Posted: Jan 12, 2012 - 04:40 AM |
Posted: Jan 12, 2012 - 05:04 AM |
Unfortunately it doesn't seem to bring out enough I\O pins ( I need at least 20, 2 of which ADC) otherwise I would have been in.  |
Posted: Jan 12, 2012 - 06:06 AM |
I'm all for free dev boards.
Hazzarh!
Most generous George. |
Posted: Jan 12, 2012 - 11:58 AM |
I haven't worked yet with Xmega's so count me in (will send you a PM)
What will the sellingprice be ?
Nard |
Posted: Jan 12, 2012 - 12:02 PM |
| I'll give it a go, as well. I've never used an Xmega, although I have a couple of chips somewhere. |
_________________ Leon Heller
G1HSM
Posted: Jan 12, 2012 - 04:12 PM |
| Awesome! I've been wanting to play around with an xmega. PM incoming!! |
Posted: Jan 12, 2012 - 04:28 PM |
Nice looking board , would love to try one.
PM incomming
/Bingo |
Posted: Jan 13, 2012 - 12:12 AM |
George already got my PM!
Very generous!
Thank you, George.
JC |
Posted: Jan 14, 2012 - 01:04 AM |
| I just got a PM from George saying that he'd shipped my board. |
G1HSM
Posted: Jan 14, 2012 - 01:07 AM |
Ditto
Shouldn't we be asleep ?
Thanks George ! |
Posted: Jan 14, 2012 - 01:25 AM |
I suffer from insomnia.  |
G1HSM
Posted: Jan 14, 2012 - 01:36 AM |
Unfortunately it doesn't seem to bring out enough I\O pins ( I need at least 20, 2 of which ADC) otherwise I would have been in. Smile
The idea was to be a board for students and software guys, so in order to work with it you no need anything, not even an USB cable. And then you can work at school and continue home where maybe you share a room with someone and do not want to mess with wires, DMM, power supply. Peripherals connected through UART, I2C and SPI are already there.
But you still have access to PortC and other few lines through the connector.
I am thinking at 34USD.
2mm pitch sounds a little strange, but I wanted to expose as many pins as possible. PC6 and PC7 are reversed in order to be able to directly connect a Maxstream radio module, only one row, not very professional, but you still can.
For the LCD driver, I found a PIC to be the best option.
And finally, I was looking for other micros, at Microchip for example to have a board based on a PIC (8 bit) also, but there is no such micro to compare with Xmega. Bravo Atmel!
George. |
_________________ www.sofgel.ro bootloader for mega and xmega
www.elsofgel.com XME development board
Posted: Jan 14, 2012 - 05:25 AM |
Cool, I'll try one if you have one left!
Thanks for the generous offer! |
_________________ Tom Pappano
Tulsa, Oklahoma
Posted: Jan 20, 2012 - 12:24 PM |
My board just arrived - very neat!
I need some docs, though. |
G1HSM
Posted: Jan 20, 2012 - 01:43 PM |
Posted: Jan 20, 2012 - 01:47 PM |
Thanks. I was looking for it on the home page and Projects.
I can't get the boot loader to work. I tried EasyBootXAVR 1.4WIN (124.zip) and it tries to communicate on COM2. The Silicon Labs CP210x USB to UART Bridge is on COM38 on my system. I think that the supplied file, EasyBootAVR_1_4.exe, is the wrong one.
The software source code should be supplied. |
G1HSM
Posted: Jan 20, 2012 - 04:39 PM |
There is an .INI file on the same directory. Open it and change the com port from COM2 to COM38 or whatever port is assigned. Then try again.
I know there is an API function that could give me the available ports but I do not know which one is. If somebody could tell me about, I could put a drop down list to choose from.
I am cleaning up the project for the demo firmware on AS4 and I will post it.
George. |
Posted: Jan 20, 2012 - 06:23 PM |
Thanks, George.
Editing the .INI file fixed the problem. |
G1HSM
Posted: Jan 20, 2012 - 07:57 PM |
I wish someone would make a board similar to the raspberry pi or beagleboard, except using the AVR32 AP7000 as the CPU. I would buy one of those for sure.
I would, but I'm too lazy. |
_________________ I like cats, too. Let's exchange recipes.
Posted: Jan 20, 2012 - 08:57 PM |
Atmel stopped production of AP7000 ages ago and they are now "not recommended for new design". It was their attempt at a mobile phone CPU that failed (I guess a large customer pulled out or something) so in AV32 all that's left are UC3's which are souped up microcontrollers rather than SoCs |
Posted: Jan 21, 2012 - 05:34 AM |
George,
Mine arrived today!
It looks very nice and I am looking forward to working it!
Thank you!
JC |
Posted: Jan 21, 2012 - 06:30 AM |
Posted: Jan 21, 2012 - 03:19 PM |
Posted: Jan 21, 2012 - 04:23 PM |
How do I get the XME-board in bootloader-mode ?
(EasyBootAVR_1_4 for WinXP installed, edited EasyBootAVR_1_4.ini for use with Com32: CP2104 enumerated on 32) |
Posted: Jan 21, 2012 - 05:00 PM |
There are two ways to enter the bootloader.
