fkpwolf
PostPosted: Mar 21, 2012 - 03:37 PM
Before switch:
A---B
C---D
After switch:
A---D
C---B
It can be implemented by 2 common switches. But I need only one so user can operate it easily.
OR I need a IC to implement this?
Fan
PostPosted: Mar 21, 2012 - 03:45 PM
This is a regular DPDT switch.
You could make it with wafers but this would be bulky.
Or design a suitable wafer yourself.
You could also do it with regular gates or in software.
It all depends on what you want to switch.
DocJC
PostPosted: Mar 21, 2012 - 03:46 PM
Well,
This looks like a simple DPDT toggle switch application. Double Pole Double Throw
Feed A and C into the two central terminals.
Flip the switch left and A and C go to B and D.
On the other set of terminals you have B and D flipped, so if the switch is clodsed in that direction A nd C now connect to D and B.
So a single switch can be used, but internally it switches two poles in each of two directions.
JC
Cross posted with David...
ka7ehk
PostPosted: Mar 21, 2012 - 04:33 PM
Is this power or small signal? Analog or logic?
Jim Wagner
fkpwolf
PostPosted: Mar 21, 2012 - 04:34 PM
Thanks for quick response. I search the "DPDT" and it should fill my requirement.
But the size of one DPDT looks a little big for SMD board... Anyway It is not a big problem.
And @David, what't the "regular gate" and "software way", can you give more details? I am quite new guy:)
Fan
fkpwolf
PostPosted: Mar 21, 2012 - 04:36 PM
it carry PWM signal, should be logic.
MBedder
PostPosted: Mar 21, 2012 - 05:46 PM
Oh really?
http://www.sparkfun.com/products/597
ka7ehk
PostPosted: Mar 21, 2012 - 06:30 PM
DPDT switches come in a huge range of sizes. At one extreme, big ones will handle kilowatts. At the other end, little ones will handle microwatts. Methinks you need a little one.
Jim Wagner
meslomp
PostPosted: Mar 22, 2012 - 06:41 AM
make sure you also select the right variant.
make before break, or break before make.
That might keep you from getting nasty surprises....
and think about what will happen during the switching period, wich in your eyes is short, but for your processor might take a long time with a lot of unforseen issues that then appear.
2)tutorial forum
3)Newbie start here
fkpwolf
PostPosted: Mar 22, 2012 - 03:27 PM
I found a IC: ADG888, dual DPDT. http://www.analog.com/en/switchesmultip ... oduct.html
how about this?
ka7ehk
PostPosted: Mar 22, 2012 - 03:48 PM
If it is really a logic signal, then why not CD4051, 74C4051, 74HC4051, or other variants. Readily available. Low cost.
Jim Wagner
PostPosted: Mar 22, 2012 - 04:08 PM
Shirley, you can use your existing AVR PORT pins.
You can either send PWM out on a different OC pin or simply gate it with other GPIO pins.
You can add extra chips if you like, but this seems untidy to me.
fkpwolf
PostPosted: Mar 24, 2012 - 09:16 AM
I checked the page http://ics.nxp.com/products/hc/switches/, looks 4051 is just a SP4T. So If I want a dpdt, I need a 3*spdt chip like 74hct4053, is it correct?
I am wondering why there are not DPDT chip. Maybe they want you to use 2*SPDT to build a DPDT.
fkpwolf
PostPosted: Mar 24, 2012 - 09:18 AM
For my application, all PWM ports are used. But what's your meaning of "gate it"?
PostPosted: Mar 24, 2012 - 09:24 AM
Yes. Any chip is going to be configured as the 'most useful'. e.g. SPDT.
Why not say exactly what you want to do?
Describe in English.
I doubt that you need any external chips at all.
fkpwolf
PostPosted: Mar 24, 2012 - 09:44 AM
I am building a PC Fan controller. I use PWM to control speed of fan. It is simple. But fan has 2 kinds: 3pin and 4pin. For 3pin, I use PWM to driver a voltage bulk to control voltage of fan. For 4pin fan, PWM signal drivers fan directly.
So I want to one PWM signal to driver fan whatever it is 3pin or 4pin. Of course you need software configuration.
Now my plan is to use 2 74HCT4053(I need a TTL enabled one?). 3*SPDT * 2 = 3 DPDT. And use a avr chip to drive the 2 4053(need 3 ports of avr chip). Does my solution work?
Fan
PostPosted: Mar 24, 2012 - 10:00 AM
I presume you are using a Tiny25 or similar 8-pin AVR.
Adding two 4053 chips looks overkill.
I do not know what a 'voltage bulk' is.
I presume it is a 'charge pump' that creates a variable DC voltage.
You want a 3-pin fan to connect to one header, and the 4-pin fan to connect to a different header. Or perhaps the 3-pin just uses 3 of the 4 pins on a single 4-pin header.
Post your schematic. It makes life a lot easier.
fkpwolf
PostPosted: Mar 24, 2012 - 01:48 PM
Yes David, I want 3-pin use 3 of 4 pin on single 4-pin header. So the header can be reused.
And I use a "buck converter": UDN2981. This chip also need PWM to drive it.
Before switching:
OCRB1 pwm---->4pin of fan header
PB1 HIGH--->buck convert--->12v ---->3-pin of fan header
after switching(for 3pin fan):
OCRB1 pwm---->buck convert--> (0v~12v)-->3-pin of fan header
PB1 --> N/A
I hadn't draw schematic for this approach.
scorpdaddy
PostPosted: Mar 26, 2012 - 12:50 AM
Switching a couple of SPDT? Consider:
http://www.ti.com/lit/ds/symlink/sn74lvc1g3157.pdf
Sub $1 parts. SOT23-6 package. Smaller that 4051's.
Plugging a 3 ping connector onto a 4 pin header may lead to many incorrect connections. The extra circuity to protect against incorrect connections may justify the second header anyway?
