it from what I have read.
Do I need to force a driver update on my AVROne to make this process work as intended (automatically prompt to enable DWEN)? Or is have I missed something in Studio 6?
I am just trying to debug some I2C stuff from Fleury and want to understand best way to do this going forward.[/img]
PostPosted: May 18, 2012 - 04:05 PM
It's when you "start Debugging" and the selected debug interface is "AVR One"
PostPosted: May 18, 2012 - 04:11 PM
If you are already in debugWire mode, Studio does not need to prompt you. Your debug session starts painlessly.
Just follow the prompts. e.g. start with a virgin AVR.
1. Start Debug.
1A. Studio may prompt you to update firmware.
2. Studio prompts you.
3. answer yes, and Studio sets DWEN
4. Studio prompts you to toggle power.
5. answer yes, and your debug begins.
6. do your debugging.
7. ...
You can either 'disable debugWire at the end of your session or simply start at (1) again. Since you are already in dW, you go straight to (6).
Readers here like to complicate matters. Generally by setting DWEN when they have no debugger.
If you never touch DWEN yourself, you will get on just fine. Always let Studio do it for you.
cshutchinson
PostPosted: May 18, 2012 - 04:21 PM
My point is, studio won't do it for me. I have a screenshot attached showing the error.... Hope I am being clear.
cshutchinson
PostPosted: May 18, 2012 - 04:24 PM
1. Start Debug.
7. ...
I will start again with a virgin AVR and report back.
PostPosted: May 18, 2012 - 04:26 PM
It's that text up at the top right in the "Output" window (which you can copy and paste into code tags here) that would be far more useful to diagnose what's going on.
cshutchinson
PostPosted: May 18, 2012 - 04:30 PM
Ok, here it is. Thanks.
11:27:05: [WARNING] The device [attiny13] is not supported in ASF Version [3.1.3] that is used in the project RealTimeClock
11:27:34: [ERROR] , ModuleName: TCF (TCF command: Processes:getContext failed.)
11:27:34: [ERROR] Target synchronisation failed. Debugger command setEmulatorMode failed., ModuleName: TCF (TCF command: Processes:launch failed.)
11:29:33: [ERROR] , ModuleName: TCF (TCF command: Processes:getContext failed.)
11:29:33: [ERROR] Target synchronisation failed. Debugger command setEmulatorMode failed., ModuleName: TCF (TCF command: Processes:launch failed.)
cshutchinson
PostPosted: May 18, 2012 - 04:34 PM
I guess I can try changing ASF version...backwards.
cshutchinson
PostPosted: May 18, 2012 - 04:41 PM
Changing ASF to 3.0.1 still gives these error messages when debug is selected on virgin chip:
11:40:02: [ERROR] , ModuleName: TCF (TCF command: Processes:getContext failed.)
11:40:02: [ERROR] Target synchronisation failed. Debugger command setEmulatorMode failed., ModuleName: TCF (TCF command: Processes:launch failed.)
While the ASF thing could be an issue you actually have three different sets of output there:
I imagine you got the ASF error during building. But then you tried to start debugging (twice) and on each occasion (11:27:34 and 11:29:33) got the error here seems to be that Studio is not "talking" to the debugger.
The way AS6 debugging works is that there's the front end Studio debugger itself then running as a separate process there is a debugger daemon and the two communicate over a localhost TCP/IP channel using the TCF protocl (which is apparently just a variant of that used in Eclipse). It is that communication that has failed.
I have a feeling you either need to contact Atmel or wait to hear from one of their staff here. It seems odd that the One! works for ISP (proving that cabling/USB driver and so on are working) but does not work for dW or JTAG. Atmel will hopefully be able to help you determine the reason why.
cshutchinson
PostPosted: May 18, 2012 - 04:45 PM
[quote="clawson"]
Thanks, yes, I will try to contact Atmel. This problem was alluded to here on AVRFreaks a few weeks ago, but no solution was ever offered. This may well indeed be a bug. Will report back on what Atmel says if I can get in touch with them.
Update: Support ticket posted to Atmel.
sikolymester
PostPosted: May 18, 2012 - 08:36 PM
Try to pull up the reset pin to vcc with a ~20kohm resistor.
It might be worth a shot.
cshutchinson
PostPosted: May 18, 2012 - 09:04 PM
Yes, good idea; I just tried 20k and 15k but still get same error message.
I haven't heard back from Atmel support yet, might be a few days. In the mean time, I have a chip that I put in debug mode myself and I am debugging with it fine with the AVRONE. That would be ok if it was the only way, but that shouldn't be required.
cshutchinson
PostPosted: May 22, 2012 - 01:46 PM
Update from Atmel. This is indeed a bug in Studio 6. Here is the official response:
Dear Customer,
Thank you for contacting Atmel.
I’m afraid this is an issue with Atmel Studio 6, where it fails to program DWEN fuse while going into a debug session. I could reproduce the issue here.
As you said, manually programming DWEN fuse enables debugging using Atmel Studio 6, this method can be used. As long as ISP programming is not required, you may keep DWEN programmed. In that case, select ‘Disable Debugging’ instead of ‘Disable DebugWIRE and Close’.
Another temporary solution is to use AVR Studio 5.1.208 for debugging.
We’re really sorry for the inconvenience in this regard.
Best Regards,
Jain Joseph
Atmel Technical Support Team
cshutchinson
PostPosted: May 24, 2012 - 08:25 PM
Atmel was nice enough to email me a new DLL that fixes the problem. If anyone needs it let me know.
jtowich
PostPosted: May 30, 2012 - 04:32 AM
I could use the new DLL. Email to joe@ntsengineering.net. Thanks
