alexe100
PostPosted: Apr 21, 2012 - 12:34 AM
consider figure in attachment.
I have an avr raven which brings nodes, headers and board number one. I also bought an avr dragon to program raven nodes. But it seems that i lack of the board number 2. I need to bue it also but i dont know its name.
Can you help me?
Thanks a lot
Alex
kk6gm
PostPosted: Apr 21, 2012 - 02:08 AM
Looks like it translates between the AVR 6-pin and 10-pin programming connectors.
sbennett
PostPosted: Apr 21, 2012 - 06:48 AM
Board #2 with the white flex cable is an Atmel JTAG PROBE, part of the JTAG ICE mk-II.
Can be purchased as a replacement part - ATJTAGPROBE, but is only useful with the JTAG ICE mk-II.
It makes more sense to build your own adapter from the Dragon.
Stan
alexe100
PostPosted: Apr 21, 2012 - 09:55 AM
i want to program raven with dragon and this was the only setup i found . this board can be replaced by a bread board right? does anyone knows the pin connects?
thanks a lot
alex
PostPosted: Apr 21, 2012 - 10:12 AM
It looks to me as if the Raven has a miniature 5x2 JTAG connector with 0.05" spacing.
Your adapter board #1 simply converts from 5x2 0.05" female header to 5x2 0.1" female header.
This would plug directly onto the Dragon 5x2 0.1" male header pins.
The adapter #2 looks superfluous. If the adapter has male 5x2 0.1", then you put a short 10way female-female ribbon in between.
The Dragon manual can be seen via Studio4 Help.
I guess you already have read your Raven manual.
JTAG programming can be facilitated by connecting a JTAG
ICE mkII to the 50-mil pin header J301 (ATmega3290P) and J204 (ATmega1284P). A
total of 5 50-mil pin headers and one 50-mil to 100-mil converter are supplied with the
RZRAVEN kit.
PostPosted: Apr 21, 2012 - 01:06 PM
ebay certainly has loads of 6 to 10 converters for 0.1" pitch. It may well also have adapters for the stupid 0.05" stuff that Atmel has started to use of late.
sbennett
PostPosted: Apr 21, 2012 - 10:39 PM
Board #1 appears to be one of the Atmel JTAG/ISP standoff kit (ATAVR-SOAKIT) at $39US.
There doesn't seem to be much out there to adapt or breakout from 2x5 0.05" header sockets. This was an issue with the AT90USBKey in which I/O are on pads for a 0.05" header, where one solution was the wizbang wings, made by a fellow freak, however that enterprise seems to have vanished as lamented here. The only adapters/breakouts I could find were part of JTAG debugger kits.
MCPros offers 2x5 0.05" 20CM cable assemblies for their daisy system, but no breakouts or adapters. Same for GHI Electronics gadgeteer stuff.
Stan
PostPosted: Apr 21, 2012 - 11:34 PM
RZRAVEN kit.
I really don't see the problem. It appears that you already get a 0.05" female to 0.1" male adapter.
You should be able to connect directly to the Dragon JTAG with a short regular ribbon.
If alexe100 is in Europe, I could post him a ribbon.
I would never connect anything like in the photo. It looks uncomfortable. Something will break.
alexe100
PostPosted: Apr 23, 2012 - 10:26 AM
Yes I am from Europe (PT) and yes I already have the Board Atmel JTAG/ISP standoff kit (ATAVR-SOAKIT) which is included in the RAVEN kit.
Well, I already have this list of parts:
3 RAVEN nodes (one is USB)
1 ATAVR-SOAKIT board (included in RAVEN KIT)
5 male to male headers (included in RAVEN KIT)
1 Dragon
My big doubt is how to connect this to the dragon board because dragon board seems a "flat" board just with little holes no no conventional plugs/headers.
One more important info:
My base skill are not electronics. I bought this kit because I want to develop firmware middleware and software for RAVEN. I never thought that I would need to solder things in order to put this to work Sad
Thanks a lot
Alex
PostPosted: Apr 23, 2012 - 10:59 AM
Which country is PT ?
Email me your address and I could post you a 10-way ribbon.
Your Dragon should come with JTAG, ISP and VCC/GND headers populated.
You can read the Dragon Manual via Studio4->Help->AvrTools menu.
Figure 3.12 shows how to connect to JTAG.
The Dragon is an excellent kit. It seems unfortunate that they do not supply a 6-way ISP ribbon and a 10-way JTAG ribbon. This would only add an extra $1.00 to the selling price.
When you connect "JTAG/ISP standoff kit" to the Raven, do you see 5x2 0.1" male header pins?
PostPosted: Apr 23, 2012 - 11:00 AM
Portugal? (or at least the .pt internet domain is Portugal: http://en.wikipedia.org/wiki/.pt )
alexe100
PostPosted: Apr 23, 2012 - 12:07 PM
Yes it is Portugal (using the Internet domain for short)
When you say "email me" is avrfreaks private msg, right?
Thank you David
Alex
PostPosted: Apr 23, 2012 - 12:22 PM
Email means my direct email address.
PM means via AvrFreaks.
Regular correspondence is easier through regular email.
Use PM if you want to keep your email address private.
PostPosted: Apr 23, 2012 - 12:36 PM
Look at the bottom of every post by David. There is an email button.
PostPosted: Apr 23, 2012 - 01:10 PM
I learn something new every day!
I had never noticed the [email] button.
I see that Johan has a [www] button. Perhaps I should give that a go.
Edit. @Johan, Well that was a waste of time.
alexe100
PostPosted: Apr 23, 2012 - 02:19 PM
I never saw that button in there... Smile
Alex
alexe100
PostPosted: Apr 23, 2012 - 02:28 PM
David, as that button (email) did not worked for me I sent you a PM.
Alex
PostPosted: Apr 23, 2012 - 03:46 PM
Mr. Green
