Magister
PostPosted: Feb 22, 2012 - 12:54 PM
I always change the PATH when I test toolchain, so I know it can find the libiconv-2.dll. LTO not working may be a bug in binutils.
EDIT: binutils version is 2.22.52, not 2.23?
dak664
PostPosted: Feb 22, 2012 - 04:19 PM
srmeister wrote:
I compiled it under MinGW32 so didnt even know that it would work in cygwin.
Well, cygwin does not like your rm.exe during a make clean, e.g. if *.map does not exist it gives an error. I renamed it to rmbad.exe to get the winavr version. The first rm below deletes the file, the second gives an error since the file is gone:
$ rm --version
rm (GNU coreutils) 5.3.0
$ rm *.map
$ rm *.map
C:\avr-gcc47\bin\rm.exe: cannot remove `*.map': Invalid argument
SprinterSB
PostPosted: Feb 22, 2012 - 05:09 PM
Just use rm -f
avr-gcc NewsABIOptions4.8-WindowsInline Asm
dak664
PostPosted: Feb 22, 2012 - 06:58 PM
Well it was the makefile that showed the error and that did use -f. But it still gives an error:
$ echo 1>test.map
$ rm -f *.map
$ rm -f *.map
srmeister
PostPosted: Feb 22, 2012 - 07:19 PM
well, i dont understand why you're using cygwin.
These linux commandline tools are probably made with MinGW (ripped them off of AVR Studio 5), so maybe there is some incompatibility when trying to run a mingw program using cygwin.
maybe what you really need is a linux compiled version of gcc-4.7 so you wouldnt need to use cygwin to emulate the environment... idk.
people reported its working when combined with AVR Studio, when combined with WinAVR, and even standalone combined with some other IDE.
It is not intented to run in every imaginary way possible, otherwise i would have to write an installer and put a huge load of other work and research into it.
If you got THIS problem with rm.exe, just replace it with another rm.exe that works for you(or stop using cygwin). The same advice applies to any file that does not seem to be working.
Maybe it was a bad idea of me to make it "standalone" in that sense to include all these GNU command line tools.
srmeister
PostPosted: Feb 22, 2012 - 07:25 PM
Hello Magister,
please can you specify what command line options you used. Also, what is your OS?
please copy and paste your console output.
binutils is the most recent version of its trunk.
Magister
PostPosted: Feb 22, 2012 - 07:43 PM
I have XP 32 bits, I launch the make under a command prompt. I just added the -flto flag to CFLAGS
lto1.exe: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper: avr-gcc returned 1 exit status
c:/avr/tools/4.7/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/ld.exe: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
Without the -flto, everything works fine.
SprinterSB
PostPosted: Feb 22, 2012 - 09:25 PM
And console output with these?
-flto -v -Wl,-v -save-temps
Magister
PostPosted: Feb 22, 2012 - 09:41 PM
Not a lot of useful info, lto1.exe does a sigsegv
COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega168' '-mmcu=atmega168' '-fno-move-loop-inv
ariants' '-fno-tree-loop-optimize' '-funsigned-char' '-fpack-struct' '-ffunction
-sections' '-fdata-sections' '-fno-inline-small-functions' '-mcall-prologues' '-
mstrict-X' '-v' '-save-temps' '-gstabs' '-D' 'F_CPU=16000000' '-D' 'GRAPHIC' '-O
s' '-L.' '-Lcanlib/src' '-dumpdir' './' '-dumpbase' 'obduino3.elf.wpa' '-fltrans
-output-list=obduino3.elf.ltrans.out' '-fwpa' '-fresolution=-lcan.res'
c:/avr/tools/4.7/lib/gcc/../../libexec/gcc/avr/4.7.0/lto1.exe -quiet -dumpdir .
/ -dumpbase obduino3.elf.wpa -mmcu=atmega168 -mmcu=atmega168 -mcall-prologues -m
strict-X -auxbase obduino3 -gstabs -Os -version -fno-move-loop-invariants -fno-t
ree-loop-optimize -funsigned-char -fpack-struct -ffunction-sections -fdata-secti
ons -fno-inline-small-functions -fltrans-output-list=obduino3.elf.ltrans.out -fw
pa -fresolution=-lcan.res @C:\DOCUME~1\Frederic\LOCALS~1\Temp\ccce08yy
GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr)
compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0,
MPC version 0.9
GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096
MPC version 0.9
[Leaving LTRANS obduino3.elf.ltrans.out]
[Leaving LTRANS C:\DOCUME~1\Frederic\LOCALS~1\Temp\cc6oPJ8t.args]
r failed
srmeister
PostPosted: Feb 22, 2012 - 10:29 PM
either, it is caused by wrong PATH setting, or there is a real bug.
Maybe it is loading some libs from a wrong dir. Could you try setting your PATH in such a way, that the Toolchain dir is first dir, eg. PATH=/toolchain-4.7/bin:$PATH (or its windows equivalent).
If we do deal here with a real bug, im no expert at that, but im sure SprinterSB will try:)
dak664
PostPosted: Feb 22, 2012 - 11:11 PM
There are several other toolchains I use which are easy installations under cygwin, which also tries very hard to use installed windows applications. I have not been able to get Perl serialport.pm working in any other shell, possibly this is a 64 bit .dll problem.
But the rm error is trivial and I am happy to have the 4.7.0 build option.
SprinterSB
PostPosted: Feb 22, 2012 - 11:40 PM
The only way (for me) to track it down is to reproduce this on linux host. IF it works there I have no idea.
Is there still segmentation fault without -fdata-sections?
PostPosted: Feb 22, 2012 - 11:58 PM
@srmeister,
Thankyou very much. You have compiled avrdude-5.11.1 for Windows.
And it works nicely with usbasp and TPI devices !!
Magister
PostPosted: Feb 23, 2012 - 12:15 AM
Yes, I even removed "-ffunction-sections -fdata-sections -Wl,--relax,--gc-sections" and it still sigsegv
