indianajones11
PostPosted: Feb 10, 2012 - 09:53 PM
Compiler support for the new USB enabled Xmegas is at this time only found in AVR Toolchain . There is assembler support for it in Winavr-20100110, if you use AS4.19 . But I've been able to trick Winavr and AS4.18 into compiling for an Xmega32A4U .
Two main parts are needed for this, the startup code must be adjusted and the correct *.h file must be used . Avr-GCC startup code is provided with a general file called gcrt1.S modified and assembled for specific MCUs ( named crt_whatever.o ) and a linker script for a given chip .
What the crt startup code does, in coordination with the script file :
1) Takes care of the IVT including the bad interrupt part .
2) The copy_data routine, when needed .
3) clear_bss routine, when needed .
4) The jump to main and exit code, if the app does return ( somehow ) .
Once the app gets to main, it's *.h file time and we're good to go after that .
The idea is to adjust the gcrt1.S for my Xmega, and use the *.h from the "TOOLCHAIN" in the io.h file instead of the one for Xmega32A4 ( so it would then also have to be used when working with an Xmega32A4 ) . Another option would be to use the regular *.h then add a 2nd *.h that has the "diff'ed" stuff from the USB header file . A compile-time constant would control if the 2nd *.h is needed or not .
Because of the design structure of the Xmegas within a given series, the script file for the Xmega32A4 can be used ( as best as I can tell ) and so the -T option won't have to be passed to the linker ! This Xmega has vectors defined up to #93 ( same as regular one ), then adds two more that are USB related, #125 & #126 . I moved the extra vectors in the *.S file to the top since they would show up in the *.lss file as annoying text . The asm file also has code for a copy_data routine, but I commented that out since the chip is < 64K and in that case libgcc.a will provide it ( clear_bss also ).
Steps, using my #1 & #2 sign. toolchain :
0) Lie like a politician and choose Xmega32A4 as pjt. MCU ( as least your lips won't be movin' ! ) .
1) Add my crtxm32A4U.S source file to your pjt. tree.
2) Add avrlibc's macros.inc, needed for the *.S .
3) Add -nostartfiles as a linker option, which will keep the crt file for Xmega32A4 from being added .
Boom, done ! Here's a short program that produces correct *.lss :
#include  <avr/io.h>
#include  <util/delay.h>
#include  <avr/interrupt.h>
#include  <stdio.h>
uint8_t   bet, winning = 90;
int   main(void){
   ADCA_CTRLA = 0x12;
   while(1);
// vector #126
ISR( USB_TRNCOMPL_vect, ISR_NAKED ) {
   PORTA_DIRSET = 0xAD;
   reti();
// vector #125
ISR( USB_BUSEVENT_vect ) {
   CRC_CTRL = CRC_RESET_RESET1_gc;
I don't know how to strip out the text from the *.S that gets into the *.lss, but there must be an option . Adjusting the crt.S file should allow it to work with the other USB_Xmegas . From what little I know this "should" always work ... We'll see what the experts say about this .
Original gcrt1.S :
http://svn.savannah.nongnu.org/viewvc/t ... iew=markup
macros.inc :
http://jwtanner.com/rtos/macros.inc
Jerome
Edit : I found a bug ( just too good to be true ) ! It's not doing the copy_data and clear_bss routines correctly . The vars aren't being added in, though the routines run . Look in the *.lss and r16 should be compared to 0x02, but it's being compared to 0x00 . I KNOW I saw the build output showing bytes in the data region and it sim'ed fine ( last night ! ) !
Edit 2: Here are my compiler/linker options passed :
/* Compiler switches */
CFLAGS += -fno-inline-small-functions
CFLAGS += -ffunction-sections
CFLAGS += -fdata-sections
CFLAGS += -mcall-prologues
/* Linker switches */
LDFLAGS += -Wl,--relax
LDFLAGS += -Wl,--gc-sections
Last night I hadn't added ANY of the above yet . I just found that it doesn't like the linker switch
-Wl,--gc-sections
When I leave that one out, the routines behave . Again, it's all about the experts at this point .
Bingo600
PostPosted: Feb 13, 2012 - 03:36 PM
@Jerome
I got some hints from Jörg.
He writes
If there are no more interrupt vectors that got added (or the
additional vectors are not needed right now), hacking the IO
header file might be enough, yes.
Well, I never really liked those --gc-sections and stuff. For a
correctly written (non-C++) program, they are not needed.
Anyway, when using -nostartfiles, it must be ensure that the new
crt*.o file comes *very first* on the linker commandline, before
anything else.
Maybe this is helpfull.
/Bingo
indianajones11
PostPosted: Feb 13, 2012 - 10:52 PM
Bingo600 wrote:
@Jerome
He writes
anything else.
Maybe this is helpful.
/Bingo
Bingo, I just replaced the original Xmega32A4 *.h file with the Xmega32a4U one . That should be ok for now . I'm using Studio 4.18 / Winavr-20100110 on XP, how do I guarantee that crt.o will be 1st ?
I'm surprised that Jorg said that since that linker switch keeps unreferenced functions from ending up in the final *.hex and so saving ALOT of bytes ( depending on what's in those pjt. files of course ) . I would guess the only other way to save would be to copy only needed functions into another new file for a given app ( and so wouldn't have to use the switch ) ?
For others reading this, the libgcc.a's startup code acts right when I actually use the vars in main(), compared to what I put in the code above and it's totally right when that linker switch is left out .
Thanks alot for the help !
Jerome
PostPosted: Feb 13, 2012 - 11:05 PM
Sorry but what has libgcc.a got to do with startup code? The CRT comes from crt<model_num>.o in AVR-LibC
indianajones11
PostPosted: Feb 13, 2012 - 11:25 PM
Clawson, there's startup code in there, too . It's structured so that MCUs have < 64K of flash, it comes from that file and for > 64K the crtX.o file does it ( that's what I found others saying in my Google searching ) . I think it's still set up that way . I did a avr-objdump -S on the libgcc.a for the Xmega32a4 and I saw copy and clear_bss code in there .
I've also commented out the copy routine from my crtX.S, and clear_bss isn't even in my crtX.S but they both appear in the *.lss .
SprinterSB
PostPosted: Mar 05, 2012 - 12:28 AM
indianajones11 wrote:
2) The copy_data routine, when needed.
3) clear_bss routine, when needed.
The startup-code is a blend from avr-libc and libgcc. To make it more confusing, the avr-libc part depends on the GCC version.
libgcc contributes:
A) __do_copy_data
B) __do_clear_bss
C) __do_global_ctors
D) __do_global_dtors
