Posted: Jan 05, 2012 - 05:33 AM |
jdperess wrote:
What could have caused this?
It could be manufacturing fault or overheating while soldering.
jdperess wrote:
Does atmel warranty these things?
I have no idea. |
Posted: Jan 09, 2012 - 02:46 PM |
Hi !
Another strange problem here. BitCloud v12 & ZigBit Amp
I have 3 nodes Coordinator, Router and End Device.
I have a problem when I try to establish network:
1. Power ON Coordinator(data sink).
2. Power ON Router.
Everything works fine till now, sending data, no errors at all, neighbour tables are OK.
3. Power ON End Device.
It joins(status 0x00 on it) to Coordinator (0x92 status). But now things get very interesting. When End Device joins it messes up neighbour table on Coordinator and I'm unable to communicate with Router nor End Device.
In neighbour table of Coordinator I see only one data (I read short address and device type). Short address is from Router and device type is End Device.
This procedure works without any problem:
2. Power ON Router.
3. Turn OFF Coordinator.
4. Power on End Device.
5. Power on Coordinator
No errors on any device, send/receive data works on every node.
What could be a problem here?
Thanks and regards! |
Posted: Jan 09, 2012 - 04:03 PM |
| What are your CS_* settings? |
Posted: Jan 10, 2012 - 02:45 PM |
Hi Alexru !
As allways you're right. I put same CS_UID to Router and End Device. Copy/paste what else to say.
Solving this problem I found that End Device has more let's say parents in it's neighbour table.
I know that End Device could only have one parent.
I my case, End Device has Coordinator and Router in table, so first End device is connected to Coordinator then I turned OFF Coordinator and it joined to Router, after that I powered Coordinator and everything was OK.
In BitCloud API documentation it's said that CS_ROUTE_TABLE_SIZE and CS_ROUTE_DISCOVERY_TABLE_SIZE should be set to 0(zero) for End Device. Do I have to stick to that?
Is it OK to put on End Device?
CS_NIEB_TABLE_SIZE = 1 [this can be 3 or 4 maybe]
CS_MAX_CHILDREN_AMOUNT = 0
CS_MAX_CHILDREN_ROUTER_AMOUNT =0
What's the difference between PROJECT_NAME = MeshBean_Amp and PROJECT_NAME = MeshBean in Makefile? OK obviously _Amp is for amplified module and regular MeshBean for I don't know ATZB-24-A2.
I put PROJECT_NAME = MeshBean for amplified module end everything works.
What's the difference and what should I be careful/aware of?
Is it OK to put different CS_END_DEVICE_SLEEP_PERIOD on different End Devices?
CS_END_DEVICE_SLEEP_PERIOD can be changed at any time and what about CS_FFD_SLEEP_PERIOD parameter?
Once again many thanks, Alexru ! |
Posted: Jan 10, 2012 - 11:11 PM |
How do you check this?
No, if you don't mind wasting your RAM. Records won't be used anyway.
Except for amplifier itself. You won't notice it on short distances, of course.
As long as coordinator and routers have maximum value of all EDs it is OK.
I consider CS_FFD_SLEEP_PERIOD a hack and don't recommend to use sleeping routers at all. I don't know if it can be changed in run-time. |
Posted: Jan 11, 2012 - 07:33 AM |
Thanks for answers!
By reading End Device neighbour table.
Why don't I receive any warning about this from stack? |
Posted: Jan 11, 2012 - 04:00 PM |
I mean by using API call or just by going through internal table yourself? You may have wrong interpretation of a data in this table.
First of all IEEE address is supposed to be unique by design.And also there is no reliable way to detect this conflict. That's why IEEE makes such a big deal out of uniqueness of those addresses. |
Posted: Jan 12, 2012 - 08:31 AM |
Thanks again !
I do it like this:
ZDO_GetNeibTable(table);
for(i=0;i<CS_NEIB_TABLE_SIZE;i++)
// address
u16_free = table[i].shortAddr;
// device type
u8_free = table[i].deviceType;
Could you explain what do you mean by wrong interpretation?
One other issue:
I using security(standard) and I ran on following problem:
I have 3 nodes: Coordinator, Router and End Device(sleeps for 10 sec, awake 2 sec.), network is star topology, so Router doesn't know anything about End device.
I turn OFF Coordinator and End Device wakes up and it sees that it's parent(Coordinator) is gone and it tries to join to Router.
