LevenEigenaar
PostPosted: Jan 27, 2012 - 07:22 AM
 ISR(TIMER0_OVF_vect)
   count++;
   char buffer[BUF_SIZE];
   int index = 0;
   USART_init(UBRR_9600);
   lcd_init();
   if(count==1)
         while (modem_opstarten == 0)        // was eerst while
                  while(!(UCSRA & (1<<RXC)));
                  buffer[index] = UDR;
                  lcd_xy( 0, 0 );
                  lcd_puts("0");
                  if (buffer[index] == 0x0D)
                     buffer[index] = 0;
                     index = 0;
                     if (strcmp(buffer, "OK") == 0)
                        lcd_xy( 0, 1 );
                        lcd_puts(">"); //adc value
                        lcd_xy( 2, 1 );
                        lcd_puts(buffer); //adc value
                        lcd_xy( 5, 1 );
                        lcd_puts("<"); //adc value
                        lcd_xy( 7, 1 );
                        lcd_puts("1"); //adc value
                        test1 = 0;
                        _delay_ms(5000);
                          lcd_command( 0x01 );                          // display clear
                        //modem_begin_string = 0;
                        lcd_xy( 0, 1 );
                        lcd_xy( 5, 1 );
                        lcd_puts("2"); //adc value
                        test1 = 0;
                        _delay_ms(5000);
                     if (++index == BUF_SIZE)
                        index = 0;
                  count=0;
Hello, i have a problem
How can i make a start bit for this script, example start with 0x0A en stop 0x0D,
I have try many thinks but no results.
Here a example what i tried.
if ((UDR == 0x0A)||(set ==1))
set = 1;
MBedder
PostPosted: Jan 27, 2012 - 07:47 AM
Why on Earth are you stuffing your timer ISR with all that things? Do you have any clue of what the interrupts are for?
LevenEigenaar
PostPosted: Jan 27, 2012 - 08:24 AM
Do not know how else to. You any ideas?
jan_dc
PostPosted: Jan 27, 2012 - 09:28 AM
The problem here is that your Timer ISR blocks all other ISR's (if any). So this is considered to be 'bad practice' but I don't see any harm if you know what you are doing (meaning blocking possible other interrupts).
A 'cleaner' way of doing this is to have the ISR set a veriable to 1. Then in a continous loop you can check this variable and if == 1 procedeed with the code you currently have in your ISR.
F.i. I use a timer to create a more or less 10ms tick. The whole system is synchronised via that tick. Sometimes it waits for 50 ticks, other parts wait less and so on.
You also only have to set the UART settings once.
example of my time ISR:
ISR(CHRONO_INTERRUPT_VECTOR) {
    #if (CHRONO_10MSVALUE == 1)
      ++CHRONO_Time.tenms;
      ++CHRONO_Timer;
    #else
      if (++CHRONO_tickCounter == CHRONO_10MSVALUE) {
        CHRONO_tickCounter = 0;
        ++CHRONO_Timer;
    if (CHRONO_Time.tenms == 100) {
      #ifdef CHRONO_TIMEOUTVALUE
        if ((CHRONO_TIMEOUTVALUE) && (++CHRONO_ShutDownCounter > CHRONO_TIMEOUTVALUE)) {
          USER_ShutDownFunction();
      CHRONO_Time.tenms = 0;
      #ifdef CHRONO_FLAGS
        CHRONO_Flags.sec_full = 1;
        CHRONO_Flags.sec_half = 1;
        #ifdef USE_DISPLAY
          SDOS_blinkingDot = 1 - SDOS_blinkingDot;
      #ifdef EVENT_CHRONO_HALF_SECOND_VECTOR
        XIRQ_SET(EVENT_CHRONO_HALF_SECOND_VECTOR);
      #ifdef EVENT_CHRONO_SECOND_VECTOR
        XIRQ_SET(EVENT_CHRONO_SECOND_VECTOR);
      if (++CHRONO_Time.sec == 60) {
        CHRONO_Time.sec = 0;
