Posted: Mar 01, 2012 - 05:44 PM |
| My personal research shows that it is exceedingly difficult to peck a pushbutton with a duration of less than 10ms, and it is just as hard to repeat the pecking faster than 4 or 5 times a sec... 200ms? if your program runs 100 times a sec (every 10ms) and the switch might bounce a couple of times in a couple of ms, you might be unlucky and catch it when its open from a bounce on the first read, so you wont see the switch closure till 10ms later. Whether this meets your 'hard real time' requirement for switch read within one program pass needs further analysis. But the reading will just be delayed one pass, not missed. |
Posted: Mar 01, 2012 - 07:40 PM |
In my earlier post I suggested, as Bob did, a 10 ms. debounce of 10 ms. I picked 10 ms. on the basis that any switch that bounces for more then 10 ms. is a really bad switch, which should be considered faulty and thus thrown out.
So toggling the relay as soon as detecting a press and then doing a 10 ms. locks out any decision making until it is safely after the debounce period.
My experience is that contact bounce rarely occurs in releases, but it has happened on rare occasions! Thus it would be prudent to execute another delay of say 2-3 ms. on the release to once again lock out decision making for another short period.
I doubt whether quick successive pulse by human hand will ever be missed and if they do, it would be because the presses would be considered as "not normal operation".
Having said all that, I really hate delays in any form, and thus would execute it as a state machine, where the make & break delays are implemented by lockout states.
There are many ways to skin a cat! (Sorry to the pussy lovers!) |
Lee -.-
Posted: Mar 01, 2012 - 08:36 PM |
bobgardner wrote:
Nope. Not if the interval between switch reads is longer than the bounce interval.
That IS debouncing. |
Posted: Mar 01, 2012 - 08:43 PM |
| Naaah. Its just a delay. Debouncing is a big complicated interrupt handler that shifts bits into a register and counts how many are hi and lo. Byzantine. |
Posted: Mar 01, 2012 - 10:59 PM |
| sometimes putting a cap across a switch will remove the need for debouncing.There's probably as many solutions as there are questions... |
Posted: Mar 01, 2012 - 11:09 PM |
| IMHO Anything done to overcome bouncing, is de-bouncing! |
Lee -.-
Posted: Mar 02, 2012 - 01:23 AM |
Sounds reasonable to me.  |
Posted: Mar 02, 2012 - 06:30 AM |
| Can anyone post a program that proves bouncing exists? This might be 'Much Ado About Nothing' |
Posted: Mar 02, 2012 - 06:52 AM |
Bob. I don't have code to post right now, but I've seen bounce effecs many times on the STK-500.
It exists. |
Posted: Mar 02, 2012 - 07:52 AM |
Piece of pie.
1. Set up a port for 8 outputs & 8 LEDS
2. Set up an external interrupt with a SPST switch of some sort
3. In the ISR execute
PORTx+=1;
Press the button. It wont be long before you have multiple LED increments.
QED
This is the basic technique that I used to show students contact bounce.
Some buttons are noisier than others of course and occasionally some really crappy switches will bounce on release as well. |
Lee -.-
Posted: Mar 02, 2012 - 10:21 AM |
MASNSN:
Try this
//Atmega8, 8 MHz
ISR(TIMER0_OVF_vect) //ovf 8 ms
static uint8_t state;
//if pinb.0=0 in 8 subsequent interrupts
//then toggle portb.1
if(bit_is_clear(PINB,0)) //if buton pressed
state++;
if(state == 8) PORTB ^= (1<<1); //toggle Led
else state = 0;
DDRB = 0b00000010; //portb.1 Led
PORTB = 0b00000001; //portb.0 buton, pull-up
TCCR0 = (1<<CS02); //prescaler 256
TIMSK = (1<<TOIE0); //enable timer0_ovf
sei();
for(;;)
Posted: Mar 02, 2012 - 10:23 AM |
I can't believe I just read that - can someone pinch me? |
Posted: Mar 02, 2012 - 01:55 PM |
| My point was if we have to read a switch that bounces a couple of times over a several ms interval and the switch actuation interval is also in the ms range, then there is a problem. If a human is pressing the switch, program the computer to not read the switch faster than the human can press it, then the problem goes away. I guess there are machines that have limit switches that can be actuated at 200Hz (5 ms). A couple of ms of bounce would be a problem. Needs a filter or some help. |
Posted: Mar 02, 2012 - 06:25 PM |
With all of the talk about debouncing on this forum over the years, I'm surprised that few people seem to have actually run Jack Ganssle's well-known experiment.
