Posted: Mar 29, 2012 - 09:11 PM |
It includes GCC 4.7.0
How close to a 4.7.1 are you? I think that's the one everyone's waiting for!
Thats more up to the GCC folk than me
It typically takes me a few hours to put together a new package if I don't need to port anything, so I should be able to mave fairly quikly once 4.7.1 is announced. |
Posted: Jul 10, 2012 - 11:32 PM |
MHV AVR Tools 20120709 has been released:
http://www.makehackvoid.com/mhvavrtools-20120709
- Bump to GCC 4.7.1 and Binutils 2.22.52.20120702 (development snapshot)
- Enable LTO
- Enable XMega microcontrollers
Windows (Atom or greater), Linux x86 (Atom or greater) and Linux x64 (Sandybridge or greater) binaries are available now.
OSX will follow soon. |
Posted: Jul 10, 2012 - 11:34 PM |
This release was a real pain to push out. I added a bootstrap step that first builds a native, current compiler and then builds the rest from that. When building AVR binutils and GCC, libtool kept installing the libtool wrappers instead of the actual executables.
I ended up building these components using the MinGW shipped compilers instead. |
Posted: Jul 11, 2012 - 07:53 AM |
There are some bugs in binutils. See the patches that the following 4.7.1 + 2.23 release applies:
avr-gcc-4.7.1-rc1-mingw32.zip!/source
in
http://sourceforge.net/projects/mobilec ... 20(Win32)/
Some of these issues are upstream meanwhile, others are not... |
Posted: Jul 11, 2012 - 12:01 PM |
Thanks Sprinter  |
Posted: Jul 11, 2012 - 06:37 PM |
| FYI, with the MHV tool, my project build to 15670 bytes, with the 4.7.1 of SprinterSB it is 15460 bytes. |
Posted: Jul 12, 2012 - 08:09 AM |
Posted: Jul 13, 2012 - 03:17 PM |
Posted: Jul 14, 2012 - 12:30 AM |
Posted: Jul 14, 2012 - 11:24 AM |
I found that but it appeared to be cold dead... and also the documentation was, ehm... lacking some details... I couldn't get to accept it more than one default path to system includes whereas gcc uses two... it appered to work on manually preprocessed source somehow, though...
Aren't there any usage hints for it?
JW |
Posted: Jul 14, 2012 - 11:27 AM |
Posted: Jul 14, 2012 - 11:28 AM |
Unfortunately no - I haven't gotten around to using it myself :/
I use Eclipse CDT's Codan feature and CPPCheck myself. |
Posted: Oct 09, 2012 - 11:49 AM |
Posted: Oct 09, 2012 - 01:28 PM |
This throws an error from the dynamic liner that libiconv-2.dll cannot be found.
In my canadian cross builds for MinGW32 this error does not occur, so is this a misconfiguration from mhv side? |
_________________ avr-gcc News • ABI • Options • 4.8-Windows • Inline Asm
Posted: Oct 09, 2012 - 01:34 PM |
| Some multilibs are empty, namely the ./tiny-stack and ./avr25/tiny-stack ones. This means something more went wrong. |
Posted: Oct 09, 2012 - 01:50 PM |
Eep, something bad must have happened between building and packaging.
I'll rebuild tomorrow and see if the problem reproduces.
Cheers |
Posted: Oct 09, 2012 - 02:25 PM |
I just did a clean install and avr-gcc works, and libiconv-2.dll in installed.
If the bin directory is not in the path, you may see this error. If you did not select adding MHV AVR tools to the path at install time, you will either need to launch "MHV AVR Shell", or run the avrvars.bat from the installation in order to set up the path.
I'll need to read up more on the tiny stack issue, but it seems related to:
http://savannah.nongnu.org/bugs/?35407 |
Posted: Oct 09, 2012 - 06:30 PM |
I don't set PATH because I have around 20 versions / flavors of foo-gcc. Calling the tools by means of their absolute paths works under Linux and Windows for my builds.
With these builds, it also works if LTO is used which needs liblto_plugin.dll. No setting of PATH is needed.
The difference might be that I prefer --disable-nls with binutils and GCC. Rationale is that if people report problems and they post diagnostics (errors, warnings, fatal messagas, ...) it is not helpful if they are in Klingonian or Elbish or Rongorongo...
AVR-Libc #35407 is work in progress. AVR-Libc does not automatically adopt GCC's multilib layout fromso that each multilib change has to be hand coded in the build machinery. |
