Posted: May 04, 2012 - 11:59 PM |
I've seen several sites that claim their boards run at 3.3v rather than 5. Doing this would make some downstream designs easier, but I was wondering what risk there is.
Is it based on temperature?, endurance? or are do some items just not work (read digital returns wrong results)?
This has to do with the atmega1284 chip.
I will likely use 5 volts and the level shifter, I'm just not real clear why. |
Posted: May 05, 2012 - 12:55 AM |
Check this graph, according to it the max frequency you can get at 3.3v would be approx 12MHz or so.
So at 3.3v and 16MHz it might not run at all, or not run in a stable manner. |
Posted: May 05, 2012 - 01:05 AM |
All depends if it remains in specs with the combination of 3.3V and 16MHz. Some AVRs will. Some won't.
If its hobby stuff, you can probably get away with it out of specs. Commercial? I would not do it.
Jim |
_________________ Jim Wagner
Posted: May 05, 2012 - 05:19 PM |
| I agree that I should stick with the specs, but was wondering how would you know what failed? would there be intermittent problems or just not work, or wrong computations or all of the above. |
Posted: May 06, 2012 - 08:53 AM |
Search for "overclocking".
The datasheet will not tell you what happens when you violate specification. |
_________________ No RSTDISBL, no fun!
Posted: May 06, 2012 - 10:07 PM |
Looks like if its an xmega, the elpm instruction takes a poop at about 2x the speced max clock. We should collaborate on a test program that would light one of the stk500 leds (or leave it lit if the avr hung up)
if failure was detected in eeprom, ram, flash, ext mem bus, timers, etc. I have no idea how to write these modules but if they ran round robin, you could stick a model X avr into the stk and keep cranking up the clk till the lights came on and publish the results. Like the seti project. |
Posted: May 07, 2012 - 03:39 PM |
| Propagation delay and transition times increase at lower voltage. Look at e.g. a 74HC04 datasheet and you'll see these times @2V are 2-5 times longer than the times @4.5V. So running too fast for a given voltage (given propagation/transition times) means you're running on the ragged edge of whether all the internal setup times are met, which will eventually mean random errors, temperature and voltage sensitivity, etc. |
Posted: May 07, 2012 - 04:28 PM |
There may not be any one consistent failure.
With over-clocking, one common reported failure is EEPROM write at temperature extremes.
But, whether or not that is what you might see is anyone's guess.
Jim |