        #ifdef EVENT_CHRONO_MINUTE_VECTOR
          XIRQ_SET(EVENT_CHRONO_MINUTE_VECTOR);
        #if defined(CHRONO_HOURS) || defined(CHRONO_MINUTES)
          if (++CHRONO_Time.min == 60) {
            CHRONO_Time.min = 0;
            #ifdef CHRONO_HOURS
              #ifdef EVENT_CHRONO_HOUR_VECTOR
                XIRQ_SET(EVENT_CHRONO_HOUR_VECTOR);
              ++CHRONO_Time.h;
    #ifdef CHRONO_FLAGS
      else if (CHRONO_Time.tenms == 50) {
        #if (CHRONO_10MSVALUE != 1)
          if CHRONO_tickCounter == 0) {
          #ifdef USE_DISPLAY
    #ifndef TRAPPED_INTERRUPT_VECTOR
      if ((CommStatus.Trapped) && (CommSettings.EnableTrap)) {
        TRAPPED_CallFunction();
Then in main code there is the following piece of code in an infinite loop:
do {
  if (KEYBOARD_Button.risingEdge) { /* button pressed */
    KEYBOARD_Button.risingEdge = 0;
    if (KEYBOARD_Button.button == (unsigned char) KEYBOARD_BUTTON_SELECT) { /* CAL pressed */
      MEASUREMENT_VCalibration();
      goto MAIN_loop;
    #ifndef __C5010__
      if (KEYBOARD_Button.button == (unsigned char) KEYBOARD_BUTTON_UP) { /* store value */
        DISPLAYSTRING_LEFT(0);
        MEASUREMENT_STORE_Display();
       DISPLAY_LoadAndDrawTemplate(INDEX_MAIN_MEASURE);
        goto label_MeasureAndDisplay_loop;
      if ((KEYBOARD_Button.button == (unsigned char) KEYBOARD_BUTTON_DOWN) && (!MEASUREMENT.channel[0].measurementStatus.outOfRange)) { /* store value */
        MENU_Parameter.row1 = MAIN_coordinate[0].row+2;
        MENU_Parameter.column1 = MAIN_coordinate[0].column+19;
        MENU_Parameter.wraparound = 1;
        USER_Settings.storeTable[0].position = USER_Settings.storeTable[0].position % (MEASUREMENT_STORE_MAXPOSITION+1);
        MENU_NumberParameter.number = ((long) USER_Settings.storeTable[0].position+1) * NUMBER_FACTOR;
        MENU_NumberParameter.increment = NUMBER_FACTOR;
        MENU_NumberParameter.minimum = NUMBER_FACTOR;
        MENU_NumberParameter.maximum = (MEASUREMENT_STORE_MAXPOSITION+1) * NUMBER_FACTOR;
        NUMBERSFORMAT(3);
        NumbersFormat.zeroOrSpace = 1;
        DISPLAYSTRING_INVERT_RIGHT(0);
        MENU_SetNumber();
        if (MENU_Status.accepted) {
          USER_Settings.storeTable[0].position = (MENU_NumberParameter.number/NUMBER_FACTOR) - 1;
          MEASUREMENT_STORE_Write();
    if (KEYBOARD_Button.button == (unsigned char) KEYBOARD_BUTTON_CANCEL) { /* MODE pressed */
      goto label_MainMenu;
} while (!CHRONO_Flags.sec_half);
Just before this do while loop some functionality is done. This do while is a wait loop until the next 0.5s event occurs. Within this wait loop some things like keyboard are checked and things are done if needed. Some important things are checked in the time ISR (if this functionality is used).
Kartman
PostPosted: Jan 27, 2012 - 09:45 AM
Cr and lf are not stop and start bits! The convention is to put cr,lf on the end of the string. I think you want to have a read of my tutorial on multitasking.
jan_dc
PostPosted: Jan 27, 2012 - 10:37 AM
He's asking to start with a certain code and stop with a certain code. LF/CF are just one of the many. Personally I use 0x00 as stop. And any new byte is a start. Much more convenient than LF/CR.
LevenEigenaar
PostPosted: Jan 27, 2012 - 10:49 AM
Hey!
This is a code too read the rs232 char.
Every word start with 0x0A and ends with 0x0D
How can i start with the char 0x0A ?
Example
0x0A CONNECT! 0x0D
with responds (OK)
Connect will set in the buffer.