If the application support a jump to the bootloader section, (demo application does) then make sure the PC GUI on tab "Update Device", the text box called "Jump to BL string" is filled with 0500013977B6 (see the attached picture, red mark). This string is application firmware dependent. One could decide upon single byte (I do not recommend), but the idea is whatever your application needs to make a jump to the bootloader section put it there in that text box. It is simply sent to the serial link before to try to read fuses. Also, the BL GUI must be set properly, see the picture, blue mark. The tab Generate Bootloader does not matter here, it is used only to generate the bootloader hex file.
At the micro side this is what happen:
PCExeCom1: ; jump to boot loader
LDI rXL, LOW(dStartBufferRxPC + 3)
LDI rXH, HIGH(dStartBufferRxPC + 3)
LD rA, X+
CPI rA, 57 ; 0x39
BRNE PCExeCom1RET
LD rA, X+
CPI rA, 119 ; 0x77 these 0x39 and 0x77 are there only to make it less susceptible to false incoming data
BRNE PCExeCom1RET
LDI rZL, LOW(BootLoaderSection)
LDI rZH, HIGH(BootLoaderSection)
IJMP ; jump to boot loader section (32768 / 2)
PCExeCom1RET:
RET
The second way to enter the BL is to simply click the Start button and then to give the micro a reset by using the attached small board with a reset button on it.
I may publish the serial protocol for the bootloader..
George. |
Posted: Jan 21, 2012 - 05:17 PM |
Thank you !
Will try later ..... dinnertime here and I am the cook
Aha, that is the clue.
Had already the STK600 connected with PDI; it communicates, so that's something. |
Posted: Jan 21, 2012 - 08:39 PM |
The mini-add board is not on that schematic, it is a separate board.
The ISP - PDI pin and signals matches Atmel's PDI connections used on their programmers. It is a mistake it is labeled ISP. It should be PDI.
The signals are:
1 - PDI
2 - 3.3V
3 - NC
4 - NC
5 - nReset
6 - GND
George. |
Posted: Jan 21, 2012 - 10:25 PM |
I'm puzzled.
I wrote a Bascom demo (hex-file) via the bootloader to XME, just to get something else in than your demo. The reason for doing that is that I want to familiarize myself with the bootloader concept. Never used one before.
After that I re-programmed the XME with the hex-file in the demo SW. I get a blinking led, but the display shows 8.E8. Vivaldi is still there.
I think I am missing some crucial information.
Openened the project in AS4, re-compiled and tried that: no luck. Same behaviour. |
Posted: Jan 21, 2012 - 11:37 PM |
It seems I messed up the project when I cleaned up the comments.
Attached is a working hex file. You can use it until I fix the project.
George. |
Posted: Jan 22, 2012 - 03:30 AM |
Posted: Jan 22, 2012 - 07:33 AM |
Hi George,
My XME arrived and looks great!
I have an ISR flashing the LED, (Heart Beat).
I can read the PB Switch.
Tomorrow I'll beep the Piezo and write to the LCD.
JC |
Posted: Jan 22, 2012 - 01:09 PM |
angelu wrote:
Demo project fixed.
George.
Thanks a lot, now it works fine.
I will write my own, very first Xmega program and upload that with the bootloader.
Edit: first I will try to upload one of Bascom's demo:
' XM32A4-UART.BAS
' (c) 1995-2011 MCS Electronics
' sample provided by MAK3
$regfile = "xm32a4def.dat"
$crystal = 32000000 '32MHz
$hwstack = 64
$swstack = 40
$framesize = 40
'include the following lib and code, the routines will be replaced since they are a workaround
$lib "xmega.lib" : $external _xmegafix_clear : $external _xmegafix_rol_r1014
Config Osc = Disabled , 32mhzosc = Enabled '32MHz
'configure the systemclock
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1
Dim B As Byte
Dim S As String * 50
Config Com1 = 38400 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Com2 = 19200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Com3 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Com4 = 38400 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Com5 = 38400 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM1:" For Binary As #1 'COM1....COM8
Print #1 , "This use COM1"
'Dynamic COM Port Variable must start with BUART
Dim Buart_channel As Byte '0 = COM1 ...... 7 = COM8
'when using a variable, notice that the index is 0 based !
'We use here ATXMEGA32A4 so we have 5 COM Ports available (Buart_channel = 0.....4) !
Buart_channel = 0
Print #buart_channel , "This use ALSO COM1"
Buart_channel = 1
Print #buart_channel , "This use COM2" 'You do not need to open it with Dynamic Channels
'But when you want to open it then do it this way
Open "COM3:" For Binary As #buart_channel
Buart_channel = 2
S = Waitkey(#buart_channel) 'waits for key on COM3
Print #buart_channel , "This is COM3)"
For Buart_channel = 0 To 4 'ATXMEGA32A4 have 5 COM Ports
Print #buart_channel , "Hello" 'print Hello on every COM Port (with configured Baud rate)
Next
'Buart_channel = 7
'Print #buart_channel , "This use COM8" 'For example for ATXMEGA128A1 devices you have 8 COM Ports
Do
B = Inkey(#buart_channel) 'Listen on every COM Port if something is coming
Next
Loop Until B <> 0 'Exit Do Loop when something is there
End
Hmm. XME1.1 still active.
