Posted: Feb 24, 2012 - 08:03 AM |
| can anyone tell me the schematic diagram of the interfacing between microcontroller ATMEGA168P with the encoder HT640s???/ |
Posted: Feb 24, 2012 - 12:40 PM |
| Are you sure that you really need this IC? It does something that can be done in software in just few lines of code. What you really need is something named "TXM-xxx-LC" in the datasheet. |
Posted: Feb 24, 2012 - 07:13 PM |
well what is the code? |
Posted: Feb 24, 2012 - 07:21 PM |
| so can u tell me the code that can be used at the place of that ic???? |
Posted: Feb 24, 2012 - 07:32 PM |
No, I'm not doing other people homework. Show me your code and I'll correct bugs in it, but I'm now writing the code for you.
Mod: stop using two accounts. |
Posted: Feb 24, 2012 - 07:37 PM |
so, after using that code there will be no requirement of encoder ic,????
is this right??? |
Posted: Feb 24, 2012 - 07:50 PM |
| Correct, you can even use standard UART module. All this IC does is data serialization, which will be done by the UART module. Connect UART TX pin to whatever "TXM-xxx-LC" is and you've got a transmitter. |
Posted: Feb 26, 2012 - 12:05 PM |
if i want to send some signals from microcontroller to my pc and then want to viusulize it.
how to connect both of them????
what softwares exactly should be used??? |