1. On End Device I receive ZDO_NETWORK_LOST_STATUS
2. On Router ZDO_CHILD_JOINED_STATUS
3. After some time on Router I receive ZDO_CHILD_REMOVED_STATUS
4. I reset End Device.
5. Again on Router ZDO_CHILD_JOINED_STATUS
6. On End Device ZDO_AUTHENTICATION_FAIL_STATUS
7. Again after some time on Router I receive ZDO_CHILD_REMOVED_STATUS
I use CS_ZDO_SECURITY_STATUS 0.
I turn ON Coordinator and I'm able to communicate with Router but End Device is gone.
Coordinator is needed for this AUTHENTICATION and that's the reason why End Device can't join to Router.
How to handle this situation?
Thanks ! |
Posted: Jan 12, 2012 - 09:12 PM |
1. You need to call ZDO_GetNeibAmount() to get actual amount of records that will be returned in the table. Some records you are seeing this way (looking over CS_NEIB_TABLE_SIZE) might be incorrect.
2.Coordinator is required for normal network operation. |
Posted: Jan 15, 2012 - 02:50 PM |
My goal is like this:
1. All nodes have some default CS parameters in Configuration.h file
2. When I want to start network, first of course I add COORDINATOR, but I send to it new CS parameters which are stored in FLASH and form now on COORDINATOR runs on these new parameters.
3. Now I add another device(ROUTER or END DEVICE it doesn't matter), so now I have to "program" COORDINATOR to "rise up" with default parameters so this new device(which has only default parameters) could join to COORDINATOR. Then COORDINATOR sends CS parameters(not default) to new device(which stores this parameters in it's own FLASH) and both nodes can function on these parameters(not default). This step is repeated for every node I want to add in network.
Both comunications are with standard security.
I saw something like this on Internet but I can't remember where.
So COORDINATOR would be out of network just when I add new node in network and that is I don't know 10-15 seconds something like that.
I hope you understand me what I would like to achieve.
Can I do that and are there some restrictions/problems?
Thanks Alexru! |
Posted: Jan 16, 2012 - 09:57 PM |
| Why not send new parameters to each device from the same device as for the coordinator? Coordinator can't return to its previous network, you'll have to restart it anyway and all devices that were on this network will have to rejoin. |
Posted: Jan 17, 2012 - 02:51 PM |
Sorry, I wasn't clear enough from start.
I "program" COORDINATOR via USART (USB or Ethernet). I find this practical and I don't need any special device dedicated just for "programing".
Or can you suggest another way?
I've tried network(STANDARD SECURITY) like this(COORDINATOR can't have END DEVICEs just ROUTERs):
COORDINATOR -> ROUTER -> END DEVICE
I turned COORDINATOR OFF for 20 minutes and turned it on again end everything works, I didn't receive any errors on ROUTER nor on END DEVICE.
So I don't know why do you mean I have to restart/reset network?
Thanks again, Alexru! |
Posted: Jan 17, 2012 - 08:19 PM |
Once coordinator is started it will be in the different PAN ID (is non-standard static PAN ID is not used, of course).
If router will detect address conflict, for example, it will try to communicate to the coordinator and will not find it. If you don't expect this to be a problem, then don't don anything about it, but normally you would ping coordinator from time to time and rejoin if it is not there.
But since you restart coordinator anyway then your solution might work. When special command is received or button pressed C must restart with default settings and allow new device to join. Then it will communicate real parameters to this device and restart with real parameters. Device will restart with real parameters as well. Seems like a valid commissioning method.
LE: But I still would suggest that other devices will ping the coordinator and rejoin if necessary. |
Posted: Jan 31, 2012 - 01:08 PM |
Hi Alexru!
I've established network, COORDINATOR and 3 ROUTERS. BitCloud v.13
Everything works fine.
I set on every device in config file:
#define CS_MAX_CHILDREN_ROUTER_AMOUNT 2
What bothers me is that looking at NEIGHBOUR TABLE of each node I see 3 records, e.g. on ROUTER 1 I see COORDINATOR and ROUTERS 2 and 3.
I don't know why?
In few posts you suggested me to use this function. Reading BitCloud API this function only returns amount of routers and children(END DEVICE) amount. How can I know which of these records in NEIGHBOUR TABLE are incorrect?
Routers don't have parents so calling ZDO_GetParentAddr() on ROUTER node doesn't make sense?
Thanks ! |
Posted: Feb 01, 2012 - 06:42 PM |
Use ZDO_GetNeibTable() to get actual table contents. Only valid records will be returned. It is incorrect to look as the neighbor table directly.
Correct. |