BL IDE shows that fuses are read and flash is being programmed.
Do I have to do something with the BL string 0500013977B6 in my application ? |
Posted: Jan 22, 2012 - 01:52 PM |
My evaluation:
1. The board itself: nice design, well built. You motivated already the 2mm header.
For a developmentboard I'd like to have access to all pins: f.i. the CP2104 has lots of other pins that can be used (or abused) for different purposes.
2. You're going to sell these XME-boards as developmentboards: are they part of a training you will give ? If not, and these boards are sold as such, a good set of documentation is needed. More examples of SW implementations f.i. The demo shows what the board can do. But a set of simple example that show particular functions will give students more insight.
3. Schematic: pin numbers and devicenames are very, very small.
4. Bootloader is great: students don't need a STK600 or so with PDI functionality.
Since I never used it before: I would have liked some step by step procedure in which is expained what happens where and when. And for the complete noobs: what IS a bootloader ?
5. Price of $34: is a good price. I would be willing to pay that amount for this board.
I will keep editing this post: that prevents scattering all over the thread. Order of notes is random. I simply will add a new one or edit an existing note. |
Posted: Jan 22, 2012 - 02:26 PM |
The demo has an option to jump to the bootloader when it receives this string from the CP2104.
If your application has this feature and it uses any other string, then put it there in that BL IDE text box.
If it does not, then clear the text box and use the reset button to reset the micro right after you click Start button on BL IDE.
To unplug and plug again the board to USB does not work because it will take some time for the COM port to appear in Windows, and the bootloader will wait only one second for the reading fuses command to arrive, after that will give it a software reset and the application program will start.
RTS and CTS are connected to the micro.
After BL IDE starts, it will read the .hex file after first time Start button is clicked. Even you select a new .HEX file, will not be read, unless you start the application again. So likely the same demo .hex was burned again in the micro. Have to be fixed.
George. |
Posted: Jan 22, 2012 - 04:52 PM |
Yup, that closing of BL IDE and opening again to get a new hex-file loaded has to be fixed. Did you write it yourself ? If so, a progress-bar during programming would be nice. And does it actually verify the uploaded code ? All I see is the sequence "Read fuses" and "Write flash memory" and "Done" in the lower left corner of the BL IDE.
MyBlinky works ...
$hwstack = 64
$swstack = 40
$framesize = 40
Set Ddrb.1
Do
Set Portb.1
Waitms 100
Reset Portb.1
Waitms 100
Loop
End
Hmm, this didn't work:
Do
Set Pinb.1
Waitms 100
Loop
Apparently Xmega's doesn't toggle PortB.1 when PinB.1 is written. Time to consult the datasheet.
Edit: Xmega's are very sophisticated. I like that
This works fine
Do
Toggle Portb.1
Waitms 50
Loop
Posted: Jan 22, 2012 - 05:54 PM |
I'll add to Nard's Platform Demo.
This one includes hardware definitions for all of the Xmega's Ports.Pins, but they haven't yet all been tweaked.
Some will need further refinement as one sets up the attached hardware, but this should keep one from having any significant hardware conflicts.
It triple beeps the Piezo on start up, and then uses
Port D, Timer/Counter #0, to generate a 1 / mSec Interrupt
from which a Heart Beat LED is flashed.
JC
'File: XME Test V3.bas
'Testing George's (AVRFreak: angelu) new Xmega platform.
'ATXmega32A4, 3 char USART connected LCD, Piezo, LED, 3-Axis Accel,
'Atmel Dataflash chip, Audio amp, Relay driver,
'USB interface via USART to USB Bridge chip.
'Bascom. JEC
'Jan. 21, 2012
'Ver: 1 Jan 21, 2012
'Simple Flash the LED at 1 Hz works.
'This runs on Xmega's Int 32 MHz Clock, at 32 MHz.
'This sets up lots of Port.Pin assignments, but have not tested them, yet.
'Ver: 2 Jan 21, 2012
'Test reading the PCB's PB Switch. No Debounce provided.
'Push the PB Switch to turn On the LED.
'Release and LED is Off.
'Ver: 3 Jan 22, 2012
'Add a Timer/Counter ISR for driving the LED as a Heart Beat LED.
'Assume Clock is 32 MHz.
'Set Up ISR for 1 Intr / mSec, (1 kHz Intr).
'Use Port D Timer/Counter #0.
'32MHz to Prescaller of 256 gives 125000 clock to T/C module.
'Set TOP to 125, i.e. divide by 125, for 1000 Intr/s per Second.
'Actually set for 124, to account for roll over from TOP to 0.
'Also added a 3-Tone's per Beep, Piezo-Beeper routine.
'Beep is program driven, and therefore ties up the micro.
'Fine for testing for now.
'This works.
'Hardware Setup and Notes:
'XMega runs at 2 MHz on startup, default.
'Note: The Vtarget pin on PDI 6-Pin Header is tied to the PCB's 3.3V line.
'This is sourced from an LDO which is powered from the USB Port.
'USART to USB Bridge:
'PortE.2 = RxD0
'PortE.3 = TxD0
'PortA.4 = RTS Hand Shake
'PortA.5 = CTS Hand Shake
'Piezo
'PortB.0 via NFet
'LED
'PortB.1 Active Low
'3-Axis Accelerometer, MMA8453Q
'I2C Interface. +/-2/4/8g, 10-Bit resolution.
