Posted: May 16, 2012 - 07:00 PM |
need a c code to step a stepper in individual steps i.e if i need to move a stepper one step, a function like
MoveSTEPPER(6); should move the motor 6 steps
Regards. |
Posted: May 16, 2012 - 07:15 PM |
| You need it - you write it, what's the problem? |
Posted: May 16, 2012 - 08:05 PM |
The problem is am still a newbie and i tried to develop the code bt was unable.the code i developd is shown below.it can only move the motor four steps or multiples of four.
void ForwardStepperMotor()
for(unsigned int x=0; x < 6; x++)
//Normal Bipolar Stepping,forward
PORTD = 0X50;
_delay_ms(100);
PORTD = 0X48;
_delay_ms(100);
PORTD = 0X28;
_delay_ms(100);
PORTD = 0X30;
_delay_ms(100);
kindly help! |
Posted: May 16, 2012 - 08:37 PM |
How are you driving the motor from PortD?
Jim |
_________________ Jim Wagner
Posted: May 16, 2012 - 08:41 PM |
| Create an array that holds the 4 values you need for assigning to PORTD, keep track of the current index into the array for the current step. Use that in the for loop to step the motor. |
Posted: May 16, 2012 - 09:23 PM |
| Welcome to the AVRfreaks forum. Thank you for filling in your city and country. Please search for 'jones on stepper motors' on google. This is a good explanation of how to drive the stepper motors. There are many projects in the projects section here also. If there are 4 outputs driving the coila and coilb on the low 4 bits of portd, you energize them in this sequence:0b0101 0b0110 0b1010 0b1001 then back to the start 0b0101. Step thru the table backwards to step backwards. |
Posted: May 16, 2012 - 10:26 PM |
its a Bipolar stepper motor and am using two Toshiba half-bridge chips(TA7291SG) to drive the motor.
am wondering if its possible to write a function that makes it possible to step the motor in single steps according to the parameter of the function eg
stepmotor(int steps)
The function can then be used to step the motor a given number of steps by specifying the function parameter for example,to step seven steps the function can be called;
stepmotor(7); |
Posted: May 16, 2012 - 10:29 PM |
Thanx 4 the quick reply.the sequence makes the motor move 4 steps.is it possible to step the motor a given number of steps eg 2 steps,7 steps
Regards |
Posted: May 16, 2012 - 10:32 PM |
This seems a great solution.could please help with example code,thnx |
Posted: May 16, 2012 - 10:51 PM |
What part of what Koshchi wrote are you having a problem with?
One way to go about it from C would be:
/*** varables section ****/
// array for step values
// index of above array storing current motor position
/*** subroutine section ***/
void stepmotor_cw(int steps) {
//loop until steps = 0
//add one to index
// figure out if index is too big and set to 0 if so
// copy array[index] to stepper pins
// delay some amount to let the stepper actually move
//subtract 1 from steps
// go to loop
void stepmotor_ccw(int steps) {
//subtract one to index
// figure out if index is too small and set to 3 if so
// go to loop
/** main section **/
main(){
//setup portd to be outputs
for(;;){
// your awesome app code gos here
Bonus points for figuring out how to write stepmotor( steps, direction)
Almost every one here is happy to teach you how to fish, however this is not a fish market.  |
_________________ link
i am a NOOO00B!!
Don’t let that undermine what I just said.
Posted: May 17, 2012 - 12:45 AM |
Actually, I would be willing to show him my complete compilable example if I knew that would suddenly make it all coalesce into a sensible result. This is the Instant Of Learning when the Aha! happens.
To Mr. Kumpes from the land of Fast Runners: the dude from San Jose is from the world epicenter of computers, electronics and software innovation. I think it is Safe To Say that if you convert each one of his comments into a syntactically correct c statement, you will have a compilable working program that you and the other freaks can critique and debug. |
Posted: May 17, 2012 - 04:40 AM |
You must also control the timing of the steps.
A sub routine that performs a loop to step a motor more than 1 step that also incorporates time delays can be very poor code if your AVR is doing other threaded tasks.
I set up as Koshchi suggests for the 4 (or other number) steps and then put your step output in a timer interrupt. Simply set the new position of the stepper in a global variable and the timer ISR functions on it's own similar to putting a character in the USART and the hardware performs the timing of the output of all the bits.
So you call a routine to set the stepper at a new position and then check your DRO values (updated by the ISR) to see when the motor has reached that position. That allows you to monitor limit switches, output data and other things while the hardware interrupt controls the smooth ramp speed up and down to the desired position. Yo can't just start a stepper at top speed and stop it on a dime if you plan to use the top speed of a stepper or it will just hum. Use the frequency of the ISR and change the frequency inside the isr after each step. you can also calculate ramp speed using the delta of where the motor is and where it is going as well as change on the fly from 1/8 step to full stepping while at top speed and back down to 1/8 steps (or other smaller steps) depending on the complexity of the driver circuit, current control etc... |
Posted: May 17, 2012 - 06:10 AM |
I'd suggest to read some literature about "C programming" to you. You also should read some book about stepper motor control.
Your questions are quite simple. You'll pay one - two days to study the stuff.
If you haven't got studied it now you'll not be able to solve more difficult problems... IMHO.
Good luck! |
Posted: May 17, 2012 - 06:12 AM |
Hello metron9,
ya, ya, still need to start at the basics.  |
i am a NOOO00B!!
