Posted: Dec 28, 2011 - 03:29 PM |
Hey everybody!
I just started using avr studio and I got a question, I got a problem programming a servo motor in avr studio 5. The meaning of my program is that the servo motor goes to the value in the servo.c file can someone help me? thx
code:main
#include "servo.h"
void main (void)
int i;
DDRB = 255;
PORTB = 255;
for(i=0;i<optel();i++);
PORTB = 0;
for(i=0;i<32000;i++);
code: servo.c
#include "servo.h"
unsigned char optel (void)
optel=300;
unsigned char optel (void);
code: servo.h
[/b] |
Posted: Dec 28, 2011 - 07:42 PM |
in servo.c
- optel() has no return - add return
- 300 is greater then 255 change char to int
unsigned int optel (void)
return 300;
in servo.h change declaration to unsigned int optel (void);
- line void main(void) change to int main(void) and add return 0 before last } |
Posted: Dec 28, 2011 - 08:15 PM |
| Wrong forum. This post has absolutely nothing to do with AS5. |
Posted: Dec 28, 2011 - 08:25 PM |
| OK - for admin (moderator) - move this post to GCC. |
Posted: Dec 28, 2011 - 08:43 PM |
Does not it come with an integrated C compiler? |
Posted: Dec 28, 2011 - 09:02 PM |
AS5 forum is about problems with AS5. Installation, compile, debug, help, improve idea,
This post is apparently about beginner and C language |
Posted: Dec 28, 2011 - 09:03 PM |
Irrelevant.
Would you call up the Microsoft help line to answer a question on grammar simply because you were writing in Microsoft Word?
This forum is for questions and problems regarding AS5 itself, not about how to program AVRs. It is certainly not about problems with servos or the C language itself, which is what the problem is here.
Edit: For those of you who might be confused, "this forum" referred to the AS5 forum where this post was originally.
And for whomever moved it, it is still not a good forum since the question is not specific to gcc either. |
Posted: Dec 28, 2011 - 09:15 PM |
| hmmm grumble...I should just delete it .... |
Posted: Dec 28, 2011 - 09:19 PM |
Do not worry - move this post before start its own life with hundreds replies about nothing.
Note: There is not forum for beginners. For anybody is better place post and wait for solution, then learn or find solution in books, in internet, in school.
Your sentence:The Board helps those that help themselves.-- is right. |
Posted: Dec 28, 2011 - 09:22 PM |
No worries here, the problem was solved with the very first response. |
Posted: Dec 29, 2011 - 12:16 AM |
| A servo wants to see a specific waveform in order to work properly. You need a pulse between 1 and 2ms, repeated every 20ms of so. Your code produces pulse, but we don't know how wide, since we don't know you clock speed. |