'PCB has external pull-ups on SCL & SDA lines.
'PortE.1 = SCL
'PortE.0 = SDA
'Accel Interrupt #2 goes to Xmega PortA.2
'Accel Interrupt #1 is not tied to Xmega.
'SPI Serial Flash Memory Chip: Atmel AT25DF041A
'On SPI bus.
'PortA.1 is used for the Chip Select.
'3 Char LCD has its own PIC uC driver.
'Send it serial data via PortD.3.
'See XME Manual for the protocol.
'XME has an External 32kHz Xtal, on PR0 & PR1.
'Audio Driver to Headphones:
'Driven by Xmega DAC(s).
'Xmega controls the audio amp's ShutDown\ signal.
'PortD.4 to Audio Amp ShutDown\ Low for normal audio output mode.
'PortB.2 = DAC0 signal
'PortB.3 = DAC1 signal
'External Relay/Inductive Load Driver:
'High = NFet is On. Max is 14V, designed for +12.
'Switches to common Ground.
'Typically 400 mA per channel, Rds ON < 1.5 ohms.
'PortD.0 controls DR0 NFet, available on Header.
'PortD.1 controls DR1 NFet, available on Header.
'The Mini-Add On PCB has a Reset Push Button Switch
'and a Standard 6-Pin PDI Header.
'Pin #1 is furtherest from the PB Switch, and elevated furthest from
'the surface of the PCB.
'Port C is brought out on the XME Header.
'Note PortC.6 and portC.7 are swapped in non-sequential order.
'Push Button Switch:
'PortD.2 Uses the Internal PullUp Resistor.
'Xmega PortA:
'PortA.0 = N/C
'PortA.1 = To Serial Data Flash chip's CS
'PortA.2 = Accel Interrupt #2 input to Xmega
'PortA.3 = ADC #5 Input 5V Supply Monitor Input via Attenuator V=(0.149)*Vusb
'PortA.4 = USART to USB RTS Hand Shake Signal
'PortA.5 = USART to USB CTS Hand Shake Signal
'PortA.6 = ADC #6 Input via Header Pin 9
'PortA.7 = ADC #7 Input via Header Pin 11
'Xmega PortB:
'PortB.0 = To Piezo, via NFet
'PortB.1 = To LED, Active LOW
'PortB.2 = To Audio Amp DAC0 signal
'PortB.3 = To Audio Amp DAC1 signal
'PortB.4 = N/A
'PortB.5 = N/A
'PortB.6 = N/A
'PortB.7 = N/A
'Xmega PortC:
'PortC.0 = Ext Header Pin 18
'PortC.1 = Ext Header Pin 16
'PortC.2 = Ext Header Pin 14
'PortC.3 = Ext Header Pin 12
'PortC.4 = Ext Header Pin 10
'PortC.5 = Ext Header Pin 8
'PortC.6 = Ext Header Pin 4 Non-Sequential
'PortC.7 = Ext Header Pin 6 Non-Sequential
'Xmega PortD:
'PortD.0 = To External Relay Driver NFet, DR0 Signal, on Header Pin 17
'PortD.1 = To External Relay Driver NFet, DR1 Signal, on Header Pin 19
'PortD.2 = To PB Switch to Gnd. Uses the Internal PullUp Resistor
'PortD.3 = To 3-Char LCD, Serial Driven
'PortD.4 = Audio Amp ShutDown\ Control, Low = Audio Active
'PortD.5 = MOSI
'PortD.6 = MISO
'PortD.7 = SCK
'Xmega PortE:
'PortE.0 = To Accelerometer, I2C SDA, has External Pullups
'PortE.1 = To Accelerometer, I2C SCL, has External Pullups
'PortE.2 = To USART to USB Bridge, RxD0
'PortE.3 = To USART to USB Bridge, TxD0
'PortE.4 = N/A
'PortE.5 = N/A
'PortE.6 = N/A
'PortE.7 = N/A
'Xmega PortR:
'PortR.0 = 32 kHz Xtal2
'PortR.1 = 32 kHz Xtal1
$regfile = "xm32a4def.dat" ' specify the used micro
'$crystal = 20000000 ' used crystal frequency
'$crystal = 32768 ' used crystal frequency
'$crystal = 8000000 ' used crystal frequency
'$crystal = 14745600 ' used crystal frequency
'$crystal = 2000000 ' used crystal frequency
$crystal = 32000000
'$baud = 19200 ' use baud rate
$hwstack = 64 ' default use 32 for the hardware stack
$swstack = 40 ' default use 10 for the SW stack
$framesize = 40 ' default use 40 for the frame space
$lib "xmega.lib"
'Set Up 32 MHz Int OSC:
'first enable the osc of your choice
Config Osc = Enabled , 32mhzosc = Enabled
'Configure the systemclock
Waitms 500 'Startup Stabilization Delay
'Configure Port A:
'Set for Inputs for now.
'USART will override this.
'Change PortA.1 for Serial Flash when test it.