I did just that several months ago after having purchased several different types of switches for a project. Some were ordinary normally-open, momentary-contact pushbutton switches and others were SPST toggle switches and one was an old-style pull-on, push-off automotive type.
All were hooked up to my oscilloscope and tested semi-extensively.
What I found:- There was a wide variety of bouncing behavior. One pushbutton (Mouser P/N 112-R13-502A-G/B) had virtually no bounce on closure while a SPST toggle switch (bought at a local store) had up to 12 distinct bounces after closure.
- The worst case for all switches that I tested was 2320 usec (2.3 milliseconds) of bouncing. Yes, that was the same 12-bouncer (a baton-style SPST toggle switch) mentioned above.
- Bouncing on switch opening was rarer, but it certainly did happen, most frequently with that same SPST 12-bouncer toggle switch.
What I saw was not totally unexpected, but it was in some ways still an eye-opening experience. It wasn't too long after my Ganssle-style experimentation that I finally got motivated to write up a test app based on the well-known, efficient Peter Dannegger ('danni') debounce algorithm. Shortly thereafter, that test code was incorporated into all pertinent project code of mine. |
Posted: Mar 03, 2012 - 11:43 AM |
I think we maybe need OP to take a step back and describe exactly what kind of button/switch he is talking about. I was assuming something like:
or maybe:
but not:
or
(which is actually a pushbutton that toggles)
It is the first kind of button clawson. Anyway I found the solution |
Posted: Mar 03, 2012 - 11:47 AM |
chartman wrote:
This is not what I need. What I exactly need is debouncing
1. You press the button a led is on
2. You release the buttont the led remains on
3. You press the button again the led is turned off
4. You release the buttont the led remains off
5. You press the button again and led is once again on and so on
Poor old MASNSN he must be really confused now. He was right all along in asking about TOGGLE.The 'quote' above is still wrong my friend.... what you are describing is a 'toggle' implementation of a switch, not 'debounce'.
To get a debounce you will need to insert a delay between steps 1&3 (or 2&3) somewhere in your software.A suggestion would be a minimum of 10milliseconds.
I hope that helps you understand a bit clearer.
People in forum said that this behaviour is 'debouncing' and not 'toggling' but anyway finally I reached my goal and found the solution by myself |
Posted: Mar 03, 2012 - 11:56 AM |
Folks
Thank you all, I found the solution, I wrote the code that helps me toggle two leds at once one green led for the mode ON in PINB0 and one another red led for the OFF mode in the PINB2.
DDRB |= 1<<PINB0;//assigning pin0 as output
DDRB &= ~(1<<PINB1); //PINB1 as input
DDRB |= 1<<PINB2;//assigning pin0 as output
//Set the initial statuts of the both leds
PORTB|=1<<PINB0;
PORTB&=~(1<<PINB2);
//This is a flag to keep the status
int pressed = 0;
/*bit_clear is a simple routine to check whether a pin is high it is simple to write as a function or a macro*/
if(bit_clear(PINB,1))
if(pressed ==0)
PORTB^=1<<PINB0;
PORTB^=1<<PINB2;
pressed = 1;
pressed = 0;
Finally it is important or place a ceramic 22pF capacitor in the legs of the button to prevent the oscillation effect when pressing and releasing. I did the experience and it works fine. |
Posted: Mar 03, 2012 - 12:11 PM |
Visovian wrote:
MASNSN:
Try this
//Atmega8, 8 MHz
state++;
else state = 0;
sei();
for(;;)
Thank you for the code, really appreciate that however I will let the interrupt for another task. I explain more.
The atmega8 will control three tasks
1.Task 1 is switchinq a relay ON/OFF
2.Task 2 after x minutes it will switch the relay OFF and I will preserve the timer interrupt to this task
3.Task 3 I will use an LCD to display informations to the user countdown until the condition to switch the relay off is met
Any Idea |
Posted: Mar 03, 2012 - 12:28 PM |
| But you have no form of debounce in that code? And a "tact switch" (that's what the first picture is called) are notorious for contact bounce. |
Posted: Mar 03, 2012 - 12:58 PM |
You do not appear to be using an internal pull-up on your switch.
Do you have an external pull-up resistor?
A typical internal pull-up is 30k. Your RC time-constant (with 22pF) is 660ns.
A 1M0 external pull-up would still be 22us.
I would be very surprised if any real-life switches would stop bouncing this quickly.
In practice, there are many tricks for detecting a single button-press.
A 22nF capacitor would probably work fine with a 30k internal pull-up or even 1M.
Even Uncle Bob can only press his guitar picking fingers at a super-human speed.
