Posted: Mar 23, 2012 - 04:38 PM |
Maybe that page should be moved to a more common place...
The AVR-LibC user manual perhaps? |
Posted: Mar 23, 2012 - 05:04 PM |
wek wrote:
SprinterSB wrote:
This works for me (Win2000) with exace the same k.c source and command line. The only difference is the OS and that I use a non-quoted, nix-friendly path name:
32-bit Vista here, but using the short directory names (C:\PROGRA~1\ etc.) made difference indeed.
If it's approved that m$ish path-names cause the trouble, I'd write a line along with the links to the zip.
@Magister: Does it work if you use sane path names?
so the "just drop it at AVR-Libc because there is no better place"?
For the text in question I'd very much prefer a less static, wikiesque site. I am thinking of the German mikrocontroller.net or roboternetz.de/rn-wissen.de wiki. In particular the rn-wissen.de has a much more appealing web-typography and -layout than the mikrocontroller.net |
Posted: Mar 23, 2012 - 05:21 PM |
Thanks Johann for the hints.
One more question on -flto, if you permit.
volatile char c;
__asm__ volatile (
"lds r16, c"
:::"r16"
results in
`c' referenced in section `.text.startup' of C:\Users\OM7ZZ\AppData\Local\Temp\cclowUTz.ltrans0.ltrans.o: defined in discarded section `COMMON' of C:\Users\OM7ZZ\AppData\Local\Temp\ccgEBL3F.o (symbol from plugin)
collect2.exe: error: ld returned 1 exit status
I roughly understand the reason; the question is, how to avoid the error.
JW |
Posted: Mar 23, 2012 - 05:25 PM |
Not at all. Put it in the one place where everyone using avr-gcc goes to learn how to use it. The precedent (for explaining command line options) is already set by this page there:
http://www.nongnu.org/avr-libc/user-man ... tools.html
I spend my life on this message board pointing people at:
http://www.nongnu.org/avr-libc/user-manual/index.html
as the hub of info for using avr-gcc. It would seem a shame to water this down and splatter it across 20 different documents/web sites. If all questions can be answered by: "Visit this link and read everything there" then surely that's a good thing?
Or do the GCC developers somehow look down their noses at the lowly AVR-LibC developers and don't want to "give them the credit" or some other * like that? |
Posted: Mar 23, 2012 - 05:34 PM |
I agree with Cliff.
While from a systemic point of view putting gcc-specific information into libc-related documentation is "not-right thing", the avr-libc documentation *is* the defacto collection of basic wisdom, whether you like it or not.
As a matter of fact, thanks to this "improper" way of doing things, the AVR GNU *toolchain* may well be one of the best documented variant of all GNU processor targets...
JW |
Posted: Mar 23, 2012 - 05:45 PM |
SprinterSB wrote:
In particular -mstrict-X -fno-tree-loop-optimize shows pleasant results.
Without attempting to understand the implications of these switches or their relationship to my programming habits, I added both to the experimental setup and they yielded further cca 0.6% (in fact more - maybe around 1% - the reported size includes quite some progmem data too) reduction of the code size (added the result to the "table" I posted above).
I am not going to start the "find the best combination" game - I am a firm believer of "go asm if you want absolute control" approach - but it's nice to know that there are still ways how to squeeze out more juice...
I guess this is one of the things which attracts you to the playing with the compiler, isn't it...
Thanks again,
Jan. |
volatile char c;
__asm__ volatile (
"lds r16, c"
:::"r16"
results in
c is unused and thus may be discarded. Either compile main.c and similar modules that bypass semantics without lto-information, or use something like
char __attribute__((used)) c;
Notice that in the small program above "volatile" is void because there are no accesses to c from C. |
Posted: Mar 23, 2012 - 05:47 PM |
I already use sane path.
I traced down the problem to the delay function
void main(void)
_delay_ms(1);
avr-gcc k.c -o k.elf -Os -DF_CPU=14745600UL -mmcu=atmega2561 -Wa,-adhlns=k.lst -Wl,-Map=k.map,--cref
works fine
avr-gcc k.c -o k.elf -Os -DF_CPU=14745600UL -mmcu=atmega2561 -Wa,-adhlns=k.lst -Wl,-Map=k.map,--cref -flto
lto1.exe: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper: avr-gcc returned 1 exit status
c:/avr/tools/4.7.1/bin/../lib/gcc/avr/4.7.1/../../../../avr/bin/ld.exe: lto-wrapper failed
fails. If I remove the -Os it compiles.
Can you reproduce it? |
Posted: Mar 23, 2012 - 06:21 PM |
SprinterSB wrote:
That's it, thanks.
I would expect that.
So I threw in several dozens of attributes and the m2561 code reduced to 138581 bytes (from 141863), but the functionality is not completely OK. It probably relates to the fact that the data size was also reduced by 4 bytes - I don't think I had data to throw away It probably fell over on some marginally written piece, but I am not going to investigate it at this point.
Thanks again for your work,
Jan |
Posted: Mar 23, 2012 - 06:22 PM |
Magister wrote:
I traced down the problem to the delay function...
Yes, thanks! Reduced to the max:
extern void __builtin_avr_delay_cycles (unsigned long);
int main (void)
__builtin_avr_delay_cycles (1000);
Without the extern decl there is a proper error message. |
Posted: Mar 23, 2012 - 06:34 PM |
You are welcome
When you fill a bugzilla entry for it, PM me the number, I'll add myself on the CC list! |
Posted: Mar 23, 2012 - 08:45 PM |
It's PR52692 |
Posted: Mar 23, 2012 - 09:31 PM |
ezharkov wrote:
[...] did not quite like __attribute__((always_inline)). It said "always_inline function might not be inlinable".
Are the functions declared as inline? |
Posted: Mar 24, 2012 - 09:10 PM |
Hello guys, I'm new to avr programming. I tried building avr-gcc with gcc 4.7.0 and binutils 2.22 and avrlibc 1.8 (latest releases), but I seem to be missing some microcontrollers from the available devices list. Mainly the atxmega128a3u, which I'm currently using.
What are the recommended versions for stable builds, which also include the latest microcontrollers? I don't want to be on the cutting edge, just to be stable (don't really care for size optimizations just yet) |
Posted: Mar 24, 2012 - 10:19 PM |
SprinterSB wrote:
It's PR52692
Thanks for having added me  |
Posted: Mar 24, 2012 - 10:29 PM |
No, they were not. Adding inline helped. |
Posted: Mar 25, 2012 - 11:56 AM |
wek wrote:
volatile char c;
int main (void) {
__asm__ volatile ("lds r16, c" ::: "r16");
Even more instructive than __attribute__((used)) with c would be to make the usage explicit:
char c;
int main (void) {
__asm__ volatile ("lds r16, %0" :: "i" (&c) : "r16");
Posted: Mar 25, 2012 - 01:44 PM |
As Atmel's 4.5.1 toolchain does support that device seek out their patch set and find out what the patch that adds 128a3u actually affects. Then make similar mods. to the files in the toolchain source you are using. IOW backport the patch to 4.7.x |
Posted: Mar 25, 2012 - 02:00 PM |
The Atmel 4.5.1 patchset does not introduce changes for that device. What do I miss?
@admin: Could this sub-thread be broken out? |
Posted: Mar 25, 2012 - 02:16 PM |
They are violating GPL again?
(they have made several issues of 4.5.1 but I don't think they've posed the patch set for the latest one yet).
[I'll split this out later - I have to take the cats for a walk now] |