Porta_pin0ctrl = 0 '0 d = Input, no pullups
Porta_pin1ctrl = 0 '0 d = Input, no pullups
Porta_pin2ctrl = 0 '0 d = Input, no pullups
Porta_pin3ctrl = 7 '7 d = Disable "Input Buffer" for ADC
Porta_pin4ctrl = 0 '0 d = Input, no pullups
Porta_pin5ctrl = 0 '0 d = Input, no pullups
Porta_pin6ctrl = 7 '7 d = Disable "Input Buffer" for ADC
Porta_pin7ctrl = 7 '7 d = Disable "Input Buffer" for ADC
Porta_dir.0 = 0 'A.0 = Input N/C
Porta_dir.1 = 0 'A.1 = Input Serial Data Flash CS
Porta_dir.2 = 0 'A.2 = Input Accel Intr #2
Porta_dir.3 = 0 'A.3 = Input ADC #5, USB Voltage Monitoring
Porta_dir.4 = 0 'A.4 = Input USART to USB RTS Hand Shake
Porta_dir.5 = 0 'A.5 = Input USART to USB CTS Hand Shake
Porta_dir.6 = 0 'A.6 = Input ADC #6 Input via Header
Porta_dir.7 = 0 'A.7 = Input ADC #7 Input via Header
'Configure Port B, (Lower Nibble Only, Upper Nibble doesn't exist):
'Set for
Portb_pin0ctrl = 0 '0 d = Totum, no pullups
Portb_pin1ctrl = 0 '0 d = Input, no pullups
Portb_pin2ctrl = 0 '0 d = Input, no pullups
Portb_pin3ctrl = 0 '0 d = Input, no pullups
Portb_dir.0 = 1 'B.0 = Output To Piezo NFet
Portb_dir.1 = 1 'B.1 = Output To LED Act Low
Portb_dir.2 = 1 'B.2 = Output DAC to Audio Amp
Portb_dir.3 = 1 'B.4 = Output DAC to Audio Amp
'Configure Port C:
'This Port is available on the Header.
Portc_pin0ctrl = 0 '0 d = Input, no pullups
Portc_pin1ctrl = 0 '0 d = Input, no pullups
Portc_pin2ctrl = 0 '0 d = Input, no pullups
Portc_pin3ctrl = 0 '0 d = Input, no pullups
Portc_pin4ctrl = 0 '0 d = Input, no pullups
Portc_pin5ctrl = 0 '0 d = Input, no pullups
Portc_pin6ctrl = 0 '0 d = Input, no pullups
Portc_pin7ctrl = 0 '0 d = Input, no pullups
Portc_dir.0 = 0 'C.0 = Input via Header
Portc_dir.1 = 0 'C.1 = Input
Portc_dir.2 = 0 'C.2 = Input
Portc_dir.3 = 0 'C.3 = Input
Portc_dir.4 = 0 'C.4 = Input
Portc_dir.5 = 0 'C.5 = Input
Portc_dir.6 = 0 'C.6 = Input
Portc_dir.7 = 0 'C.7 = Input
'Configure Port D:
'Set for
'To LCD Driver, PB Sw Input, Relay Drvr outputs, MOSI, MISO, SCK.
Portd_pin0ctrl = 0 '0 d = Totum, no pullups
Portd_pin1ctrl = 0 '0 d = Totum, no pullups
Portd_pin2ctrl = 24 '0 d = Input, Uses pullups
Portd_pin3ctrl = 0 '0 d = Totum, no pullups
Portd_pin4ctrl = 0 '0 d = Totum, no pullups
Portd_pin5ctrl = 0 '0 d = Input, no pullups
Portd_pin6ctrl = 0 '0 d = Input, no pullups
Portd_pin7ctrl = 0 '0 d = Input, no pullups
Portd_dir.0 = 1 'D.0 = Output, Ext Relay Drve, via Header
Portd_dir.1 = 1 'D.1 = Output, Ext Relay Drve, via Header
Portd_dir.2 = 0 'D.2 = Input, PB Switch, Uses Internal Pull Up
Portd_dir.3 = 0 'D.3 = Input
Portd_dir.4 = 1 'D.4 = Output, Audio Amp ShutDown\, Low = Audio Active
Portd_dir.5 = 0 'D.5 = MOSI Set up separately
Portd_dir.6 = 0 'D.6 = MISO Set up separately
Portd_dir.7 = 0 'D.7 = SCK Set up separately
'Configure Port E, (Lower Nibble Only, Upper Nibble doesn't exist):
'USART to USB Bridge and Accel chip, (I2C)
'Must set PortE.3, TxD0 to output for USART to work.