But if i send
0x0A POSSIBLECONNECT 0x0D
It will send Error example
PostPosted: Jan 27, 2012 - 10:50 AM
LevenEigenaar,
If I were you I think I'd take a step back from what you are attempting here. Just growing an entire "sub program" inside an ISR() is actually very bad program design. When an ISR() is entered interrupts are disabled so if the ISR() code itself takes 10's or 100's of milliseconds to execute it may block several other interrupting events in the system from being serviced. Doing things like lcd_*() output in an ISR can take several milliseconds alone for each call. The ISR should be designed to only do the absolute minimum work and exit as soon as possible. In the limit this may be as simple as:
volatile flag;
ISR(TIMER_OVF_vect) {
 flag = 1; // notify main() that the event occurred
  while(1) {
    do_other_stuff();
    if (flag) {
      all_the_stuff_from_the_ISR();
      flag = 0;
The best way to go about designing a program like this is to work on small parts in isolation. Test those until you are happy that the function works then finally put all the elements together following an overall high level design (perhaps a flowchart?) that shows how everything should connect together. You need a clear picture of that overall design in your mind before you attempt to integrate the function blocks. In doing that you will be forced to consider whether "two things need to happen" at the same time and that's when you will consider splitting execution flow between main() and ISR()(s) code (again keeping those ISR()s short).
While the other replies here are helpful I fear they may just lead to a further complication of a bit of a rickety design.
BTW the convention is not to read it as:
0x0A "CONNECT" 0x0D
but as
"CONNECT" 0x0D 0x0A
which in C is
"CONNECT\r\n"
Each "line" sent by the modem is terminated with Carriage Return (0x0D) then Line Feed (0x0A)
LevenEigenaar
PostPosted: Jan 27, 2012 - 11:13 AM
   modem_opstarten = 1;
   int index = 0;
   lcd_init();
      if (flag == 1)
                  lcd_xy( 0, 0 );
                  lcd_puts("0");
                     buffer[index] = 0;
                     index = 0;
                        lcd_xy( 0, 1 );
                        lcd_xy( 2, 1 );
                        lcd_xy( 5, 1 );
                        lcd_xy( 7, 1 );
                        test1 = 0;
                        _delay_ms(5000);
                        lcd_xy( 0, 1 );
                        test1 = 0;
                        _delay_ms(5000);
                           index = 0;
         flag = 0;
   while (modem_opstarten == 1)
               USART_tx_string("AT+IPR=9600");                      //verander baudrate
               USART_Transmit(0x0D);                             //carriage return
               USART_Transmit(0x0A);                            //nieuwe lijn
               _delay_ms(100);
               USART_tx_string("AT+CPIN=");                      //verander baudrate
               USART_Transmit(0x22);
               USART_tx_string("6251");
               _delay_ms(100);
               USART_tx_string("AT+CGATT=1");                     //GPRS Registration
               _delay_ms(100);
               USART_tx_string("AT+COPS?");                     //GSM Registration bijvoorbeeld (TMOBILE  NL)
               _delay_ms(100);
               USART_tx_string("AT+CGDCONT?");
               _delay_ms(1000);
               USART_tx_string("AT+CGDCONT=1,");                   //controle gsm modem actief? ok of error
               USART_tx_string("IP");
               USART_tx_string(",");
               USART_tx_string("internet");
               _delay_ms(100);                                 //Vertraging 1 seconden
               USART_tx_string("AT$HOSTIF=2");
               _delay_ms(100);
               USART_tx_string("AT$ACTIVE=1");
               _delay_ms(100);
               USART_tx_string("AT$PADDISC=1");
               _delay_ms(100);
               USART_tx_string("AT$PADDST=");
               USART_tx_string("--------");
               USART_tx_string(", ----");
               _delay_ms(100);
               USART_tx_string("AT$AREG=2");
               _delay_ms(100);
               USART_tx_string("AT&W");
               _delay_ms(100);
               USART_tx_string("AT$RESET");
               _delay_ms(100);
               modem_opstarten = 0;
               modem_rs232_check = 1;
Hi thank you,
The flag will not be a 1?
How can i set the isr?
PostPosted: Jan 27, 2012 - 11:21 AM
Sorry, what do you mean? As long as you defined it as "volatile" then when timer 0 overflows it will be set and the code in main() will then see this.
