Posted: Feb 11, 2012 - 05:52 PM |
Hi!
I tried using a display seiko l2014 (using a ks0076), I wrote this little code following the instructions of datsheet ... The code initializes the display software (init()) and sends a character to the display (send()).
I connected pins DB7-DB0 to PortA PA0-PA7, pin E to PortC PC4, pin RS to PC0 and R/W to ground (logical 0)
But the display does not display anything
I use a Stk500 with an atmega32a
#include <stdio.h>
#define F_CPU 4000000UL
#define lcd_data PORTA
#define lcd_rs 0
#define lcd_e 4
void e_toggle(void);
void data_send_sel(void);
void comm_send_sel(void);
void write_byte(uint8_t d);
void iniz(void);
void send(void);
void e_toggle(void)
PORTC |= (1<<lcd_e); // e=1
_delay_us(50);
PORTC &= ~(1<<lcd_e); // e=0
_delay_us(50);
PORTC |= (1<<lcd_rs); // rs=1
_delay_us(50);
PORTC &= ~(1<<lcd_rs); // rs=0
_delay_us(50);
lcd_data = d;
e_toggle();
void iniz(void)
comm_send_sel();
write_byte(0b00110000);
_delay_ms(5);
_delay_us(120);
_delay_us(50);
write_byte(0b00111000);
_delay_us(50);
write_byte(0b00001000);
_delay_us(50);
write_byte(0b00000001);
_delay_us(50);
write_byte(0b00000111);
_delay_us(50);
void send(void)
comm_send_sel();
_delay_us(50);
write_byte(0b00001110);
_delay_us(50);
write_byte(0b00000110);
_delay_us(50);
data_send_sel();
write_byte(0b01001100);
_delay_us(50);
int main()
//gestione display seiko 20x4
DDRA = 0xFF; //porta connessa ai pin dati
DDRC = 0xFF; //porta connessa ai pin di gestione
DDRB = 0xFF;
DDRD = 0x00;
PORTB = 0xFE;
while (PIND != 0xFE);
iniz();
PORTB = 0xFD;
while (PIND != 0xFD);
send();
I ask you where you think I'm wrong, and possibly how to correct the error ....
ah I've tried in the forum archive, but I have not found anything that contradicts the code I wrote, or that could help me
Bye
Def89 |
Posted: Feb 11, 2012 - 06:30 PM |
| Dont you need something like lcdsend("HELLO") in there somewhere? |
Posted: Feb 11, 2012 - 06:56 PM |
void send(void)
comm_send_sel();
_delay_us(50);
_delay_us(50);
_delay_us(50);
data_send_sel();
_delay_us(50);
function send () sends a code ascii (0b01001100 = "L") to display, or at least should be, but that does not appear
Bye |
Posted: Feb 11, 2012 - 07:08 PM |
JTAG disabled? |
Posted: Feb 11, 2012 - 08:00 PM |
sternst wrote:
JTAG disabled?
Yes, jtag is disabled by JTAGEN fuse, but why? I haven't any problems to programm the atmega32
I tried to control a HD44780 display but this shows no signs of life
I think the problem is in software, but I do not know where ...
I'm not 100% sure that the displays are working, are recovered from surplus equipment, but it seems strange that neither of them works: (
Bye |
Posted: Feb 11, 2012 - 08:32 PM |
You can't use PC4..PC7 if JTAG is hogging those pins |
Posted: Feb 11, 2012 - 08:40 PM |
Take a look at the note that follows the information concerning the 'Function Set' instruction. This is located a few pages after Table 6.
Note: Perform the function at the head of the program before executing any instructions (except for the read busy flag and address instruction). From this point, the function set instruction cannot be executed unless the interface data length is changed.
I interpret this as saying that you can only use this instruction once, when you initialize the LCD controller. (I am not including the three instances at the very beginning that actually seem to perform a 'reset').
You have included this instruction both in your iniz and in your send routines.
You should consider adding some more comments to your code to make your intentions clearer to us troubleshooters.
Don |
Posted: Feb 11, 2012 - 09:10 PM |
If we got a € for everyone that has posted here not getting their character LCD display to work we'd have a small fortune by now. There should be enough with ready-to-run implementations to get out of all those discussions.
I am not very interested in fault-seeking your code. Such endeavours almost always demands that one drags out ones own display, wire it up to match the code in question, and then start debugging. In your case it also involves reverse-engineering your binary constants - the C language supports symbolic constants quite well.
My suggestion is that you start with some well tested code that someone else wrote, and then start to alter it to your needs. There are several CLCD libraries available. A search here should give several. Good words to include in your search terms are the respective authors: "Pascal Stang", "Peter Fleury" and "danni" (AVR freaks member Peter Dannegger). If you want some minimal test code, then let me shamelessly promote my own minimal demo here.
Also, the standard questions apply:
What have you done for contrast control?
Since you have data lines on PORTA (and assuming that PORTA also hosts the ADC inputs, something that I leave for you to double-check), have you connected AVCC / AGND also?
HTH! |
Posted: Feb 12, 2012 - 11:28 AM |
Yes I've connect display so:
pin 1 GND
pin 2 +5V
pin 3 10k trimmer (adjusted to 3.8V)
pin 4 -> PC0
Pin 5 GND
pin 6 -> PC4
pin 7 -> PA0
Pin 14 -> PA7
I will not invent any new code, first I want to understand how the display works by using a code ready, then I'll worry about to change according to my needs.
The use of PortA and C is random, when I do not like to use other features of the processor
Bye |
Posted: Feb 12, 2012 - 12:33 PM |
It should be about 0.1V - wind it to the other end of the scale. |
Posted: Feb 12, 2012 - 03:54 PM |
I tried using the program linked to JohanEkdahl, but even so the display does not work
the value of VLC (pin 3) is set to 0.6V
The manual reports that Vdd - Vlc = 4.4V so Vlc = 0.6V
I do not know what else to try to do: (
Ah ATmega32 F_cpu is 4Mhz
Bye |
Posted: Feb 12, 2012 - 05:26 PM |
| Have you convinced yourself that the AVR is running at all? Have you done the LED blinky? |
Posted: Feb 12, 2012 - 06:00 PM |
if I understand what you asked me, my English has some gaps ......
Yes I'm sure it will have functions and that the program performs what is written, I have modified your code so I can run "a line of code" only when I push a button, so i can see if on pins 0-7 are the correct codes, displaying them using 7 LEDs, and the codes are correct ....
I ask if you performed the special connections between display and microprocessor, I have directly connected the data pin, the control pins, the power pin and installing only the trimmer for Vlc (between Vcc and Gnd)
I want to thank you for the help that you are giving me, you are great people
Bye |
Posted: Feb 12, 2012 - 06:23 PM |
I was asking if the AVR was running at all, i.e. has a valid CPU clock. My question is void since
which prooves beyond any doubt that it is actually running.
The quote also shows that you actually know what you are doing, and have a high technical skill level. Not everyone manages to implement his own step-debugger in software with a few LEDs. Congratulations!
Can you verify that you see the correct signals on the E (Enable), RS (RegisterSelect) and R/W (Read/Write, if you use it) lines lines also?
Would it be possible to get a photo of the wire-up of the display posted here?
Also, there are some rare character LCD displays that require a negative contrast voltage. Can you spot a manufacturer and model somewhere on the display module - or do you have a link to a data sheet? |
Posted: Feb 13, 2012 - 10:14 AM |