Porte_pin0ctrl = 0 '0 d = Totum, no pullups
Porte_pin1ctrl = 0 '0 d = Input, no pullups
Porte_pin2ctrl = 0 '0 d = Input, no pullups
Porte_pin3ctrl = 0 '0 d = Input, no pullups
Porte_dir.0 = 0 'E.0 = Input, Set up later as I2C SDA
Porte_dir.1 = 0 'E.1 = Input, Set up later as I2C SCL
Porte_dir.2 = 0 'E.2 = Input, RxD0
Porte_dir.3 = 1 'E.3 = Output, TxD0
Dim J As Byte
Dim D As Byte 'LCD Chaser LED Counter
Dim Jxb As Byte 'PB Switch
Dim Pbsw0 As Byte 'Push Button Switch 0 Status
Dim Tonecnt As Word 'Number of pulses per Sound loop
Dim Tonelp As Word 'Number of Sound times through loop
Dim Toneperiod As Word 'Adjustment for Tones Period, uSec
Dim Toneperiod2 As Word 'Escalating Tone Period
Dim Lpcnt1 As Word 'Loop Counter
Dim Lpcnt2 As Word 'Loop Counter
Dim Isrcnt As Word 'ISR Counter TCD0, 1 intr q mSec
Piezo Alias Portb_out.0 'Piezo
Led Alias Portb_out.1 'LED, Active LOW
Load0 Alias Portd_out.0 'Ext NFet Load Driver 0
Load1 Alias Portd_out.1 'Ext NFet Load Driver 1
Pbsw Alias Portd_in.2 'PB Switch, Push = Gnd
Tonecnt = 300
Tonelp = 3 'Three tones per "Beep"
Isrcnt = 0 'Init ISR Counter to 0
'Set up Port D Timer/Counter #0 for generating a High Level Interrupt.
'No PWM waveform is generated on any I/O Pins.
'Assumes uC Clock is 32 MHz.
'Partially uses Bascom, partially uses direct control of the Registers.
'32 MHz uC Clock with PreScaler div by 256 gives 125000 clock into T/C.
'T/C Top set to 124, (div by 124), gives 1000 Intr / Sec.
'i.e. Divide by 125, but have to account for the roll over from TOP to 0.
'Bascom combines PER Low and PER High for the user.
Config Priority = Static , Vector = Application , Hi = Enabled
Tcd0_ctrla = &B00000110 'Divide by 256
Tcd0_ctrlb = &B00000000 'Normal Mode
Tcd0_intctrla = &B00000011 'Enable OverFlow Intr, High Level
Tcd0_intctrlb = &B00000011 'Channel A, High Level Intr
Tcd0_per = 124 'PER 124 Dec
On Tcd0_ovf Isrtcd0 'ISR Timer/Counter D #0
Enable Tcd0_ovf , Hi 'Enable as High Interrupt
Enable Interrupts 'Global Enable Interrupts
Premain:
Gosub Xbeep 'Beep on Start-Up of Program
Main:
Do
'Test routines go here....
Loop 'Forever
Isrtcd0:
'Assumes uC Clock = 32 MHz
'Set for 1000 Intr / Sec, i.e. 1 Intr q mSec
'On Entry have: ISRCnt
Isrcnt = Isrcnt + 1
If Isrcnt < 50 Then
'Turn On LED
Led = 0 'Active Low
Else
'Turn Off LED
Led = 1 'Active Low
End If
If Isrcnt > 1000 Then
Isrcnt = 0 'Roll Over q 1 Second
End If
Return
Xbeep:
'Beeping Piezo via XMega.
'Prog driven, not ISR driven.
'Currently a sequence of three beeps, increasing in frequency each beep.
'Pulse the piezo to do this, are using an asymetric pulse for now,
'not a 50% duty cycle.
'This ties up the micro, as it isn't ISR driven.
'On Entry have: ToneLp The number of individual tones played per "Beep" call.
'On Entry have: ToneCnt The number of hardware pulses to the piezo to
'make it beep.
Toneperiod = 200 'Init Tone Period Adjustment, uSec
Toneperiod2 = Toneperiod 'Init period, then adj it per beep
For Lpcnt1 = 1 To Tonelp 'Loop counter
For Lpcnt2 = 1 To Tonecnt 'Number of pulses
Piezo = 1 'Piezo
Waitus Toneperiod
Toneperiod2 = Toneperiod + 100
Piezo = 0
Waitus Toneperiod2
Next Lpcnt2
Waitms 50 'Intra-Beep pause
Toneperiod = Toneperiod - 50
Next Lpcnt1
Return
Flashled:
'Flash the on board LED at 1 Hz
'Software driven with delays
'Assumes 32 MHz Clock
Do
Led = 1 'Off, Active Low
Waitms 500
Led = 0 'On, Active Low
Waitms 500
Loop 'Forever
Return 'Null and Void
Readsw:
'Read the Push Button Switch Input. Unpressed = pulled high.
'No Debounce included.
'Turn On the LED if the PB Switch is pressed.
'Or Beep the Piezo, program driven for now.
If Pbsw = 0 Then
'PB Switch is pressed
'Gosub Xbeep
Led = 0 'LED On, Active Low
Else
'PB Switch is not pressed
Led = 1 'LED Off
End If
Return
Posted: Jan 22, 2012 - 08:36 PM |
Have to be fixed.
It is fixed now. It reads the hex file every time Start button is clicked.
Progress-bar added.
Yes, it does. If you not check the "Verify" box, a slightly increase in speed can be noticed. The idea was not to wait until all flash is written and then to check it if something is wrong. You can test on a locked micro trying to reprogram. The verification is done page by page. During the verification, data is not sent nor read by PC again but it is checked against the one in ram used for writing. I suppose the data in ram is reliable since it is sent with two CRC bytes at the end.
When "Erase" is checked, it will erase page by page right before the writing for all memory. If it is not checked, it will erase only pages that are supposed to be written. You can save time this way.
