LevenEigenaar
PostPosted: Jan 19, 2012 - 02:14 PM
USART_init(UBRR_9600);
lcd_init();
char buffer[10];
uint8_t U;
    while(!(UCSRA &(1<<RXC)));
    U = UDR;
    if (U == 0x41)
      USART_tx_string("2");
      USART_tx_string("1");
this code
    if (U == 0x41)
how can i chance that example too AA ?
DO1THL
PostPosted: Jan 19, 2012 - 02:17 PM
well, you have (assumingly) 10 fingers. Select one of your choice (avoid the thumb, it's going to get ugly with that finger), then type at the appropriate place in the source code editor "AA".
Einstein was right: "Two things are unlimited: the universe and the human stupidity. But i'm not quite sure about the former..."
thygate
PostPosted: Jan 19, 2012 - 02:47 PM
given the current context of the questions and 0x41 = 'A', what he probably means is how to check for 2 received characters to match "AA", not one character equals 0xAA.
DO1THL
PostPosted: Jan 19, 2012 - 02:54 PM
Ok, granted. Then it will take an absolute minimum of brain in addition to a finger. Just set a flag on reception of the first 'A', clear it again if the next received char is not an 'A'. Anytime you receive an 'A' you check if that flag is already set, which will mean that you got two consecutive 'A' in a row. Magic, isn't it?
thygate
PostPosted: Jan 19, 2012 - 02:59 PM
For a more general approach, LevenEigenaar, study this code example.
#include <string.h>
#include "uart.h"
#define BUF_SIZE 10
  char buffer[BUF_SIZE];
  int index = 0;
  // init uart
    // wait for Rx complete
    // store character in buffer
    buffer[index] = UDR;
    // process on newline character
    if (buffer[index] == '\n')
       // zero terminate string on newline character
       buffer[index] = 0;
       // reset index for next string
       index = 0;
       // compare buffer to string
       if (strcmp(buffer, "AA") == 0)
          USART_tx_string("AA recieved\n");
          USART_tx_string("string did nto match\n");
    // increment index, wrap when at end of buffer
    else if (++index == BUF_SIZE)
       index = 0;
Note: untested.
This uses a simple buffer to store received characters, and performs a check for a match to the string "AA", only after a new line character has been received.
Now try to understand this first, and try to make your questions a lot clearer.
smileymicros
PostPosted: Jan 19, 2012 - 04:37 PM
No, try:
      for (i=0; i<10; i++)
        buffer[i] = usart_rx();
        if (i == '\n')
        else {
          lcd_putchar(buffer[i]);
Cliff, I didn't want to read this entire thread to see if you are intentionally jerking the guy around, but if that isn't the case, then what about the line:
if (i == '\n')
Did you really mean to have that in the code?
[edit]
Missed last page, but question still stands.
[/edit]
PostPosted: Jan 19, 2012 - 04:55 PM
It's a typo. It should (obviously?) have read:
        if (buffer[i] == '\n')
Well spotted Embarassed
(sometimes I think I should give up!)
smileymicros
PostPosted: Jan 19, 2012 - 05:10 PM
Don't give up! If you give up, I'll have to start watching TV again.
DO1THL
PostPosted: Jan 19, 2012 - 08:30 PM
Smiley,
even without Cliff being around, isn't reading a thread like this one better than any soap you could see on the TV? You could even have chips or popcorn while reading this...
smileymicros
PostPosted: Jan 19, 2012 - 08:47 PM
Well by analogy if Cliff does leave it will go from being a one hour soap to a 1/2 hour soap since he posts about 1/2 the content here.
Okay, I'll be nice. He posts 1/2 the worthy content here.
LevenEigenaar
PostPosted: Jan 20, 2012 - 07:44 AM
Thank you all but my English is not my best. I can scripting c++ but too everything to explain is for me difficult. So SMILEY:p And thank you all for the posted, commends!
