Posted: Feb 07, 2012 - 07:42 PM |
Okay, and I always wondered why the Atmel EK1 has a 32 kHz oscillator. Maybe I can find a way to upgrade the board with a crystal.
but you'll have to disable calibration in the HAL
Which functions are involved?
Last question for today!
Thanks a lot. Have a good evening! |
Posted: Feb 07, 2012 - 07:44 PM |
| halStartingCalibrate() |
_________________ The opinions and views expressed by me on this forum are my own and do not represent my employer or anyone else that I'm affiliated with.
Posted: Feb 08, 2012 - 07:51 AM |
But to calibrate internal RC oscillator BitCloud uses 32 kHz oscillator as a reference.
So would it also be a problem to use USART at higher speeds (>9600 Baud)?
The only reason why halReadUid() might take that much time is to wait until few bytes are sent over SPI.
I haven't configured the EEPROM part so far. My EEPROM is on PB4. There is no UID in my EEPROM. Could that also be part of the problem?
I don't understand the selection of Int. RC Oszillator in the Fuses.
Int. RC Osz.: 32kHz
CKDIV: 8 kHz
Result: 4 kHz
The Blink-example demands a 8 MHz system clock. How does that fit with the 4 kHz Clock? |
Posted: Feb 08, 2012 - 04:13 PM |
Yes, it will. Normal UART operation is the main reason for calibration.
No, SPI will just receive 0 as UID, but it should happen quickly.
You have selected 8 MHz internal RC oscillator in your fuses. CKDIV8 will divide it to 1 MHz for easy calibration and after calibration stack will disable CKDIV8. |
Posted: Feb 08, 2012 - 04:48 PM |
Aha, the internal RC is 16 MHz and the Prescaler is 1:2 in the default state, isn't it? Thus it's 8 MHz.
If I use the USART (9600 Baud) with the fuses I have posted above I get wrong output on the terminal. If I change Fuses to the Transceiver Oscillator instead the output is correct. Why can't I use the Transceiver Oscillator. Which part of the Bitcloud won't work? |
Posted: Feb 08, 2012 - 04:51 PM |
Correct.
That's because calibration to non-existing 32 kHz made frequency completely off.
Sleeping. RF transmitter frequency is disabled during the sleep. |
Posted: Feb 08, 2012 - 05:06 PM |
Without an 32 kHz Oscillator I can't
1. address an external EEPROM (very slow)
2. use sleeping mode
Is that right?
According to that I have to find a way to upgrade my board. |
Posted: Feb 08, 2012 - 05:22 PM |
guitero wrote:
Is that right?
I don't know why SPI is so slow. It should not be this way. I assume something else is wrong and your entire system might run at a very slow speed. |
Posted: Feb 08, 2012 - 05:33 PM |
Damn! Any suggestions what I can do to solve the problem?
How can I check whether the entire system is affected or not. |
Posted: Feb 08, 2012 - 05:37 PM |
First of all I would try to understand what parts of UID read take that much time.
After that I'd run some code that blinks an LED (not a Blink application, but rather hard-coded while (1) loop and manual delays between blinks and try to estimate expected blink interval and compare it to the actual interval) |
Posted: Feb 08, 2012 - 06:29 PM |
I think this is the part where the delay (20 seconds) happens.
// wait for end of action
while(!(TWCR & (1 << TWINT)));
It's all fine. I wrote a small application that toggled a LED every second. After that I tried to send one Byte to a terminal every second. I checked Int. OSC. (8 MHz) and Transceiver OSC (16 MHz). I recognized no significant delay. |
Posted: Feb 08, 2012 - 06:34 PM |
| Oh, you have TWI UID enabled. It can cause delays if device is not present. I was looking at RCB version, which uses SPI. Then you'll just need to remove this read. |
Posted: Feb 08, 2012 - 06:40 PM |
All right! Can you give me a hint how I can integrate my external EEPROM (CS is on PB4) into the BitCloud. |
Posted: Feb 08, 2012 - 06:43 PM |
| I would just remove UID read from the HAL and read it in the application. This way it will be much easier for you to maintain the code. Just set CS_UID to a read value before starting a network. |
Posted: Feb 08, 2012 - 06:55 PM |
Sorry, I don't quite follow. CS_UID is the unique identifier for every node. How can that be set to a read value? Would you mind getting more into detail? |
Posted: Feb 08, 2012 - 06:59 PM |
You will read some UID value from the EEPROM; then you need to write this value to UID:
ExtAddr_t addr;
readValueFromEeprom(&addr);
CS_WriteParameter(CS_UID_ID, &addr);
That all valid if you want to read UID from external EEPROM; if you don't I don't understand what the problem is. |
Posted: Feb 08, 2012 - 07:09 PM |
| Sorry. You've got me wrong. My problem is to change the pin of the EEPROM because on the example board it's not on PB4. But I don't find the file where I can change the pinning. |
Posted: Feb 08, 2012 - 07:17 PM |
What example board? STK600-megaRF does not have CS for EEPROM at all.
That depends on what you want to achieve.
My advice: BitCloud is a networking library, treat it as such. EEPROM does not have anything to do with sending data, so just access it as you would without BitCloud around. |
Posted: Feb 08, 2012 - 07:22 PM |
| Okay,I think I can manage that. Thanks a lot for your answers Alex! |