George. |
Posted: Jan 22, 2012 - 09:35 PM |
Okay, I will download the new BL IDE. Thanks for the fix.
Doc, that defenition is not in the reg-file ? Thanks for posting your program.
@all: it's quite fun to play around with the XME. I need to familiarize myself with the Xmega's. And I don't see that as something bad !
Nard
Edit: new bootloader BL IDE works as a charme now. That was a quick fix ! Thanks.
Note: no update in revision level. I dumped the earlier version. |
Posted: Jan 23, 2012 - 06:40 PM |
Got mine today
Thanx George
/Bingo |
Posted: Jan 23, 2012 - 07:19 PM |
| Picked up mine today too! Thanks George! |
Posted: Jan 23, 2012 - 08:10 PM |
@George
I can't seem to get the Linux bootloader going.
It just hangs saying reading fuses 0%
Ubuntu 10.04 LTS
CP210x seen fine as ttyUSB0
Jan 23 21:01:47 x60-2 kernel: [12279.729054] usb 4-1: new full speed USB device using uhci_hcd and address 4
Jan 23 21:01:47 x60-2 kernel: [12279.903269] usb 4-1: configuration #1 chosen from 1 choice
Jan 23 21:01:47 x60-2 kernel: [12279.910990] cp210x 4-1:1.0: cp210x converter detected
Jan 23 21:01:47 x60-2 kernel: [12280.021075] usb 4-1: reset full speed USB device using uhci_hcd and address 4
Jan 23 21:01:47 x60-2 kernel: [12280.171255] usb 4-1: cp210x converter now attached to ttyUSB0
Modified .INI file to /dev/ttyUSB0 , selected Xmega32A4 , and Baud 115.200
[Settings]
cboxResetDevice=1
cboxEraseEeprom=0
cboxEraseFlash=1
cboxWriteEeprom=0
cboxWriteFlash=0
cboxVerifyFlash=0
UARTx=2
SerialNumber=
OscillatorTypeItemIndex=4
ExtOscFreq=8000000
ClockDividerItemIndex=0
PllFactorItemIndex=4
PllClockSourceItemIndex=0
DeviceItemIndex=6
BaudRate=115200
BootLoadSize=2048
intBootLoadSize=2048
SerialPortDevice=/dev/ttyUSB0
AppFlashFileName=/home/1-Xmega/1-XME-Board-George/XME_1_1.hex
ConnString=0500013977B6
This is console startup msg
EasyBootXAVR.1.4LIN-128$ ./EasyBootAVR_1_4
[WARNING] Out of OEM specific VK codes, changing to unassigned
[WARNING] Out of unassigned VK codes, assigning $FF
See attached png. |
Posted: Jan 24, 2012 - 01:02 AM |
Posted: Jan 24, 2012 - 07:24 AM |
| Goodies arrived today George, XME board and EasyBoot work fine, now for some tinkering! Thanks again! |
Tulsa, Oklahoma
Posted: Jan 24, 2012 - 06:58 PM |
angelu wrote:
It seems that the existing driver for CP210x does not fully support CP2104.
See this
http://www.spinics.net/lists/linux-usb/msg56962.html
I tested the bootloader IDE in Ubuntu 10.4 with a standard serial port and it is working.
George.
Hmmm ... It kinda renders the built-in USB i/f useless @ Linux
Unless you want to roll your own kernel.
/Bingo |
Posted: Jan 24, 2012 - 07:20 PM |
This happen with new devices.
What about Ubuntu 11 ?
I will contact a Silicon Lab rep. |
Posted: Jan 25, 2012 - 01:54 PM |
@George
It seems that CP2104 support is in Kernel 3.x
But based on previous experience , im only using Ununtu LTS versions (latest is 10.04) w. Kernel 2.6.38
I tried to build a driver yesterday from Silabs , but the latest was corrupt on download (several tines)
And the previous had tonzz of build errors.
Edit:
But i guess this was one of the purposes of your nice offer.
To discover those "unplesanties"
/Bingo |
Posted: Jan 25, 2012 - 06:25 PM |
I received mine, Thanks again George.
I have not had much time to play with it yet, but do have the boot loader running fine (and led blinky running) in WinXP sp3, will use win7 64bit later.
Thoughts on the hardware, A taller user button to make it easier to press (reset is fine). Also an option to have the expansion header mounted upside down to mount a board without enlarging size (other than thickness) and without covering LCD screen is about only other thing I can think of that has not been mentioned already. |
Posted: Jan 25, 2012 - 07:30 PM |
Posted: Jan 25, 2012 - 07:35 PM |
To add to Bingo's comment:
The AVRISP mkII cable has lead one marked with a red wire.
With the Mini-PCB connected to the MXE plug the mkII cable connector in so that the red wire is at the end of the 6-Pin connector farthest from the little Reset push button switch on the Mini-PCB.
JC |
Posted: Jan 26, 2012 - 04:13 AM |
Today I installed Ubuntu 11.10 with kernel 3.0.0-15 but still no luck  |
Posted: Jan 26, 2012 - 08:30 PM |
Hi George,
Clearly a lot of work went into the XME design!
It is a very nice Xmega platform to work with.
