milesy
PostPosted: Mar 23, 2012 - 01:27 AM
HI Guys
this is probably going to sound like a dumb question but i am having trouble gettin AVR studio 4 to compile a C programme
Essentially i am getting a cannot find ELF file error - can anyone help pint me in the right direction here (totaly new into this)
milesy
PostPosted: Mar 23, 2012 - 01:50 AM
ok so in another thread i found to disable use Toolchain and point to WIN AVR make and gcc file.
I am now getting a gcc instalation problemm cant excute ccl - no such file or directory.
again any ideas?
milesy
PostPosted: Mar 23, 2012 - 02:04 AM
ok (talking to myself here) i have the gcc linked to the wrong gcc......so now it seems to be doing something but i am getting code errors - can anyone link to a really simple flash led in C for the AT90s8515??
PostPosted: Mar 23, 2012 - 08:11 AM
I checked the datasheet. This should work:
#undef F_CPU
#define F_CPU 1000000UL // change to your CPU frequency
   DDRC = 0xFF;
   while(1) {
     PORTC ^= 0xFF;
     _delay_ms(250);
milesy
PostPosted: Mar 23, 2012 - 09:59 PM
thanks clawson but i get this error with your suggestion above
rm -rf ledflashnet.o ledflashnet.elf dep/* ledflashnet.hex ledflashnet.eep ledflashnet.lss ledflashnet.map
Build succeeded with 0 Warnings...
avr-gcc -mmcu=at90s8515 -Wall -std=gnu99 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT ledflashnet.o -MF dep/ledflashnet.o.d -c ../ledflashnet.c
../ledflashnet.c:4:24: util/delay.h: No such file or directory
../ledflashnet.c: In function `main':
../ledflashnet.c:10: warning: implicit declaration of function `_delay_ms'
make: *** [ledflashnet.o] Error 1
Build failed with 1 errors and 1 warnings...
if i can get a some sample code that works, i will be able to work from there
milesy
PostPosted: Mar 23, 2012 - 10:45 PM
ok i think my problem here is
../ledflashnet.c:3:24: util/delay.h: No such file or directory
help??
milesy
PostPosted: Mar 23, 2012 - 11:05 PM
lol ok found delay.h.....clawson your code was pointing to a different directory - ok so fixed that......compile works 100% however build now gives me
: undefined reference to `_delay_ms'
make: *** [ledflashnet.elf] Error 1
Build failed with 1 errors and 0 warnings...
again help?
ezharkov
PostPosted: Mar 24, 2012 - 12:18 AM
What version of avr-gcc and where did you get it from? Is it WinAVR?
You say "found delay.h" - where did you find it? Normally there should be no need to look for it. It should get installed with avg-gcc and the compiler should "find" it automatically.
If avr-gcc is installed correctly, the following should work:
avr-gcc -o led.elf -Os -mmcu=at90s8515 led.c
milesy
PostPosted: Mar 24, 2012 - 01:23 AM
yes im using winavr
the code called for delay.h using
but i found delay.h in the directory
c:\winavr\include
i then copied it to
c:\winave\avr\include/avr
and changed the code to read
#include <avr/delay.h>
when i do this it all compiles ok but complains about
ezharkov
PostPosted: Mar 24, 2012 - 03:21 AM
milesy wrote:
yes im using winavr
What version?
c:\winavr\include
I have WinAVR-20100110 and I do not see any "include". Again, it would help if you told us what WinAVR version and where did you get it from.
i then copied it to
I assume that winave is a typo. Otherwise do not do that. Do not touch anything in the winavr directory.
If you want to use WinAVR, and you are just starting with avr-gcc, then just download the latest version, which is still 20100110 I believe, install it from scratch, and do not change anything in the winavr directory, do not copy anything, do not add anything, etc.
milesy
PostPosted: Mar 24, 2012 - 04:09 AM
ok ill uninstall redownload and reinstall both avr studio and winavr.....
currently running version 20040404
milesy
PostPosted: Mar 24, 2012 - 04:20 AM
ok now i feel stupid.....resintalled as above an everything now works.....thanks for getting me going
PostPosted: Mar 24, 2012 - 08:14 AM
Why such a VERY OLD version??
milesy
PostPosted: Mar 24, 2012 - 09:26 AM
oh because i first installed avr studio 5 and found i couldnt use the AT90 processor..installed V4 and then started with the errors as listed earlier and read somewhere that the early version of winavr worked better with avr 4.......turns out for me didnt matter but thats why
PostPosted: Mar 24, 2012 - 12:15 PM
2004 is not going to work with the latest Studio. You need a WinAVR from 2006 onwards and obviously the latest (2010) version would be the one to choose.
