Posted: Jan 27, 2012 - 09:21 AM |
Its saying it expects a ) before the *.
Can anyone explain this ?
I already did:
Let's see that line in context. Will the "Electronic_Serial_Number" type be known to the compiler at the moment it reaches this line?
So did David
I would also guess that Electronic_Serial_Number has not yet come into scope.
I also showed a complete example of using struct pointers:
typedef struct {
int n;
char c;
} my_data_type;
void init_data(my_data_type * p) {
p->n = 12345;
p->c = 'A';
my_data_type mydata;
init_data(mydata);
if (mydata.n == 12345) {
UART_send(mydata.c);
Are you going to bother reading the replies you are given or not?
As for your ESN thing. the only reason you can use:
#include <stdio.h>
int * n;
printf("%d", *n);
And the compiler doesn't moan about not knowing what "int *" is, is because it's a type already known to the compiler. But if you try:
#include <stdio.h>
int * n;
mytype * foo;
printf("%d", *n);
You will get:
error: expected ')' before '*' token
because in this program the compiler has no idea what "mytype" is. I can correct that in one of two ways:
#include <stdio.h>
typedef struct {
int n;
char c;
} mytype;
int * n;
mytype * foo;
printf("%d", *n);
or
#include <stdio.h>
#include "contains_type_definition_for_mytype.h"
int * n;
mytype * foo;
printf("%d", *n);
Posted: Apr 19, 2012 - 11:05 PM |
Like Martin I prefer the typedef route:
typedef struct {
int n;
char c;
} my_data_type;
p->n = 12345;
p->c = 'A';
init_data(mydata);
The one time you use a struct tag would be for self-reference:
typedef struct mydata_tag {
int n;
char c;
struct mydata_tag * next;
} my_data_type;
(usually when creating linked lists).
I hate compiler warnings. They are usually a good indication I have done something wrong. When passing a pointer to a structure as in your example I get this:
../GPS_Functions.c:3: warning: 'struct gps_st' declared inside parameter list
../GPS_Functions.c:3: warning: its scope is only this definition or declaration, which is probably not what you want
It gives an error if I take the struct out of the function header.
typedef struct {
int wYear;
} gps_st;
Function declaration:
void GetLocalTime(gps_st*);
Function Call:
GetLocalTime(&gps_data);
Function:
void GetLocalTime(struct gps_st * foo){
If I remove "struct", it will not compile. I have tried it with and without the space after *. |
_________________ I use:
AS6 (under duress)
WinAvr 20100110
Windows 7 & XP
STK 600
AVR ONE!(broken and Atmel won't fix)
JTAGICE3 (only works with AS6)
AVRISP II
So far - '88 '2560
Sometimes my own RTOS
Posted: Apr 19, 2012 - 11:32 PM |
| You definitely have to clean up this mess:
#include <avr/i2c.c>
#include <avr/macro.c>
#include <avr/spi.c>
#include <avr/MCP23S17.c>
#include <avr/CM404.c>
#include <avr/buzzer.c>
#include <avr/heater_cooler.c>
#include <avr/LEDs.c>
#include <avr/motor.c>
#include <avr/usart.c>
#include <avr/external_EEPROMs.c>
#include <avr/MCP4921.c>
#include <avr/1284P_AD.c>
#include <avr/switches.c>
#include <avr/AVR_setup.c>
#include <avr/DS2401.c>
- Never (as in NEVER!) include C files! Write proper prototypes for global variables and functions, write global macros as needed and typedefs. And put them in headers.
Include these headers in the C files as needed. That way C files can communicate.
- Never (as in NEVER!) put your files as system files. They are no system files. Use #include "foo.h" or perhaps #include "path/foo.h" and tell the root directory of your project include paths to the compiler by means of -I root.
Posted: Apr 19, 2012 - 11:51 PM |
Confused.
My structure is in a header file.
My comment was only about passing the pointer. I get compiler warnings.
Not sure if you caught that I was only saying that if I did the structure pointer passing as described in the quoted passage, it throws errors. I gave small snippets of my code showing that I am passing the pointer in the exact same way. My structure is in fact inside a .H file that is included.... |
AS6 (under duress)
WinAvr 20100110
Windows 7 & XP
STK 600
AVRISP II
So far - '88 '2560
Posted: Apr 19, 2012 - 11:53 PM |
That code did not come from me. Not sure if you are replying to my message or some other message. |
AS6 (under duress)
WinAvr 20100110
Windows 7 & XP
STK 600
AVRISP II
So far - '88 '2560
Posted: Apr 20, 2012 - 12:07 AM |
ibapah wrote:
Confused.
That happens if you append your question to an old thread.
Someone might come around and comments on the old original code instead of your new one.
The "struct" here is wrong.
And what does "will not compile" mean? Don't you think that the concrete error message might be of use for us? |
Posted: Apr 20, 2012 - 12:32 AM |
| I wish I could. It was complaining of expecting a ( or ; or something. But right after posting that note, the compiler warnings with the "struct" stopped. No idea. I had built all multiple times. Nothing changed that I know about. Just quit throwing warnings. Actually, that is not totally true, I ran the code with the simulator. That is what caused the warnings to stop. I guess if they come back I will make another posting here along with the actual error when the "struct" is removed. |
AS6 (under duress)
WinAvr 20100110
Windows 7 & XP
STK 600
AVRISP II
So far - '88 '2560
Posted: Apr 20, 2012 - 01:11 AM |
As someone who pretty much ALWAYS includes C files, I'll bite. Never? Is it better to put everything into one single file?
(Again, I am not saying that everyone should forget about linking and never learn what a linker is. If someone includes C files just because he/she does not know any better - that is bad and it should be pointed out. But to never include? I say never say never.) |
Posted: Apr 20, 2012 - 01:50 AM |
I have multiple C files, but I don't use include. I just tell the IDE/project whatever it is called there are multiple source files. I have one (or more) header files with all function declarations and global variable declarations. But the C files don't have to be included.
Not sure the danger in including c files, but with the IDE/project essentially wrapping it all together in a project for you, there is no need.
I think I am missing SprinterSBs main point. |
AS6 (under duress)
WinAvr 20100110
Windows 7 & XP
STK 600
AVRISP II
So far - '88 '2560
Posted: Apr 20, 2012 - 09:16 AM |
Ignore it for now - as Stefan told you your post triggered Georg-Johann to read/reply to the original post - nothing to do with what you were asking. Anyway just to confirm what Stefan said. If I take the example code I posted to this thread:
typedef struct {
int n;
char c;
} my_data_type;
p->n = 12345;
p->c = 'A';
init_data(mydata);
and compile that I get:
avr-gcc -c -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=8000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort
-enums -Wall -Wstrict-prototypes --save-temps -fverbose-asm -Wa,-adhlns=./test.lst -std=gnu99 -MMD -MP -MF .dep/test.o.
d test.c -o test.o
test.c: In function 'main':
test.c:14: error: incompatible type for argument 1 of 'init_data'
test.c:16: warning: implicit declaration of function 'UART_send'
The reason for that is that I missed the & as the function invocation was supposed to pass a POINTER to the struct, not the struct itself (we just fell foul of something like this in real code the other day when a 250K struct instead of a pointer to it was being passed and crashing the stack in a DSP RTOS - that was actually because of C++'s pass by reference mechanism which makes it easier to make this error). The code should have read:
init_data(&mydata);
in which case you only get the warning:
and that's simply because this is an incomplete test program.
In case you missed it the whole point of typedef'ing a struct and avoiding the use of a tag is for the very reason that you don't then have to sprinkle you code with the word 'struct' all over the place. |