I have the LCD, Piezo, USB Bridge, and PB Switch up and running.
The External Memory and the Accelerometer will obviously take a little bit more effort.
I thought I'd mention something here that might otherwise go un-noticed, and potentially damage the device. I did not wish anyone to inadvertantly do so. Perhaps Manual Ver 2 could include a line or two about this:
Some AVR Programmers just monitor the Vtarget voltage on the programming headers to adjust the programmer's output voltage to match that of the target board being programmed.
Other programmers, like the STK500, (Which, admittantly would not be used for PDI programming), can supply power to run the target PCB via the Vtarget pin on the programming header.
If one were not using the USB port connection on the XME, and was instead just using it as an Xmega development platform, one might consider powering the XME from their programmer, via the Vtg pin on the programming header. (One less cable in the way, "Testbed" not tied to PC, etc.)
Although convenient, this is probably not a good thing to do.
The potential problem, (no pun intended), is that back-powering the XME board through the Vtg pin on the programming header at 3 or 3.3 Volts will also supply 3.3 V to the Vout pin of the voltage regulator, (the MCP1725).
In this mode, however, the voltage regulator's Vout will be more than 0.3 V greater than the voltage regulator's input, Vin.
Although some voltage regulators might tolerate Vout > Vin, the Electrical Spec's state that no pin can have a voltage greater than Vin + 0.3 V. (Vout exceeds this in this mode.)
I asked MicroChip if the "non-powered" mode of the voltage regulator was an exception to this rule, and Vout could be > (Vin + 0.3) and they said no.
A schottky diode directly across Vin and Vout, reverse biased, would solve this.
An alternative solution would be to use an adjustable version of the voltage regulator and run it at 3.3 V + Vdiode with a forward biased diode in the output, powering the rest of the circuit, and blocking any back-feed to the voltage regulator in a non-USB powered mode.
I do not know if the MCP1725 will really care about this or not, I don't have any sitting on my bench to test it. But regardless it would be out of spec.
I don't know exactly which PDI capable programmers can source out of the Vtg pin, (I have one which can), but perhaps either Ver 2 of the PCB could include the diode, or Ver 2 of the Manual should include a warning.
Such an event would no doubt be a rare occurrence, but I thought it worth mentioning least someone discover this the hard way.
Keep up the good work. I like the XME.
JC
Edit: Typo. |
Posted: Jan 26, 2012 - 09:15 PM |
Good catch, Doc.
So the voltage regulator is an issue (not a problem), but also the Xmega and flash mem don't like a Vcc of 5V.
How about this as ECN in the next generation: a resistor of 1k between Vcc on the PDI connector and the local 3.3V ? The Xmega, displaydriver (avoiding the brand ), flash memory, amplifier etc. will draw more than 1.7mA, so the 1k will be high enough to keep them safe.
I can check with the STK600 if that 1k effects the read back voltage; Dragon may be harder since I don't want to upgrade it (no AVR Studio5 for me). But I can give it a try.
Nard |
Posted: Jan 26, 2012 - 10:13 PM |
The linear regulator has one diode on the power P mosfet (see picture). The linear regulator is 500mA rated and at the input of the regulator there is also an external diode, so all what that internal diode has to power is the internal circuits which I estimate to take less than 1mA.
If I would have put the diode after the regulator, then the voltage after the diode would have been compromised. The voltage drop for a diode depends on the current.
I am not concerned at all that a 3.3V voltage on the external connector would damage it when not connected to USB.
The fact there is a 500mA regulator there is to provide power to some potential loads connected to the board. Some extensions (shields) for this board will follow soon. Having there a resistor would compromise this.
STK600 do not allow you to set a voltage higher than 3.3V as long as you have an Xmega selected.
Well, I know, I have to put these things on the manual.
Anyway, thanks for your attention.
George. |
Posted: Jan 26, 2012 - 10:29 PM |
That's fine, but you need to realize that the voltage regulator is still being operated out of spec IF one powers the XME via the programming header, (at 3 V), or if someone powers it via the power connection on the 2x10 Header.
The hard spec, written by MicroChip, is that Vout can't be more than 0.3 V above Vin. With the External FET and the External (input) diode, Back-Powering this chip will be out of spec.
An additional schottky diode, directly across the voltage regulator fixes this. Completely.
But, it is totally your call as to whether you do this or not. Engineering is about trade offs.
My point is I want to be sure you understand the decision you are making. I am NOT trying to force you to change any thing.
I said it before, and I'll repeat it: You did a very nice job. It is much easier for use to critique a design than it is for one to create a design.
JC |
Posted: Feb 15, 2012 - 02:23 PM |
Nard,
Have you had a chance to test the XME's Serial Flash Memory with Bascom yet?
(A simple Erase Chip and then Write to Location 000h, followed by Reading back from location 000h?)
If so, I would be interested in seeing how this was performed.
If not, not a problem.
JC |
Posted: Feb 15, 2012 - 02:51 PM |
No. Not found a timeframe to do that. Too many other things absorbed the available time.
Sorry for that.
Nard |
Posted: Feb 15, 2012 - 03:01 PM |
Not a problem!
I know the "Too many things..." all too well!
JC |
Posted: Feb 17, 2012 - 05:03 AM |
