alexru
PostPosted: Jan 19, 2012 - 07:34 PM
What do you mean?
The opinions and views expressed by me on this forum are my own and do not represent my employer or anyone else that I’m affiliated with.
djoshi
PostPosted: Jan 19, 2012 - 07:37 PM
Say a valid byte is 0x55.
I recive one.
How can I confirm that I have got 0x55 due to calibration tuning and not an error.
So what I am trying to ask is can there be a possibilty that when AVR is not calibrated it could recivie a 0x55 just once.
Regads
DJ
djoshi
PostPosted: Jan 19, 2012 - 09:21 PM
Where can I find the current calibratin function, as I can see a assembler file but I can see where its called.
Is there a doc or guide, showing how I compile the hal as i belive this can not be done using avr studio.
Regads
DJ
alexru
PostPosted: Jan 19, 2012 - 09:36 PM
Implement some kind of confirmation protocol.
alexru
PostPosted: Jan 19, 2012 - 09:38 PM
halCalibrateInternalRc() in Components\HAL\avr\atmega1281\common\src\calibration.c
There is no document for this. You need to run "make clean all" from the command line in HAL directory.
djoshi
PostPosted: Jan 20, 2012 - 11:30 AM
When you say HAL directory. I guess you mean the top most level inside the HAL folder.
I guess I must also disable the ASYNC clock as well. Can this be done via a flag or do I need to comment out lines,
Regads
DJ
alexru
PostPosted: Jan 20, 2012 - 09:00 PM
Yep.
I think code comments will be necessary. Also keep in mind that async. timer is used during sleep, so your device won't be able to sleep.
djoshi
PostPosted: Jan 20, 2012 - 11:02 PM
This problem is only on the cord board. Worst case, I will disable it only for the cord. MY Router and End are working well with the a 32Khz.
Is it possible to compile the HAL so that calibration function and async enable function can be executed outside SYS_SysInit() and then called from the bitcloud project enviroment.
This way I can have two extra function, so that I do not need to keep re compiling when I jump from cord to end.
Regads
DJ
alexru
PostPosted: Jan 20, 2012 - 11:05 PM
For initialization from HAL_Init() call function defined in the application and define this function differently for different devices.
djoshi
PostPosted: Jan 20, 2012 - 11:15 PM
But how is this function called from the Bitcloud project file? I am only calling SYS_SysInit()
Regads
DJ
alexru
PostPosted: Jan 20, 2012 - 11:16 PM
SYS_Init() calls HAL_Init().
djoshi
PostPosted: Jan 20, 2012 - 11:21 PM
Silly Question.
Say I have a flag in my application area called calib_flag, so if I place the extern before this in the HAL file, will it be accessble.
Regads
DJ
djoshi
PostPosted: Jan 27, 2012 - 09:03 PM
Where Can I find the place in the HAL that let me select the define to set timer2 as a syn or async?
DJ
Regads
DJ
alexru
PostPosted: Jan 27, 2012 - 09:06 PM
Timer2 is used for sleep modes, it is not configurable.
djoshi
PostPosted: Jan 27, 2012 - 09:18 PM
What about in the Cord device. I would like it to be in Sync. At the moment its Async as its depending on the 32Khz.
Regads
DJ
alexru
PostPosted: Jan 27, 2012 - 09:20 PM
Then you'll have to change the HAL code to support whatever you need.
djoshi
PostPosted: Jan 27, 2012 - 09:22 PM
OK, I thought there might be some defines to make it a sync.
Regads
DJ
djoshi
PostPosted: Jan 31, 2012 - 03:26 PM
What problems could happen if the timer2 is sync. Can there be an timing issues. I can also use 8Mhz for more accuracy,
Regads
DJ
