Posted: Apr 26, 2012 - 09:15 AM |
Stepping through the code in a simulator (such as in AVRStudio) may be very instructive, too; although it may take some effort to set it up.
Johan (or others): is there any truly step-by-step guide for this?
JW |
Posted: Apr 27, 2012 - 02:33 AM |
Thanks, your reply was very helpful. But I still have some doubts.
1. r26,r27 is X-low/high byte register (so is it true that r24,25 are also low/high byte; r22,r23 - low/high & so on..) [sorry, if it sounds silly but that's what I feel from the code]
2. Couldn't understand the values given to r24...r27. But if I want to fill RAM with 0xAA from 0x21ff-0x200 then is this code correct?
.section .init0,"ax",@progbits
LDI r27; CLEAR X HIGH BYTE
LDI r26, 0x21FF; SET X LOW BYTE TO 0X21FF LOCATION
LDI r25; CLEAR HIGH BYTE
LDI r24, 0X200; SET LOW BYTE TO 0X200 LOCATION
LDI r16, 0XAA; VALUE TO BE STORED
LOOP:
ST X, r16;
SBIW r26,1; DECREMENT LOCATION BY 1
CP r26,r24; COMPARE LOW BYTES
CPC r27, r25; COMPARE HIGH BYTE WITH CARRY
BRNE LOOP; BRANCH IF r27 & r25 ARE NOT EQUAL
Can I write:
ST X, r16;
as
ST X-, r16;
3. r16 register is used to set the value 0xAA (just like we use a variable in C), instead we can use r0, r1..or r15. Am I correct?
Thanks once again
JohanEkdahl wrote:
Herte are some cluse:
Posted: Apr 27, 2012 - 05:05 AM |
You can feel all you like. If you want facts then download the AVR Instruction Set document and use it. |
Posted: Apr 27, 2012 - 05:26 AM |
Hey, it's not like that (you guys are great, you catch every single word ).I downloaded the manual and read it...but I couldn't find or may be couldn't get it into my head correctly, that's why I said that. The manual is still open, am compiling the code and trying to solve errors & warning..if you don't believe..here are some of them after compiling the exact code written above(by me):
../RamInit.S: Assembler messages:
../RamInit.S:3: Error: `,' required
../RamInit.S:3: Error: garbage at end of line
../RamInit.S:4: Warning: constant out of 8-bit range: 8703
../RamInit.S:5: Error: `,' required
../RamInit.S:5: Error: garbage at end of line
../RamInit.S:6: Warning: constant out of 8-bit range: 512
Posted: Apr 27, 2012 - 06:07 AM |
At least I got rid of the messages with this:
clr r27; CLEAR X HIGH BYTE
LDS r26, 0x21FF; SET X LOW BYTE TO 0X21FF LOCATION
clr r25; CLEAR HIGH BYTE
LDS r24, 0x200; SET LOW BYTE TO 0X200 LOCATION
Posted: Apr 27, 2012 - 08:22 AM |
I am debugging the program and watching the memory & registers. The program does fill 0xAA but at the wrong places (from 78-60). I don't understand why? The start & end address that I've given is 0x200-0x21FF respectively.
Somebody please point out my mistake... |
Posted: Apr 27, 2012 - 08:35 AM |
You CANNOT put a 16 bit value into a 8 bit register, that is loading r26 FROM address 0x21FF
same thing here |
Posted: Apr 27, 2012 - 08:43 AM |
You can use the code from here:
http://www.rn-wissen.de/index.php/Speic ... -Verbrauch
#include <avr/io.h> // RAMEND
#define MASK 0xaa
// !!! Never call this function, it is part of .init-Code
void __attribute__ ((naked, used, section(".init3"))) init_mem (void);
void init_mem (void)
// Use inline assembler so it works even with optimization turned off
__asm volatile (
"ldi r30, lo8 (__heap_start)" "\n\t"
"ldi r31, hi8 (__heap_start)" "\n\t"
"ldi r24, %0" "\n\t"
"ldi r25, hi8 (%1)" "\n"
"0:" "\n\t"
"st Z+, r24" "\n\t"
"cpi r30, lo8 (%1)" "\n\t"
"cpc r31, r25" "\n\t"
"brlo 0b"
: "n" (MASK), "n" (RAMEND+1)
If you want a different start, use a different start address. The example above uses __heap_start which starts after static data.
For the start of RAM, you can use __data_start which is defined in the linker script, just like __heap_start.
I'd discourage to write this in C for several obvious reasons like, e.g. not overriding the return address of the worker. |
Posted: Apr 27, 2012 - 11:18 PM |
js wrote:
same thing here
Thanks so much, it was very helpful (also understood why the values for R24...R27 were like that). Got the desired output.
Thanks everybody! |