This is now the code
#include <string.h>
#define UBRR_9600 103
#include "uart.h"
#define BUF_SIZE 10
void InitUART (unsigned char baudrate);
unsigned char ReceiveByte (void);
void TransmitByte (unsigned char data);
void gets1USART(char *buffer, unsigned char len);
void USART_init(unsigned int ubrr)
   UBRRH = (unsigned char)(ubrr>>8); //101
   UBRRL = (unsigned char)ubrr;
   UCSRB = (1<<RXEN)|(1<<TXEN);
   UCSRC = (1<<URSEL)|(1<<UCSZ1)|(1<<UCSZ0);
unsigned char usart_rx(void)
   while(!(UCSRA & (1<<RXC)));          //wait until reception complete
   return UDR;                     // receive value from UDR
  while (!(UCSRA & (1 << UDRE)));
  UDR = data;
void USART_tx_string( char *data )
while ((*data != '\0'))
      while (!(UCSRA & (1 <<UDRE)));
      UDR = *data;
      data++;
  int index = 0;
  // init uart
    if (buffer[index] == '/n')
       buffer[index] = 0;
       index = 0;
          USART_tx_string("string did not match\n");
       index = 0;
Thank you it works! I will post a video too show you
PostPosted: Jan 20, 2012 - 12:12 PM
No one has asked what clock speed he has specified.
LevenEigenaar
PostPosted: Jan 24, 2012 - 02:17 PM
16 mhz i use
LevenEigenaar
PostPosted: Feb 08, 2012 - 09:05 AM
I will try to send a int. With this code
int test5 = 5;
USART_Transmit(test5);
Example
But isnt work?
PostPosted: Feb 08, 2012 - 09:43 AM
What is the parameter to USAT_Transmit()? My guess is it takes either a single character or a pointer to an array of characters. If it's either of these it will not deliver what you want. The output at the PC end that you see as a human is in ASCII so, for example, the letter A is 65 and the digit 5 is 53. So if you used:
USART_Transmit(53);
you might see '5' at the other end. For numbers 0 to 9 you can convert to their ASCII value by adding 48 to them but a more useful way of specifying that 48 is to use the character '0'. So:
USART_Transmit(test5 + '0');
may result in '5' appearing at the other end.
When you have several digits to convert it gets more complicated as you have to split a multi-digit number into individual digits by repeated division by 10 and then adding '0' to each of those. For this reason (most versions of) C provide a function called itoa(). So if you use:
int n = 12345;
char output[8];
itoa(n, output, 10);
then output[] contains the sequence of ASCII characters "12345".
Now it could be that USART_Tranmit() takes a string (that is an array of characters) instead of a single character so this might be directly useable with it.
I guess we'll wait to hear what the interface to that function is.
EDIT: OK I should have re-read the whole thread. I see:
void USART_Transmit(unsigned char data);
In which case it is the case that:
will work as long as test5 is just 0 to 9. For longer numbers then use:
void USART_String(char * str) {
  while(*str) {
    USART_Transmit(*str++);
int n = 12345;
char output[8];
USART_String(output);
LevenEigenaar
PostPosted: Feb 08, 2012 - 10:03 AM
Thank you! Thank you, you help me alot!
I will try it in my script
LevenEigenaar
PostPosted: Feb 08, 2012 - 11:12 AM
Hi i got another question,
How can i make from a rs232(uart) string example 12345 a int?
Grz
PostPosted: Feb 08, 2012 - 11:30 AM
The opposite of itoa() is (surprise, surprise!) atoi(). Use it as follows;
char input_string = "12345";
int n;
n = atoi(input_string);
(in reality you would be building up input_string a character at a time by receiving them from the UART). atoi() stops converting when it reaches a character that is not in "-0123456789"
LevenEigenaar
PostPosted: Feb 08, 2012 - 12:38 PM
Ehm, i mean.
If i send a variable code example 12345 or 13245 how can i example make on this variable a int function?
Grz
PostPosted: Feb 08, 2012 - 01:51 PM
Type your question in Dutch as I don't follow what you are asking in English.
