powerover
PostPosted: Feb 26, 2012 - 03:48 AM
Hi there guys I am new to micro-controller programming and right now I am trying to learn how to get the USART going on a ATmega164PA.
I found this tutorial (the one echos whatever it receives back to the pc) written by Dean Camera (also know as abcminiuser here) and followed it. It was clear and simple and I had the USART setup in no time, except that it isn't working properly and I can't figure out why.
Here is my code, pretty much the same as what is written in the tutorial:
#define USART_BAUDRATE 9600
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
void usart_init(void)
   UCSR1B |= (1 << RXEN1) | (1 << TXEN1);
   UCSR1C |= (1 <<  UCSZ10) | (1 << UCSZ11);
   UBRR1H = (BAUD_PRESCALE >> 8);
   UBRR1L = (BAUD_PRESCALE);
void usart_echo(void)
    char Receivedbyte;
      for (;;)
         while ((UCSR1A & (1 << RXC1)) == 0);
         Receivedbyte = UDR1;
         while ((UCSR1A & (1 << UDRE1)) == 0);
         UDR1 = Receivedbyte;
and here is how I used it in the main:
      usart_init();
      usart_echo(); //not working yet
The micro is running at the default full speed of 8Mhz. The fuse that divide the clock speed by 8 isn't set.
I use Realterm on my PC, the PC is talking to the micro through a USB--serial converter cable, with common ground (the micro is powered by the 5V on the USB). Both TX and RX lines have 20Ohm series resistors.
When I send a character using Realterm, I immediately receives something back, but it is not what I sent, instead I receive some garbage code. This tell me that I got the settings wrong somewhere, probably the baud rate but I can't figure out specifically where I went wrong.
Any kind of help will be much much appreciated.
Thanks guys. [/code]
dksmall
PostPosted: Feb 26, 2012 - 04:21 AM
Did you define F_CPU as 8Mhz?
thygate
PostPosted: Feb 26, 2012 - 04:28 AM
Does the USB Serial converter cable have a TTL level interface, instead of RS232 ?
powerover
PostPosted: Feb 26, 2012 - 04:39 AM
Hi there thanks for the reply. No I didn't. Do I have to define it as such? If so how do I do that? thanks.
powerover
PostPosted: Feb 26, 2012 - 04:43 AM
It is TTL logic level, on the cable itself it says TTL-232R-3v3. I was considering using a level shifter chip but I was told that it should work with series resistors, just to limit the current.
dksmall
PostPosted: Feb 26, 2012 - 05:07 AM
Depends on what you're compiling with. Assuming AVR studio, then it's part of the project settings.
powerover
PostPosted: Feb 26, 2012 - 05:12 AM
I am using avr studio 5...can you please explain a bit more? thanks.
dksmall
PostPosted: Feb 26, 2012 - 05:00 PM
I don't use AS5 some someone else will have to jump in. Typically you should have a menu command that get to Project Properties, and the frequency should be defined somewhere in the properties.