Having said that I don't see any code that starts timer 0, or enables its interrupt or enables the global interrupt flag?!? Surely you must have had this previously as you already had the code you were using inside the handler for the timer overflow? You still need to have that timer run and interrupt if the execution of the rest of the code is dependent on the timer even occuring (to be honest, if this is a modem, I don't see why it would be dependent on a timed event anyway?)
jan_dc
PostPosted: Jan 27, 2012 - 11:22 AM
will result in a lock for ever if modem_opstarten != 0
The ISR will never quit and no other interrupts can be serviced.
This should work as long as there are no infinite waits for a software status. When an ISR is running a software status will not change unless it's changed by the ISR.
#define MODEM_IDLE 0
#define MODEM_DATA 1
char modem_state;
ISR(TIMER0_OVF_vect) {
  count++;
  int index = 0;
  lcd_init();
  if(count==1) {
    lcd_xy( 0, 0 );
    lcd_puts("0");
    switch (modem_state) {
    default :
      index = 0;
      if (buffer[0] == 0x0A) {
        modem_state = MODEM_DATA;
    case MODEM_DATA :
      if (buffer[index] == 0x0D) {
        buffer[index] = 0;
        index = 0;
        lcd_xy( 0, 1 );
        if (strcmp(buffer, "OK") == 0) {
          lcd_xy( 2, 1 );
          lcd_xy( 5, 1 );
          lcd_xy( 7, 1 );
        else  {
          lcd_xy( 5, 1 );
        test1 = 0;
        _delay_ms(5000);
      if (++index == BUF_SIZE) {
        index = 0;
dksmall
PostPosted: Jan 27, 2012 - 02:49 PM
Why are you even using a timer interrupt? From what I see of your code you're simply talking to a modem. Focus on getting your serial routines working and don't worry about timers for now.
LevenEigenaar
PostPosted: Jan 27, 2012 - 05:31 PM
Thank you all for you responds I will try it tomorrow !!!
And will replay on all you responds
grz
LevenEigenaar
PostPosted: Feb 02, 2012 - 07:30 AM
Sorry this code doesn't working.
LevenEigenaar
PostPosted: Feb 02, 2012 - 12:17 PM
Can someone help me with the problem
0x0A is the bit will start the buffer
0x0D is the bit will stop the buffer.
Someone?
PostPosted: Feb 02, 2012 - 12:19 PM
0x0A is not a "bit", it is at least 4 bits and more usually 8.
LevenEigenaar
PostPosted: Feb 02, 2012 - 12:34 PM
Ok,
Is here a example script for?
for receive strings?
LevenEigenaar
PostPosted: Feb 02, 2012 - 12:37 PM
   int index = 0;
   lcd_init();
      while (1)
         if((buffer[0] == 0x0A)||(test1 == 1))
            test1 = 1;
               buffer[index] = 0;
               index = 0;
               if (strcmp(buffer, "CONNECT") == 0)
                  lcd_xy( 0, 0 );
                  lcd_xy( 0, 2 );
                  lcd_xy( 1, 0 );
                                    lcd_xy( 0, 2 );
                  index = 0;
This isn't work at all?
What do i wrong?
LevenEigenaar
PostPosted: Feb 02, 2012 - 12:45 PM
Is this the right way?
   int index = 0;
   lcd_init();
      while (1)
         if((buffer[0] == 0x43)||(test1 == 1))
            test1 = 1;
               buffer[index] = 0;
               index = 0;
                  lcd_xy( 0, 0 );
                  lcd_xy( 0, 2 );
                  _delay_ms(5000);
                  test1 = 0;
                  lcd_xy( 1, 0 );
                                    lcd_xy( 0, 2 );
                  _delay_ms(5000);
                  test1 = 0;
                  index = 0;
Kartman
PostPosted: Feb 02, 2012 - 12:54 PM
Did you read my tutorial on multitasking? Did you understand what Cliff and I said about CR/LF?
May i suggest you get an Arduino board as there are projects similar to what you want to do. At a minimum look at the arduino code to see how they do it.
PostPosted: Feb 02, 2012 - 12:56 PM
Did you understand my previous point about not putting all the work in the body of an ISR? (whatever anyone else might say it is bad advice even if they do think it is good for you to learn from your mistakes - the issue it creates is so complex that it could floor an expert let alone a beginner!)
jan_dc
PostPosted: Feb 02, 2012 - 02:29 PM
Start the debugger, set a break point in the ISR and step through the code and see where it's going wrong (and why).
Learn to do debug or else you will never write any code.
